Question about Disney Playhouse 's Stanley Wild for Sharks! (2589901) for Mac, PC
Can't uninstall stanley wild for sharks
It says the file size is 3876 mb - when i go to remove it, i click remove and nothing happens - it also says it's used on a daily basis - i have never played the game and want to delete it from my computer. what can I do?
  • Anonymous Jan 11, 2009
    I have the same problem and it is causing my computer to go soooo slow. If anyone can help, it woud be appreciated. Thanks!
2 Suggested Answers
Bruce Boogie
  • 242 Answers
SOURCE: I cannont uninstall stanley wild for sharks on my
go into control panel look for install/uninstall.
You must use this to uninstall otherwise lots gets left on your machine,
Or check on Google for a free uninstall program.
Good luck.
Posted on Feb 13, 2011
I want delete ArcSoft MediaImpression2 from Add or Remove Program but cannot. When I click Remove button, nothing happen but the file is still there. I need your help/ Thanks in advance
Click here to download and install ccleaner.exe
This program is free for you
once started, access the add/remove programs tab on the left hand side and select the program you want to remove and click uninstall. If you cant uninstall still, you can remove it from the systems program log, as it may be corrupted or may have uninstalled correctly, but left the file that windows reads in order to say it is installed.
GOOD LUCK AND RATE HIS POST AS FIXYA!!!!
May 13, 2011 | Arcsoft MediaImpression 2
Virtual Memory is low
To change the size of the virtual memory paging file
You must be logged on as an administrator or a member of the Administrators group in order to complete this procedure. If your computer is connected to a network, network policy settings may also prevent you from completing this procedure.
1.
Open System in Control Panel.
2.
On the Advanced tab, under Performance, click Settings.
3.
On the Advanced tab, under Virtual memory, click Change.
4.
Under Drive [Volume Label], click the drive that contains the paging file you want to change.
5.
Under Paging file size for selected drive, click Custom size, and type a new paging file size in megabytes in theInitial size (MB) or Maximum size (MB) box, and then click Set.
If you decrease the size of either the initial or maximum page file settings, you must restart your computer to see the effects of those changes. Increases typically do not require a restart.
Note
Right Click on My computer then select properties OR
To open System, click Start, click Control Panel, click Performance and Maintenance, and then click System.
To have Windows choose the best paging file size, click System managed size.
For best performance, do not set the initial size to less than the minimum recommended size under Total paging file size for all drives. The recommended size is equivalent to 1.5 times the amount of RAM on your system. Usually, you should leave the paging file at its recommended size, although you might increase its size if you routinely use programs that require a lot of memory.
To delete a paging file, set both initial size and maximum size to zero, or click No paging file. Microsoft strongly recommends that you do not disable or delete the paging file.
May 04, 2011 | Microsoft Windows XP Professional
I have a game called juiced and When i double click to play it it says ,,Juiced requires virtual memory to be enabled".Can somebody please help me to fix this error and play my game please?I have...
Manually manage computer memory loadTOCNode(3, 'moreinformation'); When your computer's physically installed random-access memory (RAM) is running low, Windows adds available memory by using a paging file, generally known as virtual memory, on the hard disk to simulate physical RAM. By default, the virtual memory paging file that is created during installation is 1.5 times the physical RAM on your computer. Therefore, a computer that has 1GB of installed RAM will have 1.5GB of virtual memory.
You can manually change the size of the paging file to make it larger or smaller. You can also optimize virtual memory use by dividing the file space between multiple drives and by removing allocated space from slow or heavily accessed drives. To optimize your virtual memory space, divide it among as many physical hard drives as possible. When you select drives, follow these guidelines:
  • Try to avoid having a paging file on the same drive as the system files, usually drive C.
  • Avoid putting a paging file on a fault-tolerant drive such as a mirrored volume or a RAID-5 volume. Paging files do not require fault tolerance, and some fault-tolerant computers experience slow data writes because they write data to multiple locations.
  • Do not put multiple paging files on different partitions on the same physical disk drive.
How to manually change the size of the virtual memory paging file loadTOCNode(4, 'moreinformation'); You must be logged on as an administrator or as a member of the administrator's group to complete this procedure. If your computer is connected to a network, network policy settings may prevent you from completing this procedure.
To manually change the size of virtual memory, follow these steps:
  1. Click Start, click Run, type sysdm.cpl in the Open box, and then press ENTER.
  2. Click the Advanced tab, and then under Performance click Settings.
  3. Click the Advanced tab, and then under Virtual memory click Change.
  4. Under Drive [Volume Label], click the drive that contains the paging file that you want to change.
  5. Under Paging file size for selected drive, click Custom size, type a new paging file size in megabytes (MB) in the Initial size (MB) or Maximum size (MB) box, and then click Set.
  6. Click OK to close the dialog box and apply changes.
Note After you change the size of the paging file, you may be prompted to restart Windows. If you are prompted to restart, the changes will not take effect until Windows is restarted.
Notes
  • To have Windows select the best paging file size, click System managed size. The recommended minimum size is the same as 1.5 times the RAM on your computer, and 3 times that figure for the maximum size. For example, if you have 256 MB of RAM, the minimum size is 384 MB, and the maximum size is 1152 MB.
  • For best performance, do not set the initial size to less than the minimum recommended size under Total paging file size for all drives. The recommended size is the same as 1.5 times the RAM on your computer. It is good practice to leave the paging file at its recommended size as performance can decrease if a paging file is too large. However, you may increase its size if you frequently use programs that use lots of memory, such as graphics programs or games.
  • We strongly recommend that you do not disable or delete the paging file because this can lessen the computer's performance. However, if you decide to delete a paging file, set both the initial size and the maximum size to zero, or click No paging file.
How to manually optimize the memory usage loadTOCNode(4, 'moreinformation'); You can optimize your computer's memory usage to reflect your specific needs. If your computer is used as a workstation instead of as a server, you can increase performance by devoting more memory to your programs. Your programs will work faster and the system cache size will remain the default size that was included with Windows XP. Or, you can set aside more computer memory for a larger system cache if your computer is used primarily as a server, or if you use programs that require a large system cache.
  3. Click the Advanced tab, and then under Memory usage use one of the following methods:
    • Click Programs if you use your computer primarily as a workstation instead of as a server. This option allocates more memory to your programs.
    • Click System cache if your computer is used primarily as a server or if you use programs that use a large system cache.
  4. Click OK to save preferences and close the dialog box.
You may refer to this link http://support.microsoft.com/kb/308417
Apr 18, 2011 | Intel Core 2 Quad Q8200 Computer System...
There isn't a paper jam there is ink in the cartridges, i have selected the printer. when it prints the paper comes out blank
Make sure that the computer has available hard drive space
Printing requires the computer to have a certain amount of available hard drive space to process print jobs and to send them to the printer. Step one: Check the virtual memory settings Virtual memory is the temporary disk space on the hard drive that processes print jobs. It usually requires at least 200 MB of disk space but might require more or less depending on the printer. Insufficient virtual memory might cause the issue. Follow these steps to check and modify the amount of the virtual memory available.
Click Start , right-click My Computer , and then click Properties . Click the Advanced tab. In the Performance section, click Settings . Click the Advanced tab. In the Virtual memory section, click Change . For correct configuration, the Initial size and Maximum size settings must be less than the Space available on the hard drive. If the Space available on the hard drive is less than 200 MB , skip to the next step. Follow the instructions to clear space on the hard drive, and then start these steps over. The Initial size setting is the amount of space reserved for virtual memory on the hard drive. The Initial size setting should be about 200 MB, and greater than or equal to the recommended paging file size shown in the lower section of the dialog box. The Maximum size setting can be any number greater than the Initial size setting, but it should be at least twice the Initial size setting. Change the settings as necessary to conform to the information in this step. Click Set , and then click OK . Try printing again. If these steps resolved the issue , there is no need to continue troubleshooting. If the issue persists , see the next step
Step two: Run Disk Cleanup to remove temporary files Follow these steps to run Disk Cleanup. Click Start , click Programs , click Accessories , click System Tools , and then click Disk Cleanup . Disk Cleanup prompts you to select a drive to clean. Select the hard drive, and then click OK . Disk Cleanup analyzes the hard drive and presents a report. Select the following items from the report: Temporary Internet Files Downloaded Program Files Recycle Bin Temporary Files Click OK . If these steps resolved the issue , there is no need to continue troubleshooting. If the issue persists , see the next step. Step three: Remove unnecessary software programs Follow these steps to remove unnecessary software programs. Click Start , click Settings , click Control Panel , and then click Add/Remove Programs . Select a software program to remove, and then click Add/Remove . Repeat these steps for all software programs you want to remove. If you remove large software programs, run Scan Disk and Defrag on the hard disk drive. Look for these options in the System Tools section of Accessories
Mar 03, 2011 | HP PhotoSmart C4280 Laser Printer
I get the message when i try to copy a CD ,,out of memory
Your virtual memory is low this is not a real problem when you have other things running in the background you do not know about. I usually increase my memory as well as when I burn things I have no windows open email automatic checking turned off as well as power options stopped so I can get a clean burn no glitches as well as it may take a bit longer but I use the slower speed rather than the fastest speed burning never fails when I do this.
How to manually change the size of the virtual memory paging fileYou must be logged on as an administrator or as a member of the administrator's group to complete this procedure. If your computer is connected to a network, network policy settings may prevent you from completing this procedure.
Notes
How to manually optimize the memory usageYou can optimize your computer's memory usage to reflect your specific needs. If your computer is used as a workstation instead of as a server, you can increase performance by devoting more memory to your programs. Your programs will work faster and the system cache size will remain the default size that was included with Windows XP. Or, you can set aside more computer memory for a larger system cache if your computer is used primarily as a server, or if you use programs that require a large system cache.
  4. Click OK to save preferences and close the dialog box. I hope that this assisted you thanks for using FixYa! John
Feb 23, 2011 | CyberLink Power2Go
I cannont uninstall stanley wild for sharks on my windows program. It is listed as 9,622MB, this is a large file how can i delete it?
Good luck.
Feb 13, 2011 | Disney Playhouse 's Stanley Wild for...
How to down load to flash drive
I've just cut and pasted this from the windows help files:-
  1. Open shortcutcold.gifComputer Management (Local).
  2. In the console tree, right-click Computer Management (Local), and then select Properties.
  3. On the Advanced tab, click Performance Options, and under Virtual memory, click Change.
  4. In the Drive list, click the drive that contains the paging file you want to change.
  5. Under Paging file size for selected drive, type a new paging file size in megabytes in the Initial Size (MB) or Maximum Size (MB) box, and then click Set. If you decrease the size of either the minimum or maximum page file settings, you must restart your computer to see the effects of those changes. Increases generally do not require a restart.
note.gif Notes
  • To open Computer Management, click Start, and then click Control Panel. Double-click Administrative Tools, and then double-click Computer Management.
  • You must be recognized as an administrator or a member of the Administrators group on your computer and on the computer you are managing to perform this task.
  • You can view or change system properties on a remote computer or a local computer. To access a remote computer, right-click Computer Management (Local), click Connect to another computer, and then select the computer you want to connect to in the list.
  • For best performance, set the initial size to not less than the recommended size under Total paging file size for all drives. The recommended size is equivalent to 1.5 times the amount of RAM on your system.
  • Usually, you should leave the paging file at its recommended size, although you might increase its size if you routinely use programs that require a lot of memory.
  • To delete a paging file, set both initial size and maximum size to zero.
Once you've set your virtual memory to satisfaction. Just plug your usb flash drive in and watch the bottom right hand corner of the screen. You'll see a couple of process messages the last of which will be "your device is now ready".
What may also happen is a window pops up and asks you how you want to view the files on your device and offer a few programmes with which to do it.
If its data for transfer, click on the folder option, its then just a case of dragging and clicking files over to your computer or vice versa.
If you're still not happy, click on to "Youtube" and search for "How to use a USB drive". There are several good video intruction files there.
Jun 06, 2010 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
Hi I have reformat my Acer aspire 3050 and he delete my drivers what should I do to get them back?
HI friend
click here to download your drivers
Realtek - Audio audio.png Acer Aspire 3050 Realtek Audio Driver for Windows Vista Enterprise 32bit
Filename: Audio_Realtek_6.01.5334_Vistax86.zip
File size: 33.3 MB
Version: 6.01.5334
broadcom.jpg Broadcom - Bluetooth bluetooth.png Acer Aspire 3050 Broadcom Bluetooth Driver for Windows Vista Enterprise 32bit
Filename: Bluetooth_Broadcom_6.0.1.3500_Vistax86.zip
File size: 19.5 MB
Version: 6.0.1.3500
bison.jpg Bison - Camera camera.png Acer Aspire 3050 Bison Camera Driver for Windows Vista Enterprise 32bit
Filename: Camrea_Bison_1.0.0.14_Vistax86.zip
File size: 9.3 MB
Version: 1.0.0.14
suyin.jpg Suyin - Camera camera.png Acer Aspire 3050 Suyin Camera Driver for Windows Vista Enterprise 32bit
Filename: Camera_Suyin_1.0.0.8_Vistax86.zip
File size: 22.4 MB
Version: 1.0.0.8
ene.jpg ENE - CardReader no_image.png Acer Aspire 3050 ENE Card Reader Driver for Windows Vista Enterprise 32bit
Filename: CardReader_ENE_5.1.2600.3000_Vistax86.zip
File size: 627.3 KB
Version: 5.1.2600.3000
conexant.jpg Conexant - Modem modem.png Acer Aspire 3050 Conexant Modem Driver for Windows Vista Enterprise 32bit
Filename: Modem_Conexant_7.62.00_Vistax86.zip
File size: 2.1 MB
Version: 7.62.00
synaptics.jpg Synaptics - TouchPad touchpad.png Acer Aspire 3050 Synaptics Touchpad Driver for Windows Vista Enterprise 32bit
Filename: Touchpad_Synaptics_9.1.0_Vistax86.zip
File size: 22.9 MB
Version: 9.1.0
ati.jpg ATI - VGA vga.png Acer Aspire 3050 ATI VGA Driver for Windows Vista Enterprise 32bit
Filename: VGA_ATI_8.332.0.0_Vistax86.zip
File size: 110.4 MB
Version: 8.332.0.0
atheros.jpg Atheros - Wireless LAN wireless_lan.png Acer Aspire 3050 Atheros Wireless LAN Driver for Windows Vista Enterprise 32bit
Filename: Wireless%20LAN_Atheros_7.2.0.152_Vistax86_A.zip
File size: 2.8 MB
Version: 7.2.0.152
broadcom.jpg Broadcom - Wireless LAN wireless_lan.png Acer Aspire 3050 Broadcom Wireless LAN Driver for Windows Vista Enterprise 32bit
Filename: WLAN_Broadcom_4.102.15.61_Vistax86.zip
File size: 2.9 MB
Version: 4.102.15.61------------------------------------------------------------------------------
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
Mar 30, 2010 | Acer Aspire 3050 Notebook
Kodak esp 3 setup .exe file will not run.
If the device is installed, uninstall it.
And then re-install it, using the driver.
You can download the drivers from different locations.
Like Here
Here (Select the desired Device first)
Or you can also try the official Kodak Site Here (Yes its a 1.38 mb file, but it will download the rest of files when you'll install it)
If i was helpful, Kindly do Rate!
Jul 19, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
PC gets hang while browsing
hi swap
u need to follow some steps..
step 1) click on start>run>type "prefetch"..
delete all the files that appear in the prefetch folder
step 2)click on start>run>type "%temp%"..
try deleteing all the files u can in %temp% folder.
also empty ur recycle bin
step 3) right click on my computer>properties>>advanced>>>click on "settings" under performance>>>again click on "advanced">then under virtual memory click on "change">>>set (custom size)initail size : 1024 &maximum size : 1024>> click on set >> then click on ok and then exit.
step 4)uninstall unessesary applications from control panel>>add/remove program...
ALSO INSTALL AN ANTIVIRUS LIKE AVG 7.5 FROM www.avg.com, www.softpedia.com
Nov 03, 2007 | Microsoft Windows 2000 Professional for PC
Disney Playhouse 's Stanley Wild for Sharks! (2589901) for Mac, PC Logo
134 people viewed this question
Top Disney Computers & Internet Experts
Jax Planet
Jax Planet
ray gallant
Are you a Disney Computer and Internet Expert? Answer questions, earn points and help others
