Question about Garden
Were can i get parts and blades for for a wen model 3700 all saw
I have an old Dremel scroll saw model 550 and need blades. However, the blade holder is missing a clamp that secures the blade. Is there a universal kit I can purchase to solve problem?
Try going to a store that sells scroll saws and look at the new models to see how they hold the blade. Take your Dremel with you. Maybe you can find one that is similar enough that could work if you can get the part. Then go to the tool company's web site and search for the manual for the comparable tool you found - they all have on-line manuals nowadays. You should be able to order the part you need. Good luck!
Jan 30, 2013 | Dremel 5 3" Saw Blades 8033 For 550...
How long is the band saw blade on model 113.24330C
I can't find a Sears model 113.24330C but there is a 113.243300 so hopfully part of the last 0 got worn off. That model is a 12" bench top band saw that uses a 1/4 X 80-inch blade.
Mar 19, 2012 | Craftsman Saws
My Craftsman 7&1/4 inch 12 amp Circular Saw(Model 315.108330) slips while cutting. The motor keeps spinning but the saw stops rotating. Can I Fix it?
Most circular 7-1/4 saws have a bolt and a compression washer that acts as a brake shoe that holds the blade secure but under dire circumstances will allow the blade to slip some rather than hold the motor shaft and allow burn out. The compression washer under your bolt has become worn and doesn't grip the blade securely. You can find a split washer that will fit under the blade and give you some more friction, or go to sears and order another compression washer for your saw.In the Sears Parts List found at: http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Saw-Parts/Model-32018780/0247/0744410/50035950/00001?blt=06&prst=&shdMod=
see part no. 44
Feb 23, 2011 | Craftsman Evolv 12 Amp 7-in Circular Saw -...
Sharpen blade of chain saw
This website explains how to do it...
http://www.ehow.com/video_4419332_sharpen-chainsaw-chain.html
May 11, 2010 | Garden
Sharpening blade of chain saw
The blade needs sharpening when it stops cutting very well. Here is a website to tell you how to sharpen it...
Need switch for wen model 6014 chain saw
Jerry answered this. Reposting the same question won't cause Wagner to begin manufacturing a discontinued line.
A manual for a 6016 can be found here:
WagnerSprayTech purchased Wen forever ago
http://www.wagnerspraytech.com/portal/finding_a_product_manual_spray,98115,747.html
This unit is out of production. Contact Wagner for any parts availability. HTH
Lou
Nov 11, 2009 | Electric Chainsaw Sharpener
I need the outer flange/blade clamp for my skil model 77 type 16
The replacement part is 1619X02969. And you can get it from directly from boschtoolservice.com ($3.75).
Oct 11, 2009 | Skil 7 1/4" Magnesium "Mag 77" Wormdrive...
Need new saw blade part no & size for remington model 104316-04
The part you will need is the 8SB. You can call Master Parts at 800-446-1446 or you also can find them online at www.masterparts.net. I hope this helps!
May 24, 2009 | Remington Electric Pole Saw
Wen electric chain saw -is it doa?
Are you pressing the trigger lock with your thumb before you pull the trigger? That's a safety feature to prevent accidental sawing.
There's not a sensor for the oil, but you don't want to run the saw dry. It takes a special bar/chain oil which is thicker than motor oil.
FYI... if you look for a manual on the web, search for "Wagner chainsaw" because Wagner bought the chainsaw business from Wen.
Mar 10, 2009 | Electric Chainsaw Sharpener
Garden Logo
684 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
