Question about Lexmark X125 All-In-One InkJet Printer
Lexmark x125 all in one won't print from memory.
Replaced both ink cartridges and now it will not print from memory or receive faxes. It does receive and print jobs from my pc. It also tells me to install both cartridges, even though I have just replaced them both. HELP!!!!!!!
  • 408 Answers
Did you go into your printer properties and select new cartidge installed?  If this doesn't work, take the cartridges out and clean the contacts on the side and in the carrier with a qtip and rubbing alcohol.  Give it a few minutes to dry and reinstall the cartridges.
Posted on Mar 11, 2009
Printer says cant print until cyan ink is replaced. Have replaced it with 2 different cartridges, but still wont print
You won't be able to print if one of the cartridges is out of ink. The printer will prime every once in a while thus the need for all cartridges to have sufficient ink levels to prevent damaging the printhead.
May 29, 2012 | Lexmark Interpret S405 - multifunction ...
Memory info retrieving from lexmark x5630 fax machine
Usually, faxes are temporarily sent to the printer's memory when one of the cartridges' ink level is not substantial for printing at the instance of receiving the fax. When this happens, try to replace the cartridge(s), *without navigating away from the message "fax sent to memory", by opening the printer cover and replacing the low-ink or empty cartridge(s). After the new cartridge is installed, close the printer cover and press the OK button. Your printer should then print the fax stored in the memory.
*Make sure not to navigate away from the "fax sent to memory" message, otherwise, data will be lost.
Dec 30, 2011 | Lexmark X5650 ALL-IN-ONE PRINTER
How to print faxes from the lexmark x5630 which is stored in the memory
Dec 30, 2011 | Lexmark X5650 All-in-One InkJet Printer
How do I print faxes in the memory of Lexmark X6650 all-in-one-printer ? Is there a "tools" item in the setup menu ?
Usually, faxes are temporarily sent to the printer's memory when one of the cartridges' ink level is not substantial for printing. You are advised to replace the cartridge/s, *without navigating away from the message "fax sent to memory", by opening the printer cover and replacing the low-ink cartridge/s. After the new cartridge/s is installed, close the printer cover and press OK button to let printer print the fax stored in the memory.
* Make sure not to navigate away from the "fax sent to memory" message. You will lose the fax-in-memory data once you turn off the printer or navigate away from the message.
Sep 15, 2011 | Lexmark C533DN InkJet Printer
How do i print a fax stored in lexmark x5495 if a fax is sent and does not print out, is it saved anywhere for me to retrieve
When an incoming fax is stored temporarily in the printer's memory, chances are, one of your cartridges has low ink level. To retrieve stored faxes, current state of printer must be on the instance when the fax is temporarily sent to printer's memory. Replace your low-ink cartridge without navigating away from the Fax function. Once you have replaced the cartridge, press Ok button to continue printing the fax.
Jun 21, 2011 | Lexmark X5470 All-In-One InkJet Printer
Lexmark x5470 the machine received faxes but does not print them. saying "fax jobs in memory"... how do i print them?!?!
It could be because one of your cartridges has low ink level, thus printer is not able to continue printing the fax message. Open the printer cover and replace your cartridges (without navigating away from the fax mode). Once cartridge/s has been replaced, just hit the Check mark to print the fax message.
May 18, 2011 | Lexmark X5470 All-In-One InkJet Printer
I have lexmark x7170 all in one printer and i can't receive faxes it says memory full but when i try clearing it it says no pending faxes so i cam't. What can i do?
This temporary storage of fax may happen when one of your cartridge is detected low ink level. Try to replace your low ink cartridge. Sadly, if you have navigated away from the fax menu after inserting a new cartridge or clearing the message, you may lose the fax. You can try to have the sender resend the message. When this problem happens again, just replace your cartridge without turning off your printer. Once inserted, accept the incoming fax message to print it.
Feb 16, 2011 | Lexmark X7170 All-In-One InkJet Printer
Lexmark x125
Follow the steps given below:
1. Snap the cartridges in and out three times.
2. On the operator panel, press Options to indicate which cartridges were changed.
3. Press Start / Yes.
4. Press Options to indicate the type of cartridge you installed.
5. Press Start / Yes.
If the problem persists, do the following:
1. With the printer powered on, remove both cartridges.
2. Unplug the power cable from the back of the printer
3. With the printer disconnected, insert the cartridges and reconnect the power cable.
Apr 09, 2009 | Lexmark Pro X125 All-In-One InkJet Printer
I Need to Print
Sadly in a word, 'No'.
Here is the exact answer from Brother:
Your Brother machine is designed to stop ALL printing operations
(printing from the pc, printing received faxes and printing copies or reports) when any of the ink cartridges are empty. This is to ensure the life of the print head and maintain premium print quality. If the unit were to continue printing, print jobs and cleaning cycles would suction air from the dry cartridge and damage the printhead. Even if you print in black only or change the print settings to MONO or GRAYSCALE to avoid printing in color, the programmed cleaning cycles would still suction the dry cartridge, because they are programmed to clean ALL the ink nozzles.
The only way to continue printing is to replace the empty ink cartridge or cartridges.
While memory is available, black and white faxes will continue to be received into memory. If a color fax is being received, the Brother machines HANDSHAKE will request the fax be sent as black and white fax.
All faxes received into memory will automatically print once the ink cartridge is replaced.
NOTE: Brother strongly recommends that customers do not use generic ink or refill their Brother ink cartridges. Using non-Brother supplies may affect the hardware performance, print quality and machine reliability since the ink formulation in genuine Brother ink cartridges prevent smearing and clogging of the print head. The Brother limited warranty does not apply to any problem that was caused by the use of unauthorized third party ink and/or cartridges.
Nov 26, 2008 | Brother Multi-Function Center MFC-240C...
How do I print from memory
that's because there's a job that's stuck...
check the printer spooler for any print jobs that are hanging, delete them and the printer should start printing the fax on it's own... I just did that.
HTH
Jul 10, 2008 | Lexmark Pro X125 All-In-One InkJet Printer
Lexmark X125 All-In-One InkJet Printer Logo
196 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
