Question about GE Spacemaker JVM1640SJ Microwave Oven
How do you remove vent cover for GE Profile Spacemaker JVM1870 microwave
  • 4 Answers
SOURCE: Removal of GE Spacemaker Microwave oven
1. Unplug the microwave. The plug is probably in a receptacle that is in the cabinet above the microwave, or in the wall above the shelf that is above the microwave.
2. Remove the two (or three) screws that go straight down through the bottom of the cabinet, or the shelf, into the top of the microwave. Have help in holding the microwave when you do this, as the front of the microwave will be able to fall down when the screws are removed.
3. Allow the front of the microwave to rotate down a little, then lift the back of the unit up about 1/2" to 1". At this point, the microwave will be disconnected from the mounting plate on the wall, so you can move it forward and carry it away.
Posted on Nov 29, 2007
SOURCE: Outside venting GE Profile Spacemaker XL1800
Your vent flap could be taped or it could be faulty installation not allowing the vent to open. If you take the front vent cover off, you should be able to reach in above the fan unit and gently push the vent flap up, it should move freely with no binding. If it doesn't it is taped or blocked. If it is taped, gently putting upward pressure on the flap might release the tape. If that doesn't work the vent installation is blocking the flap. You might have to remove the unit from the wall (two people to do this) or disassemble the vent duct above the microwave and rework the interface for clearance.
hope this helps,
Posted on Oct 07, 2008
SOURCE: bulb replacement
NO,If you can get to the three phillips screws directly over the vent door then you do not have to take the unit down. Unplug the unit. Remove the top three screws over the center of the louvre and then carefully lower the vent louvre. (Lowering helps me get a better grip on the louvre assembly. Then you will slide the vent louvre assembly about 1/8" to the left and then it will pull straight back and out. In the center is an aluminum cover which has a phillips screw facing you. Remove this screw and the cover plate. The light bulb is directly to the left of the inside of the cover plate. You will see the metal tabs which hold it in place. Pull the bulb housing assembly straight out (to your right) as you face the microwave. Then you will locate your halogen 120V 20W bulb. I just received this from a fellow guest on fix it and I was able to fix my unit 10 mintes ago.Also another tip was to take the inside glass out when reinserting the bulb unit back in because it does get in the way. Good Luck
Posted on Jun 08, 2009
  • 87 Answers
SOURCE: GE Microwave Oven Installation
If the top of it butts aginst your cabinets you will have to take the bolts from the inside of your cabinets around the front area that that are holding it up out (use 2 people) once they are out it "should" still hang there, next step slowly lift it an inch or so (then you will be no longer on the back suppot) again use 2 people, then you can pull straight out. hope this is what you are looking for.
Posted on Oct 03, 2009
MicrowaveSvc
  • 9098 Answers
SOURCE: I have a GE Profile Spacemaker Microwave Touch Pad does not work
Sadly, GE does not make individual parts available for these controllers, so they cannot be repaired.
You have to replace the control panel sub-assembly (part number WB07X10733 in your case) and the best price I've found on that is $370.32 here (compared to $483.25 direct from GE).
In my opinion, this does not do much to inspire brand loyalty...
Or you may be able to find a whole oven on eBay for about that or less.
Sorry to bear bad news. Good luck.
We're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer
Posted on May 30, 2010
GE spacemaker profile xl 1800 moving vent will not close
I'm betting your base model number is JVM1860, JVM1861, JVM1870, JVM1871, JVM3660, or JVM3670.
That's the automatic louver you're having trouble with. There are micro switches in the louver assembly which tell the controller when the louver is open or closed.
If one of those switches or the louver motor fails, the louver will not work correctly.
Did your cooktop lights recently fail?
Sometimes the surge from them shorting will cause damage to the circuit board, which can be repaired.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
There is a video here showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
May 03, 2013 | GE Spacemaker JVM1640SJ Microwave Oven
Ge spacemaker xl1800 vent fan
May 03, 2013 | GE Profile Spacemaker XL 1800 36"...
HOW DO WE SWITCH FROM TOP VENT TO NON-VENT?
remove outer case and rotate vent fan motor to vent out front of unit
Aug 22, 2010 | GE Profile Spacemaker Over-the-Range...
How do I clean the inside glass on the door - GE Profile JVM1870
I have a Kenmore with similar issues.
Model 665.61639100
Anyway, good luck with this. Hope someone has an answer for you (and me).
Mine has a open slot on the top front of the door. Kinda like a double plate window execpt for the opening in front. Why is this there? I don't know. Weird design. But it leaves for the possibilty of liquid to splash in there leaving it hard to clean (like impossible).
I'm thinking I have to completely remove and disect the door.
Jan 06, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
HELLO, On my built in over the range ge profile
http://www.geappliances.ca/jsp/ge_Listing.jsp?product_id=13&cmb_378=---&cmb_Colours=---&cmb_421=---&cmb_Brands=3&cmb_379=---
click on the link above and it will be able to supply you with your manual. It also has contact information so you can call toll free to ask your question.
1800-626-2000
Dec 06, 2009 | GE JVM1840 Microwave Oven
How do i change the heating fuse for a ge spacemaker microwave
unplug first, take three screws out of top vent cover and there may even be some on the top cabinet holding vent cover on front, then you might see fuse holder just behind vent cover, if not remove screw(s) holding touch pad on, then slide touch panel up and out. it will rest on hinge, then you should see fuse holder inside behind touch panel. BE SURE TO UNPLUG FIRST AS ELECTRICITY CAL KILL YOU.
Oct 09, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
I took the cover off my GE profile microwave and the vent unit that opens when the unit runs. I fixed the microwave but can't get the vent unit back on. It has 4 keyed tabs along the bottom but won't...
look where it is catching you will find it keep trying....i had a bag of a time too just relax go slow... lite.. helps(bud lite)get someone to help balance it and thumbs up
Aug 14, 2009 | GE Profile Spacemaker Over-the-Range...
hope this helps,
Sep 30, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
156 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
