Question about Arris SB6121 SURFboard DOCSIS 3.0 eXtreme Broadband Cable Modem (612572180136)
Do not know my password for my motorola surfboard SB6121, how do I get it?
Since this is a wireless router when I try to connect to the internet from my wireless lap top it shows me my network and asks me for a password to connect to it. It says if I do not know it, ask the owner for permission, the problem is I am the owner and all I want to do is use the wireless connection. No problem when I hard wire it or plug in only with wireless connections.
  • 86 Answers
SOURCE: cable modem + dlink router
Your modem needs to be rebooted in order for your router to pull an IP from the modem. To do this, look for a little hole in the back of your modem and use a pen to push the button. Wait for the reboot to finish and then try again in about 20 seconds.
Posted on Jan 20, 2008
Tech Jenkins
  • 359 Answers
SOURCE: losing connection
I assume this is a cable modem? You need to call your cable company and have a trouble ticket created. I worked for the cable company installing cable for quite a while and I bet my paycheck the signal getting to the modem are below specs and that's why the modem gets dropping the internet connection.
Hope this helps.
Posted on Aug 13, 2008
  • 31 Answers
SOURCE: Motorola Surfboard 4220 not working with my Netgear WGT624 router
Make sure that you have the ethernet cord from your modem plugged into the WAN/Internet port on your router. Then unplug the power cord from your cable modem and plug it right back in. After the modem fully comes back online, unplug the power cord on the wireless router and plug it back in. wait 30 - 60 sec and then try and connect.
Most cable companies only allow one active"CPE" at a time for internet access. All this means is when you change what is connected to the cable modem you must always reboot the cable modem to allow access.
Hope this helps. Let me know if it does not work.
Please rate.
Posted on Apr 10, 2009
zazonker
  • 68 Answers
SOURCE: Unable to set up wireless router
Shut down your computer, unplug the cable modem and the switch. Connect all three - computer to switch, switch to modem. Make sure that the ethernet cable between the router and the modem is in the router uplink port and that the computer is plugged into one of the four ports that look alike. Wait 30 seconds - plug in the modem. Wait another 30 seconds, plug in the router, wait another 30 seconds and boot the computer. Open a browser and see if you have internet access. If you still don't, then try to check the browser by typing 192.168.1.1 into the address bar of the browser. That should give you the browser sign in screen. The Linksys default is to leave the user name blank and type admin for the password. That should give you access to the router so you can check the settings. If this doesn't work, document carefully what happens and post again with your results and we'll try to go from there.
Posted on Jun 08, 2009
Motorola router sb 6121 last blue light keeps blinking is this normal
I'm not sure which is the "last" blue light. Look here and see the explanation for a flashing light with the emblem that matches:
https://www.cox.com/residential/support/arris--surfboard-sb6121.html
May 12, 2018 | Motorola Computers & Internet
How do I find the bridge mode in sb6121
The Motorola Surfboard SB6121 is a cable modem only - no router included.
You must have a router - after the modem - in the network if you need router duties.
There is no bridge mode in the modem. Bridging the modem basically bypasses the routing function of the device and passes everything on to the next device in line......the router in this case.
Since this modem does not have a router built in - it is always in bridge mode.
Feb 03, 2015 | Arris Sb6121 Docsis 3.0 Cable Modem...
I cannot sign onto my motorola surfboard router site, no user names or passwords work. please help. my other laptop connects to wifi network fiine, but other one keeps asking for pin or security...
Connect to it directly using a LAN cat 5 cable, not wireless.
Log in as admin to the router, and change the wireless password to something new.
Disconnect the cable then try connecting from each laptop by wireless, when it prompts for password enter the new password.
Dec 14, 2013 | Arris SURFboard Gateway SBG6580 DOCSIS 3.0...
SURFboard DOCSIS 3.0 boosting the wifi signal
The SB6121 doesn't have WiFi, but I used a wifi extender (~$40-$80) to boost the wifi signal of my current wireless router that's attached to the SB6121.
Sep 20, 2013 | Arris SB6121 SURFboard DOCSIS 3.0 eXtreme...
FLASHING AMBER LINK IDICATOR LIGHT ON MY SB6121 MODEM
The SB6121 link light uses color to indicate the connection speed. Blinking means data transfer is taking place. Blue means that it's a 1000Base-T (High-speed Gigabit Ethernet). Amber means it's an older ethernet device. 100Base-T or 10Base-T Ethernet connection.
Nov 06, 2012 | Arris SB6121 SURFboard DOCSIS 3.0 eXtreme...
The wireless connection is not working. The only network that shows up is lynksis wich has a waek connection and asks for a password that i have neever had to use before, so i dont know what the password...
Unfortunately the Motorola SB5100 SURFboard is not a wireless device. The Linksys you are trying to connect to is most likely someone in your area and they have it password protected, which is why it is asking for a password.
In order to setup Wireless you will need to invest in a Linksys, Netgear, D-Link, or some other Wireless Router. They can be found at any computer store.
Once you have the wireless router you can connect an Ethernet cable from the Motorola SB5100 SURFboard to the Wireless Router. From there follow the instructions for the Wireless Router you purchased to set it up and secure it.
If this helps or solves the issue, please rate it and give a testimonial for my response.
Thank You,
Brandon
Dec 22, 2010 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
Trying to get my ps3 connected so i can get online
You need to disable the UPnP function on the Belkin router. Log into the router(192.168.2.1), and look under System Settings. If you haven't changed the password on the router, the default password is blank, i.e., no password.
Jun 08, 2009 | Arris SURFboard SB5101 Cable Modem
Please rate.
Mar 23, 2009 | Arris SURFboard SB4220 Modem
Arris SB6121 SURFboard DOCSIS 3.0 eXtreme Broadband Cable Modem (612572180136) Logo
551 people viewed this question
Top Arris Computers & Internet Experts
bobkoure
Level 1 Expert
Jerry
Jerry
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
