Question about Microwave Ovens
I have Samsung over the range microwave model #SMH9151B, I purchased a year and a half ago, went to use it made a pop sound and everything is blank and dead will not do anything, does anyone have a suggestion?
jsrock516
  • 5911 Answers
SOURCE: MAYTAG mmv4205aab OVER THE RANGE MICROWAVE
It could easily be a bad line fuse and/or line filter. To access you will need to unplug the unit and remove the outside case. Inside the unit, where the A/C power cord comes in, there should be a small circuit card (part #237068) located somewhere with a fuse mounted on it. This is your input line filter board with line fuse. Replace the fuse, first and see if this fixes your problem. This is a 20amp appliance fuse that you can purchase at any hardware store. Make sure you place the cover back on the unit BEFORE you plug it in. It is not safe to have this area of the microwave exposed with power applied. High potentials in the 4,000 volt range are present! If the fuse does not correct your problem, the circuit card runs about $26.00. Good luck and hope this fixes your problem.
Posted on Aug 04, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: My GE Built-in microwave model JVM1870 appears to have died
A microwave can be dead for many reasons.
It may be the fuse, which is usually located behind the grille, on the floor of the oven behind the control panel, between the door switches, or on the filter board near where the cord comes into the unit.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking TCOs or thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
If the cavity thermostat needs to be checked or replaced you'll need to pull the oven from the wall.
You can download GE owner's manuals and installation instructions here to make that easier.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Dec 17, 2008
dmftrucker
  • 1922 Answers
SOURCE: My LG microwave went completely dead. I is only 3
under the outer cover,its either a 10-15-or 20 amp ceramic safety fuse avail at most hardware stores, the amp rating is on the side of the fuse, if the new one blows then either the H.V. diode/capacitor or the magnetron can be suspects
Posted on Oct 05, 2009
heatman101
  • 43501 Answers
SOURCE: ge over the renge microwave runs but no heat
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
hjdhjd
Posted on Sep 30, 2010
kel1guy2002
  • 3740 Answers
SOURCE: We bought a Samsung over the range Microwave less
Hi and welcome to FixYa, I am Kelly.
I beleive that your Microwave has a 1 year warranty. Since you did not provide a model number I can not verify that. Having said that you should visit the Samsung website and make sure your Microwave is registered using the link below before calling for warranty service other wise they will refuse the warranty service request.
REGISTRATION
http://www.samsung.com/us/support/account/regist
SERVICE LOCATOR
and then use this link to find out who can service it for you.
http://www.samsung.com/us/support/service/location
You can call them at: 1-800-726-7864 and find out also. (
I think the internal fuse has failed but.. if it is infact "in warranty" Let the service provider do it for you for free. I did in home warranty service for 40 years and you have to go through the hassle of making the call and getting an authorization number.
If it is not in warranty I am certain that Sears can service it for you.
Thanks for choosing FixYa,
Kelly
Posted on Mar 25, 2011
Microwave door doesn't close properly
The service manual for model SMH9151B is here.
You can order Samsung parts by part number from the Pros here.
<- Let me know if I can help further.
Jan 20, 2014 | Samsung SMH9151 Microwave Oven
SE ERROR
I am not sure, ask the dealer
Mar 12, 2013 | Microwave Ovens
Kenmore 401.80082700 Over the range microwave just stopped working. WILL DO NOTHING! Is anyone home out there?
I would go ahead and replace the microwave oven the cost to repair will be higher than what you are thinking of getting.
Mar 23, 2012 | Kenmore Microwave Ovens
The display panel readout has a 5E or possibly a SE on the dislplay constantly
SE error means you have a shorted membrane keypad.
You have a shorting membrane keypad. If and when an oven is coming on or doing anything by itself, this is very dangerous and can result in a fire.
So until it is repaired, please leave it unplugged or leave the door open when it's not in use, and of course one should never leave a microwave unattended while cooking.
We would need the model number in order to provide you with free assistance.
It will be one of these:
SMH9151B
SMH9151B/XAA
SMH9151B/XAC
SMH9151BE
SMH9151BE/XAA
SMH9151S
SMH9151S/XAA
SMH9151ST
SMH9151ST/XAA
SMH9151ST/XAC
SMH9151STE
SMH9151STE/XAA
SMH9151W
SMH9151W/XAA
SMH9151W/XAC
It is usually found on a tag located inside the cooking cavity or around the door frame or controller frame.
Since FixYa is still not notifying us when you respond to clarification requests, you will have to post a new help request with your model number and symptoms / questions, or you may contact us here for this free assistance.
In some cases, it is a simple do it yourself repair.
Sep 18, 2011 | Samsung SMH9151 Microwave Oven
SE error on Samsung SMH9151B. Where so I find the assembly part to order?
"SE" error means you have a shorted membrane keypad.
The full model number from the tag on the oven should be one of these:
SMH9151B/XAA (service manual)
SMH9151B/XAC (service manual)
SMH9151BE/XAA (service manual)
I've included the service manual link for each one for your convenience. They'll help you with disassembly and in getting part numbers.
You can order parts by entering part numbers or your full model number from the tag on the oven here.
There are three ways you can fix this, with the last probably being the best:
1. Replace the membrane keypad ("switch membrane"). The cheapest way but the hardest. If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved. It's here.
2. Replace the control panel frame assembly ("assy control panel"), which comes with a new keypad on it already. Pretty easy, not expensive.
3. Replace the entire controller ("assy control box"). Very easy, and usually not much more than option 2.
No matter which option you prefer, at our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Some connectors on the relays may have a lock:
May 23, 2011 | Microwave Ovens
We bought a Samsung over the range Microwave less than 6 months ago. Today it died. We went through the troubleshooting and it appears to be the microwave. Where is a service provider in Madison, Wi? Can...
REGISTRATION
SERVICE LOCATOR
Kelly
Mar 25, 2011 | Samsung 1.8 Cu. Ft. Over-the-Range...
Microwave keypad does not respond and screen reads SE
The exact part you need will depend on the model number, which will be one of these:
SMH9151B SMH9151B/XAA SMH9151B/XAC SMH9151BE SMH9151BE/XAA SMH9151S SMH9151S/XAA SMH9151ST SMH9151ST/XAA SMH9151ST/XAC SMH9151STE SMH9151STE/XAA SMH9151W SMH9151W/XAA SMH9151W/XAC SMH9151WE SMH9151WE/XAA.
On some models, you can just order a new membrane keypad and replace it. It's cheap, but a lot of work.
On other models,
the membrane keypad is not available as a separate part, so you would have to order the control panel frame assembly which comes with a new keypad.
In this case, you simply move your circuit board into the new frame. That is a simple do-it-yourself job, but it costs more.
Feel free to contact me directly (and please remind me of your full model number) for more information & help and a free estimate for us to do it for you.
Aug 20, 2010 | Samsung SMH9151 Microwave Oven
Loud pop and microwave doesn't heat anymore
I have a GE Profile Spacemaker model JVM3670WF001, purchased I think in 2003. Pop sound, no Heat. Light goes on, carousel goes around,
Repair or new microwave
Jun 03, 2009 | GE Profile Spacemaker Over-the-Range...
Ge profile spacemaker over range microwave not heating
It was probably the Magnatron tube that went out , they are normally replaced only under warr. due to the cost to repair , the part is roughly 200.00 and labor ranges from 100-200. I guess it all depends on what it is worth to you , you can pick a decent brand new one up for about 200. Hope that helped you out. Phil
Dec 30, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave will not cook
Sounds like the magnetron has failed. There are some high voltage circuits that feed the magnetron and you can potentially get hurt if you don't know what you are doing. Would recommend you have it serviced by a professional if you want it fixed, otherwise look for a new one since the cost of repair can come close to the price of a new microwave oven.
Oct 27, 2008 | GE JE2160 Microwave Oven
Microwave Ovens Logo
37 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
