Question about Samsung DVD-V5500 DVD Player/VCR
Dvd/Vcr dead Hi there, The model is a bit diffirent from this one. It is the v 5600 combo. I've got the player about 2 months. From day one it is dead. i can hear the video head spinning and that's it. Some tech guy told me it is a faulty under carrage. I tried to play a video tape but only took the cassette as far as it go down, just before the tape itself is extracted to the heads ands then it stops and dead once more. What seems to be the problem. I tried to take it back to the supplier but they won't replace it. They will send it in for repairs and they will cover 30% of the costs and i must pay the balance. What can i do? Please help. Thank you Zavora
  • Gerhard Hefer Jul 01, 2007
    Hi there, thank you for the reply. I took it to the store where i bought the player. They told me it is more that 14 days it's out of there warrenty. They also told me who the service agent is for Samsung. I took it to that agent and were told what the problem is and that i must pay for that part because that part it is not under warrenty. But the player is brand new. It is not even 2 months old. I've sent a fax to Samsung headoffice in Johannesburg and up to dated i haven't had a reply or any form of contact from them. I can't complain about their service because there is no service. Best wishes
    zavora
If this player was purchased NEW within the last 12mnths, then this unit is still under Samsung's factory warranty. In this case, it should only be taken to a Samsung Authorised service agent for FREE warranty repair. Contact Samsung, for you nearest approved agent.
Posted on Jul 01, 2007
SOURCE:
How do i record using my sharp DV-RW360
Hi.Here is a site that will help you:-
Free Sharp DVRW360H DVD VCR Combo User Manual ...tv.manualsonline.com/manuals/mfg/sharp/dvrw360h.htmlDownload a free copy of the Sharp DVRW360H DVD VCR Combo User Manual UserManual.
May 08, 2012 | Sharp DV-RW340U DVD Recorder/VCR
My DVD/VHS combo remote control no longer activates the unit. I have replaced the batteries (2 times). What should I do next?
Good day. You might need to purchase another remote control so that you can access your dvd / vhs combo. I'm afraid that the remote is already broken due to normal use. You can also try to have a technician to check it for you but i suggest you bring it to a samsung authorized service center. Hope this give you a bit of help. Have a great day.
May 24, 2011 | Samsung DVD-V4600 DVD Player/VCR
I think the fuse has blown. model number DVC850C 120V Sylvania DVD/VCR combo
HI,
If it totally dead, the fuse is usually the culprit. Just get replaced.
Jan 24, 2011 | Sylvania 6727DE 27 in. TV/VCR/DVD Combo
I have URC3220 remote and a Magnavox TV How do I program it?
PLease follow the steps below
1.Turn on a desired device (e.g.,VCR or DVD player) and, if
applicable, insert media (e.g., cassette or disc).
2. On the remote control, press a device key once (i.e., DVD/VCR,
CBL/SAT,or TV).
NOTE: To program control of a VCR, PVR (or DVR),TV/VCR Combo,
or TV/VCR/DVD Player Combo press DVD/VCR once.After programming
a VCR Combo device, you will be able to control channel selection,
volume, and VCR functions.
NOTE: To program control of a DVD Player,DVD Player/VCR
Combo, or TV/DVD Player Combo, press DVD/VCR once.After programming
a DVD Combo device, you will be able to control channel
selection, volume, and DVD functions.
NOTE: To program control of a Cable Box, Cable Box/PVR (or DVR)
Combo, Satellite Receiver, or a Satellite Receiver/PVR (or DVR)
Combo, press CBL/SAT once.
3. Press and hold SET until the LED (red light) blinks twice,
then release SET.
4. Use the Manufacturer’s Codes to locate the type of device and brand name and then enter
the first four-digit code for your device. If performed correctly,
the LED will blink twice.
5. Aim the remote control at the device and press POWER
once.The device should turn off. If it does not, repeat
steps 2 through 5, trying each code for your brand until
you find one that works.
6.You are set
thanx
Jul 24, 2010 | One For All URC4110 Remote Control
Hello. I have a model # URC-4640Boo and am trying to set it up to work an a Sony dvd-vcr combo model # SLV-D300P and can't seem to find out how. Can you help me?
Configuring codes:
1.Turn on a desired device (VCR or DVD player)
CBL/SAT or TV).
NOTE: To program control of a VCR, PVR (or DVR),TV/VCR Combo, or TV/VCR/DVD Player Combo press DVD/VCR once. After programming a VCR Combo device, you will be able to control channel selection,volume, and VCR functions.
Combo, or TV/DVD Player Combo, press DVD/VCR once. After programming a DVD Combo device, you will be able to control channel selection, volume, and DVD functions.
then release SET.
4. Use the Manufacturer’s Codes to locate the type of device and brand name and then enter the first four-digit code for your device. If performed correctly,
5. Aim the remote control at the device and press POWER once. The device should turn off. If it does not, repeat steps 2 to 5, trying each code for your brand until you find one that works. If it still doesn’t work, try Searching For Your Code on next page
Auto Code Scan:
1.On the remote control, press TV once.
2. Press and hold SET until the LED (red light) blinks twice, then release SET.
3. Enter 9 - 9 - 1.The LED will blink twice.
4. Aim the remote control at the TV and slowly press POWER button.Stop when the TV turns off
5. To lock in the code, press and release SET.The LED will
blink twice.
6. To search for the codes of your other devices, repeat steps
1 to 5, but substitute the appropriate device key for the device you are searching for.
Thanx
Jul 17, 2010 | One For All URC-4605 Remote Control
I have a sv2000
I`ve just downloaded these
VCR DVD Combo
Apex Digital 1061 VCR DVD Combo Go Video 0744 0715 VCR DVD Combo Hitachi 0000 VCR DVD Combo Panasonic 1762 VCR DVD Combo RCA 0060 VCR DVD Combo Samsung 1075 0820 VCR DVD Combo Sanyo 0104 VCR DVD Combo Sony 0864 VCR DVD Combo Sylvania 0675 0000 VCR DVD Combo Symphonic 0675 0000 VCR DVD Combo Toshiba 0503 This is the website http://www.ofausa.com/en/list_codes.php?db_value=expert4&remote_choice=URC 4021
And try this link as well http://www.ofausa.com/en/remote.php?type=URC 4021
Hope this is helpful, Ian
Aug 10, 2009 | Symphonic WV806 DVD Player/VCR
I need a code for a sony remote for a maganasonic dvd player
You did not specify if is tv, dvd, vcr
try:
SONY DVD PAYER: 0533, 1533, 0864, 1033.
SONY DVD PLAYER/VCR COMBO: 0864.
SONY TV:0000, 1100, 0810
SONY TV/VCR COMBOS: 0000, 1232
MAGNASONIC TV/VCR COMBO: 1278
MAGNASONIC VCR:1278
SONY VCR: 0035, 0032, 0033, 0000, 1232, 0636
Jan 26, 2009 | One For All URC-4330 Remote Control
Zenith XBR411 DVD Recorder/VCR Combo Problem
I have the XBR616 zenith combo.
If your dead set on initializing your dvds, I can try to
do one in my dvd player to see if it works, then send it back to you. I can't guarantee anything, my player is a bit fussy, but I don't mind helping you.
If so, let me know
Oct 28, 2008 | Zenith XBR411 DVD Recorder/VCR
Multi Zone code Samsung 5600 DVD VCR Combo
Try this site:
http://www.videohelp.com/dvdhacks/samsung-dvd-v5600/7031#26074
Particularly the entries from:
Region code hack posted by Anthony Green, September 10 2006:
And
Region code hack posted by ZoidsGodzilla, November 22 2006:
Good luck
Jan 01, 2008 | Samsung DVD-V4600 DVD Player/VCR
Samsung DVD-V5500 DVD Player/VCR Logo
54 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
