Question about Food Mixers
Beaters for Ge 350 watt stand mixer model 106602
Beaters for stand mixer model 106602
  • 274 Answers
SOURCE: Replacement beaters for hand mixer
Black and Decker now has several store outlets all over the country. They are even online. You can order directly from them. 1-800-544-6986
Posted on Jul 15, 2007
SOURCE: Can the Kitchen aid accessories fit the Wolfgang puck stand mixer
If you happen to have a friendly toolmaker with a small metal lathe it should not be too difficult to modify KITCHEN AID accessories that fit on to the front powwer outlet. However Puck Stand Mixer accessories are occasionaly offered on the Web. Meat grinders are very common and original Puck pasta maker have also been seen. Get searchin'!
Posted on Dec 22, 2008
SOURCE: I need replacement beaters for an old GE hand mixer.
I bought an old GM mixer no. 30M47 with no beaters yesterday at the Salvation Army store. The beaters I have for a newish (ugly) GE hand held beater fit perfectly. I suggest taking your old beater to a store that sells new GE handheld beaters and seeing if the new beaters fit. If anyone reads this and wants me to look up the number of the new ugly beater for them, please say so before I take it to the Salvation Army.. : )
Posted on Nov 26, 2009
hslincoln
  • 235 Answers
SOURCE: Have a kitchenaid artesian mixer need to adjust
Hi KELLYSERMAN, this should be pretty easy to do by yourself the instructions for adjusting your beater to bowl clearance is in your Owners Manual. I you don’t have the original manual you can easily download a PDF version of your Owners Manual from the KA website: (http://www.kitchenaid.com/flash.cmd?/#/page/home).
Click on Customer Care>Locate Manuals& Guides> and enter the 6 character model number, in your case KSM150 and select the file listed for your model that appears under Owners Manuals (66): KSM150PSER1 (732.33KB) and save that file to your PC. Turn to Page 14 and you will find the instructions for adjusting the mixer head height. I have extracted the instructions below:
Beater to Bowl Clearance
Your mixer is adjusted at the factory so that the flat beater just clears the bottom of the bowl. If for any reason, the flat beater hits the bottom of the bowl or is too far away from the bowl, clearance
Tilt-Head models
• Unplug mixer.
• Lift motor head.
• Turn screw (A) SLIGHTLY counter clockwise (left) to raise flat beater or clockwise (right) to lower flat beater.
• Make adjustment with flat beater, so it just clears surface of bowl.
If you over adjust the screw, the bowl lock lever may not lock into place.
I hope this helps! – Howard, Burke, VA
If this solution has helped you, please rate it, thanks! - hslincoln
Posted on Dec 07, 2009
SOURCE: Replacement Beaters for GE Hand Mixer
I realize this is way way late, but I found this page trying to find this information myself. I found the answer so I wanted to solve this problem for the next person who is looking. I ended up having to contact Hamilton Beach, at 877-539-0225, to order this part. The GE people (www.gehousewares.com) only do the newer stuff that is still covered under warrantee. It took a number of calls and e-mails to get this information, but it finally got this info out of them. I now have my beaters.
Posted on Mar 02, 2010
Kitchenaid stand mixer 5SSWH 325 watts. How do I adjust the bowl height? Beater is too far from bottom of bowl. Thanks! Cas
There is a screw at the bottom of the motor head (flat head) you usually can't see it because of the top rim of the mixing bowl. hard to see and hard to reach, it may also be hard to turn due to "gunk" from mixing stuff (egg butter flour sugar) turn the screw counter clockwise to lower the motor head clockwise to raise it, you may also have the wrong size beater, it is not an uncommon problem, if you are the original owner and you have the original beater it should fix your problem with the adjusting screw, however I am not clear as to your model a 5SSWH would actually be a K5SSWH, which stands for kitchenaid 5 quart solid state white mixer, if this is your model number and you have the correct beater size then the adjusting screw will work to lower the head down, adjust it down using the stir or slowest speed just untill you can hear the beater "Ding" against the bottom of the bowl, then back it off a quarter turn to adjust properly. Hope this helps, let us know
Apr 17, 2013 | KitchenAid K5SS Heavy Duty Commercial...
Can't get my beater off my KitchenAid 350 Watts mixer
The button does not retract, a bit of CRC may help combined with a lot of wriggling and grunting. Flour gets in there over time and builds up and makes the paddle tight. Rasp it out a bit in the hole, try not to remove metal, you just want to remove the buildup. If you had a bottle brush that fitted and cleaned it in there each time it will never happen again. Look how long it has taken so far.
Dec 25, 2012 | KitchenAid KSM50PR Professional Series...
I have a Kitchenaid 550 watt 6 qt. stand mixer model #KB26GIXER. I tried to use it this morning and couldn't get the beater blade to lock in place. Isn't there supposed to be a spring and washer...
There is only one pin on the beater shaft to hold the beater in place.
There is no spring or washer on the shaft.
To Attach Flat Beater,Wire Whip, or Spiral Dough Hook, simply
1. Slip flat beater on beater shaft.
2. Turn beater to right, hooking beater over the pin on shaft.
Jun 25, 2011 | KitchenAid KP2671 Professional 6 Series...
New beaters
go to this site and you can order on line or by phone.
www.a1service.com/toastmaster.htm - 52k
please rate my answer. thanks
Feb 06, 2009 | Toastmaster 350 Watts TMSM350 Stand Mixer
Lost beaters
Either call or contact the company by phone and ask for assistance in replacement parts.
Jan 05, 2009 | Betty Crocker 340 Watts BCF1250 Stand...
Food Mixers Logo
50 people viewed this question
Top Food Mixers Experts
eyecam
Are you a Food Mixer Expert? Answer questions, earn points and help others
