Question about E-Machines T2742 PC Desktop
My emachine is stuck cycling at start up
My husband was trying to back up and restore. I'm not sure if it was cut off too soon. But now the computer is stuck cycling at start up. First the Windows(we have Vista) error recovery screen comes up. It doesn't matter which mode is chosen; it goes to a screen that says- Configuring updates: stage 3 of 3 0% complete. Do not turn off your computer. Eventually it goes to 94% complete then goes to a screen saying Shutting Down. The screen goes blank however the power button is still lit up. It then blinks a few times and goes back to the Configuring updates:stage 3 of 3 0%. It does this over and over. We have tried unplugging it as well. We're not sure if it's trashed or fixable.
  • 1 more comment
  • publicmontes Jan 10, 2009
    Oops, my emachinein the problem above is a T5224 PC desktop model not a T2742.
    Wow, thanks for the quick responses. When safe mode is selected is goes to the Loading Windows Files screen and works for a few seconds then "please wait..." comes up at the bottom of the screen. There is a whirring sound and the screen goes blank. THen the windows symbol and then back to the configuring updates screen. I tried F8 but nothing happens. It does not respond. How can I get past that screen?
  • ehm001 Feb 19, 2009
    My T5224 will not stop cycling from Configuring updates: 3 out 3 93%updated. I've tried all the suggestions and nothing seems to work . Does anyone else have another solution to this problem? I would really appreciate it.
    Brigadier General:
  • 5,158 Answers
No computer is trash when you are dealing with a software issue.
boot up and tap on the f8 key... when you get to that screen... choose safe mode... if it successfully boots.... go to start menu... and restart again... it should boot... if it wants to do the update let it.... if still nothing.... f8 again and choose last known good configuration
Robert
Posted on Jan 10, 2009
  • Roberta Smith
    Roberta Smith Jan 10, 2009
    you need to hit f8 as you are booting up.... i would suggest first unplugging the computer for about five minutes... plug it back in and start again
  • 158 Answers
Go to safe mode,
Open up an command window (Start > all programs > Accessories > Command) Run the following commands one by one;
net stop "Automatic Updates" del /f /s /q %windir%\SoftwareDistribution\*.* net start "Automatic Updates" wuauclt.exe /detectnow
Reboot the computer normally.
  • Prashant Bharadwaj
    Prashant Bharadwaj Jan 10, 2009
    1. net stop "Automatic Updates"
    2. del /f /s /q %windir%\SoftwareDistribution\*.*
    3. net start "Automatic Updates"
    4. wuauclt.exe /detectnow
After start up repair pc still shows black screen how can I fix it?
Are there any error messages?
Try going to safe mode:
Restart and tap F8.
Use the arrow key to highlight "Safe Mode"
Press enter.
If it boots up to safe mode just fine, do a system restore.
Start > Programs > Accessories > System Tools > System Restore
Select a restore point (a date when the computer was still working great).
Launch the restoration. Check if it works.
If no go, please drop me a line and I'll get back to you as soon as I can.
I hope this helps!
David
Feb 15, 2013 | E-Machines eMachines Desktop PC
Emachines E527 wont boot up
restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
you could select the option start at last known configuration that worked this will tell you if and what file has been corrupted or missing then you will know if its a hardware issue
then select restart if the problem still persists f8 back into safe mode you might need to select your operating system to load into safe mode
click start control panel administration tools computer management in the left panel events + to expand then system you will see all errors in right panel right click select properties this will tell
you what has occurred and the time it occurred
you might use the system restore to restore your system to an earlier time click start all programs
accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work
if the system restore fails
test your PSU or replace it if your power supply units fan is not working your PSU is faulty
one bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
test all power and data leads that attach to your hard drive IDE,SATA
the leads from your "((MOTHERBOARD TO YOUR HARD DRIVE))" make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty
computers need data and power to travel through every working device and to continue its cycle and have an end so any faulty leads will end up with a computer error even something as small as a faulty power connection or faulty fan lead can cause you problems
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail
check all electrical power input and extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working
also check the Cmos battery and computer ram modules make sure they are securely seated
on some motherboards cmos batteries are soldered in
hope this helps
Jul 26, 2012 | E-Machines emachines (emachinees) CD-ROM...
I have emachines model W3650 and want to know how to set back to factory setting.
(1) Go to start menu(2) Click on all programs(3) click on Emachine(4) click on Emachine recovery management(5) Click on restore on the bar across the top(6) click on restore to system factory default
Some emachines can be restored by pressing ALT+F10, but not sure on your model. Give it a try if you can't restore it to factory defaults using Emachine recovery management.
Feb 05, 2012 | E-Machines eMachines Desktop PC
Can't find my startup disc for my emachine, is
yes windows xp potable CD will solve it but select boot from CD ROM rather boot from floppy disk or you can use windows xp on bootable flash memory or you can restore your windows it might work
May 23, 2011 | E-Machines eMachines Desktop PC
How do i restore my emachine w3619 without a restore point or ****?
If your trying to restore your machine back to factory setting then you can follow the steps below: 1. Go to start menu 2. Click on all programs
3. Click on Emachine
4. Click on Emachine recovery management
5. Click on restore on the bar across the top
6. Click on restore to system factory default or 1. Turn OFF you computer 2. Press and Hold ALT key then tap F10 8 times immediately after you turn you computer on. Hope this information will be helpful. Thank you forusing FIXYA.
Apr 16, 2011 | eMachines W3619 PC Desktop
My husband has an e machines and has been having problems deleting certain programs and all he wants to do is restore to factory settings but he doesn't have the discs needed to do this...is there any way...
to do a system restore you would need the disks. possibly you could restore some settings but not a full restore. if it has xp and he has system restore enabled he might back up till a time the problems werent there.you would have had to have had the system restore activated befor the trouble started and it may still ahve problems there.some pc's have a backup on the hd you might try emachine support and see if this is the case here. i have fixed a few emachines just not that experienced their os.
Jul 16, 2009 | E-Machines T5082 PC Desktop
I have a emachine, and it cuts off soon as you start it up, i replace the mother and it still does the same thing
if a computer cuts off as soon as you start it up it is some times the power supply. You may have added something to your computer that when it gets loaded it pulls just enough wattage that the power supply overloads. Let's say you have a 250 watt power supply...if you computer pulls 255 watts it will overload the power supply and shut itself off. Try getting a Power supply with more wattage output.
Jul 15, 2009 | Computers & Internet
I need to restore my eMachine back to it's original state
hi there,
have you ever try to restore your windows on the date where it was good,click start,go to all programs,go to accesories,go to restore,go to system tools,go to system restore,on system restore click next,select a date where your windows run on good condition,click a date it was you can see a number much bigger on others # ,select previous date, and follow the system it will restart your windows automatically and it will find it for you.have a nice day,dont forget to rate me,thank's a lot.by the way you don't mention what windows your using anyway have try it.
May 15, 2009 | Computers & Internet
Tried to do a restore with restore disc that came with the comput
There seems to be a problem with the operating system that is being installed. This often happens if you use the restore disks that came from another computer.
Are you sure that you used the disks that came with that exact computer? Does it flash a blue screen right before restarting the cycle?
Try the restore over again and if the problem persists, you may have to either order new restore disks for your computer or buy a fresh copy of Windows XP.
Apr 11, 2009 | eMachines T3604 PC Desktop
It keeps shutting down on us
If this just started it could be that it is overheating. Make sure that the tower itself is in open air so that it can circulate enough air. If its in a computer desk that may not have enough room I would temporarily move it out of there and see it that stops the problem.
Hope this helps. Please remember to rate this information.
Thanks
Nov 15, 2008 | E-Machines eMachines Desktop PC
E-Machines T2742 PC Desktop Logo
578 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
