Question about Sunbeam Vacuums
Sunbeam water cooler/heater started smoking as soon as i plugged it in, do i throw the thing away or can i fix it?
3 Suggested Answers
bozcro
  • 867 Answers
SOURCE: I plugged this vacuum in - started it, has good
seens like beater brush belt dirty
Posted on Jul 14, 2009
ynogami21
  • 670 Answers
SOURCE: Plugged in my water cooler
hi there,
Possible reasons why it smoked are:
1. The water cooler received too much electricity than what it could handle. example it received 230V instead of 110V.
2. It got wet inside while plugged in and caused a caused a short circuit on the pc board.
Eitherway, to get it fixed.
1. The system needs to be opened so you can check the fuses, capacitors, IC's and make sure that the pc-board does not have a burn mark or any damage.
2. Check if there are swollen capacitors, burned resistors or loose IC's on the board. Check for any open wires as well.
3. Test the capacitors, the IC's and the resistors for continuity in electricity using a power tester.
4. If no continuity is detected on some of the capacitors and IC's then the pc board would have to repalced.
Otherwise you can have a local electrician visit your place so they can do all of this for you.
Hope this helps!
Posted on Jun 12, 2011
Sunbeam steam mop is not heating the water
Call Sunbeam Customer Support .... 1-866-726-1150
Regards,
Dennis
Aug 30, 2014 | Vacuums
Hi, I have a older model Sunbeam water cooler that hasn't been used for a while ..Need to know how to clean and sanitize it? got any ideas
Vinegar might help. Run a bunch through the water cooler and it can help clean out the unit (and will give you some disinfection as well) without damaging it. I have used vinegar in my coffee pots with much success over the years. Once you are done, you will want to run a LOT of water through it to get the vinegar taste out of the system, though. If you are not a fan of the idea of vinegar in your water cooler, you can try coffee-pot cleaner ... it is more expensive, but is designed for the same basic use.
Jun 07, 2011 | Vacuums
When I plug in my vaccum the power light turns on, but i get no power to the machine??? I changed bags and filters and still nothing??? Can you help?
That light wire is attached to part of the wiring that is just a piece attached to the main wire coming from the switch. Your bags and filters have nothing to do with powering the machine. You may have a bad switch or there may be a ground wire off the motor. I had that happen to a very large Dirt Devil and I had to take the entire machine apart to get to the motor. If you have to do that, take your time, lay everything out in the order you remove it as you take it off, make drawings of things as you go, and put it back together in reverse. If it's a switch you will have to go to a parts store to see if they either have it or they may be able to order it. But, here's the deal these days. Everything has been for some time, "throw away". That means if something goes wrong you chunk it and go buy another one. I grew up with family that didn't have the money to just go buy things like that. We either took it to what used to be known as "repair shops". Those were places where people knew how to repair things and then you went and picked them up and paid the people for their work. I'm making a joke kinda, but to make my point. The way the economy is and it may get alot worse before it gets worse yet again, Americans who grew up just throwing things away when they broke, will have to learn to do the unspeakable....FIX it! Hopefully America will by need bring back "repair shops" where you will take something you don't know how to fix and they will do it for you. Those kinds of places employed thousands of people and gave people careers and businesses with good incomes. Don't throw it away, repair it. And there is a difference between "fixing" something and "repairing" something. Fixing means just getting something running for awhile, but it usually means a temporary thing. A repair means the thing is brought back to the way it was when it left the factory. It may not be as shinny, but it will last as long if not longer when "repaired".
Mar 08, 2010 | Vacuums
I have a Kirby G7 and it will run on the low speed setting. When i switch to the high speed it starts to spark and smoke near the back of the motor near the windings. Do i have a motor going bad or is...
It's probably doing that on low speed too, you just aren't noticing. What you'll have to do is get to the motor. Look at the armature and see if it's scared, missing an pieces, scratched up.. if so, then your motor is shot, throw it away.. If not, if the armature is clean, as in no physical damage, then all that is needed is to replace the carbon brushes and everything should be ok
Oct 27, 2009 | Vacuums
Shark professional model 505.
It sounds like the themostat inside the unit is broken. The only solution to fix the unit is to send it to the manufacturer for repair.
I'm unsure of the cost for the repair but it might be cheaper if the unit is older to throw it away and buy a new steamer.
Sep 02, 2008 | Euro-Pro Shark SC-505 Handheld Steam...
Motor problem
I had to throw the machine away before it burned my house down. There is no way to fix it; had to replace it.
May 22, 2008 | Bissell 1770 Quicksteamer II Upright...
I got an new durabarnd canister with retractable cord vacuum cleaner 1 month back.One day when I was usinfg it, it just gave me a chirp sound and went off.Since then When I try to plug it in, it doest not...
buy a new one u tight **** we now live in a throw away world not many things these days are fixable things are exspecially designed so me throw them =away and go buy a new one
Apr 04, 2008 | Vacuums
Wont heat up
I know that Karchers steam cleaners have had issues with the thermal overload. I have repaired Karcher machines that got turned on with no to little water in the tank and it would heat up really fast and trip the thermal overload. The thermal overload is to reset it self when it cools down but the problem has been the thermal overloads get stuck and dont reset. When they stick, they will give the same signs you have said. In those cases the thermal overload has needed replaced. The thermal overload did its job to trip, but it fails when reseting. I understand you don't want to throw more money into it, but that is the only thing you can do. You can get the part and do it your self, but they are tricky machines to get into and you dont want to break something trying to get in. Hope this helped.
Mar 25, 2008 | Karcher DE4002 Steam Vacuum
Vacuums Logo
96 people viewed this question
Top Sunbeam Vacuums Experts
Are you a Sunbeam Vacuum Expert? Answer questions, earn points and help others
