Question about Dishwashers
AEG favorit sensorlogic F3A instruction manual
SOURCE: My AEG favorit sensorlogic turbo
hey
I just had the same issue done everything you say above with no joy. i then emptied the water that was in the dishwasher that the filter goes into and its now fine.
good luck
Posted on Jul 03, 2008
SOURCE: AEG Favorit 50730 Sensorlogic Dishwasher:
get a new dishwasher
Posted on Nov 06, 2008
SOURCE: AEG Favorit Sensorlogic turbodry
I need to know manufactures year of AEG favorit 80860
Posted on Oct 29, 2009
SOURCE: My AEG dishwasher - Favorit no. 60870 sensorlogic
I don't have the answer - but mine has been doing this too. There's now a metalic/electical smell that has me worried so I've resorted to a basin of water and fairy liquid! Did you solve your problem?
Posted on Jan 24, 2010
SOURCE: Our AEG Favorit Sensorlogic Turbodryis
i have the same problem, i have a machine that is 2005 model and it does not heat the water or dry in the end
Posted on Oct 20, 2010
Our AEG Favorit Sensorlogic dishwasher has had no power to it
Open the lower front panel and locate where the water inlet hose is connected. Shut the water off under the sink, disconnect the hose at the water inlet solenoid, then put the loose end into a bowl or pan and turn the under-sink valve on slowly. Do you get water flowing from the hose? If so, then check the solenoid water inlet valve for damage. If the coil is ok, the valve part may be stuck closed. It should make a firm 'click' when the timer is set to start the machine (leave the hose loose). If it doesn't click, the coil may be bad, the valve may be stuck, or the timer is not sending 115 volts to the solenoid. Try a new valve first. If still no click, you may need the professional service. Good luck!
Mar 26, 2010 | AEG 23 in. Favorit 50750Vi Built-in...
My AEG Favorit Sensorlogic Turbodry dishwasher is making 3 short continuous beeps which I understand means the leak prevention system has kicked in. Is there something I can do to reset or must I call a...
Open the left metal panel, if the white plastic tank is black at the bottom or is not clean: remove it, open it, clean it (make sure the water flows through properly) and put it back in.
Mar 04, 2010 | AEG 24 in. Favorit 80860iW Built-in...
My AEG dishwasher - Favorit no. 60870 sensorlogic - is making a strange noise when on - what should I do?
Nov 09, 2009 | AEG 24 in. Favorit 60870M Free-standing...
Jul 31, 2009 | Dishwashers
AEG lavamat 6955 sensorlogic, was showing F2,nowF3
Waited half hour; on start up F3 had cleared..pump overheat? Suspect sticky pump bearing..new pump.
Jun 10, 2009 | AEG Lavamat 88840 Front Load Washer
Hello, we have the AEG 60820 Sensorlogic dishwasher but no instruction manual. Please could you tell us when we should use the ''Automatic'' button and the ''Energy saving'' button? And what the advantages...
With the auto setting, the machine detrmines the time based on the load. With energy saving, you force the machine to use the least amount of water and heat, usually best for cups and glasses.
Apr 26, 2009 | AEG 24 in. Favorit 60820W Free-standing...
DISHWASHER AEG 80860
Just fixed a similar problem on an AEG F3A by following other advice on this site. Simply tip the machine forwards on to its door (best empty it of crockery first!!!).and then put it upright again when water has stopped dripping out of it. You wil get quite a bit of water on your floor which I reduced by pumping the water out of the salt resevoir first - but if you don't have a pump just have several towels handy
Aug 23, 2008 | AEG 24 in. Favorit 40850 Free-standing...
Dishwashers Logo
73 people viewed this question
Top Dishwashers Experts
Owen Barnes
