Question about LG Televison & Video
6hd hi fi stereo dvd recorder vcr player combi owners manual page 13
What are items 9 and 10
SOURCE: Accurian DVD Recorder/Hi-Fi VCR combo
You need to finalize the disc u recorded in order to play on other dvd's. press setup, press disc, press finalize then press yes. Finalization will start, this may take some time depending on the amount to be finalized. Be patient. Good luck.
P.S If u have the manual those steps are on page's 36-37.
Posted on Jan 04, 2008
early1234
  • 871 Answers
SOURCE: Magnavox #MWR20V6 DVD Recorder/4head HI FI Stereo VCR
VCR problem... replace the idler.
IDLER - symptoms:
  1. Eats tapes. Capstan pulls tape off the supply reel but the takeup side can't reel it in.
  2. Won't rewind, sometimes intermittent.
  3. Shuts off sometimes.
  4. In early failure stages, while playing, the take-up reel inside the cassette may behave erratically.
  5. When you press stop, the guide rollers retract without pulling in the tape.
THE PROBLEM - worn idler. Older VCRs have an idler that uses a rubber tire. Over the years, a slow chemical reaction occurs on the surface of the tire. This process results in a glazed surface, causing loss of traction. With a dummie cartridge you can see that the idler does engage the reel table, but if you grab the reel table with your hand, you find there is little or no torque. Without traction, the tire only slips against the reel table. If you push the idler into the reel table with your finger, it will work, but only as long as you keep your finger on it. Often all you need to do is replace the tire.
The tire can be easily removed. It's not glued or permanently fastened in any way. A small flatblade screw driver is a big help in removing the old one. In fact, you can turn it inside out and remount it that way. But since there are no treads on the inside wall and the fact the rubber has a lot of years of deterioration on it, you will be lucky to get a few months out of it. But at least you can still use your VCR in the meantime.
Newer VCRs have a gear instead of a tire. Although gears are much more reliable they still have problems. Usually becoming warped or loosing tension. The plastic retaining cap over the spring sometimes cracks. Without sufficient tension, the idler tends to get caught between the reels. This can be easily seen if you have a dummie cartridge. Gear driven idlers are one piece, so replacement involves the entire idler
hope you have grasped what is said here.
thanks for using fixya
Posted on Mar 25, 2008
SOURCE: jvc dvd/vcr. combi. hr-xv20
I have the Danish version, available online at http://www.jvc.dk/files/instruction_manual/lpt0820-007c.pdf
Try looking at the local JVC site under "support" and see if it is available. Then you will get it in your own language.
Posted on Jun 16, 2008
leethedeuce
  • 4472 Answers
SOURCE: I can't locate my owners
http://www.funai-corp.com/6pdf/om/ZV420MW8.pdf
There you go that should be the manual you are looking for. If so I would hope you would take a second and rate this FixYa.
Thanks and Enjoy,
Lee
Posted on Jun 29, 2008
quang123
  • 107 Answers
SOURCE: Samsung DVD-VR375 says "load" but tray for DVD/VCR won't open
I think you have problem in DVD deck assembly the owner manual won't help you if still under warranty bring back to Samsung if out of warranty you can buy the DVD deck from Samsung and replace by yourself
Let me know if you need part number for the DVD deck
Posted on Dec 09, 2008
Can I transfer video tapes onto CD's
A lot depends on what type of video tape you use and where do you want to play the DVDs (CDs are for audio recording only). If tape is compact VHS then you can buy a simple DVD Recorder VHS VCR combo player and transfer across easily provided you have the compact VHS cassette module.
http://www.gumtree.com.au/s-ad/reservoir/tv-dvd-players/lg-v271-vcr-dvd-player-combo-recorder-6-head-hi-fi-stereo/1073556241
For other type of video camera tapes you will have to try other methods like connect camera with tape to a DVD recorder and directly burn the DVDs. You can buy attachments and software for PC but I have found these very cumbersome to work with.
Mar 16, 2015 | Video Cameras
I got a magnavox dvd recorder and 4 head hi-fi stereo vcr and im having trouble with hooking it up to my cable box how do i record shows on my recorder without switching inputs on my tv because i switch...
Don't hook the DVD/VCR recorder through ur cable box.Hook the DVD/VCR recorder through ur tv only it should work find.This way each units have it own direct functions to the tv.U recording the shows from the tv not the cable box ok.
Nov 15, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Hi Can you tell me if i can put a vhs home vidio in to this combi unit, and record on to a blank DVD. Also can i still get a manuel for this model. Many thanks. Regards Jeff
Hi Jeff,
No you can't i'm affraid you can only record using the VHS the DVD is a player only. A manual does exist for it, well it's listed as a Toshiba SD-V392 SU. I do have a PDF copy or you can download it from http://safemanuals.com/user-guide-instructions-owner-manual/TOSHIBA/SD-V392SU-_E you just need to click this link then click on the PDF icon (file size is 4.6 meg) just for info the PDF file is virus free i've checked. Regards, James.
Apr 20, 2010 | Toshiba SD-V392 DVD Player/VCR
What type of disc do i use to record
Any DVD-R or DVD-RW will work on this system. There genrally sold in 50's but you could buy indivduals from like a office depo,Best buy, amazon.com.. Good luck
Sep 30, 2009 | Sylvania DVD-R/-RW Recorder and VHS Hi-Fi...
I just bought a DVD/VHS VIDEO player/recorder from bestbuy but it was a floor model, model no. ns-1drvcr,serial no.702026722. Can you send me a owners manual?
The manual can be found on this page in pdf format:
http://www.insignia-products.com/pc-237-31-insignia-multiformat-dvd-r-rwrrw-recorderhi-fi-vcr-combo.aspx
Take Care,
-WN
May 05, 2008 | Televison & Video
I appear to have locked myself out of my daewoo vcr/dvd combi any ideas?
What's the model number & what's locked exactly, both DVD & VCR or just one?
Dec 30, 2007 | Audio Players & Recorders
What kind of dvd's can be used in this dvd player?
That will write on -R or -RW ONLY ... for +R or +RW disks, it can read but not write. You can see this on the recordable media section on this page: http://www.dealtime.com/xPF-Sanyo-Sanyo-DVD-DRW1000-Recorder-Hi-Fi-VCR-Combo
Apr 23, 2007 | Sanyo DRW-1000 DVD Recorder/VCR
Televison & Video Logo
333 people viewed this question
Computer Repairing
Computer Repairing
