Question about Canon Office Equipment & Supplies
Canon QS100 Typewriter daisywheel mis printing
When printing, incorrect letters print
  • 19 Answers
SOURCE: BROTHER ML100
Ok,there could be two possibilities ,1, The daisy wheel may not be seated in properly. Of course I assume that the print side of the daisy wheel is facing the platen and that when the typewriter is switched on the print unit makes its customary re-setting motion and that the daisy wheel spins around at the same time. if this does not happen make sure that the lock-in lever for the daisy wheel is pushed home.. I am sure that you do all these elementary things so the only other possibility is the the hammer seleniod is not fully functioning and would have to be re-placed....Good luck!
Posted on Nov 15, 2007
SOURCE: Olympia Mastertype 3 Typewriter
Be sure the pitch selection is correct. If it is set to PS when using a 10,12 or 15 pitch wheel it will select incorrect letters.
Posted on Sep 02, 2008
SOURCE: printing wrong letters and numbers
Typing wrong letters.
Please help immediately
Posted on Sep 17, 2008
  • 3594 Answers
SOURCE: Printing incorrect letters
Check the pitck selector slide switch it may be in PS this will give you that problem.
DickyO
Posted on Apr 29, 2009
SOURCE: incorrect characters printing after the third line
Geno111 doesn't know what he's talking about. Look closely at your correction tape once it has passed the daisy wheel. Does it looked roughed up a little? I just had this same error and discovered that my daisy wheel was hitting my tape when spinning and not allowing it to jump characters like it needed to. I simply put a little double sided tape on the daisy wheel cover between it and the metal tab that holds the ribbon at a certain distance, to increase the space the daisy wheel has to spin. It seems to have worked so far. If anyone has a permanent solution, or answer as to how it spins wobbly, I'd love to hear it.
Posted on May 01, 2009
Size No. of Print wheel with a largest letters
Can you post the brand of your typewriter? On the old IBM selectric typewriters the Courier 10 ball would have larger print than the Courier 12 ball. Good luck.
May 03, 2016 | Office Equipment & Supplies
Wong letters & numbers
Bbrothers says its my daisy wheel causing this problem.
Jul 26, 2008 | Brother GX-6750 Typewriter
When I push the letters, wrong characters are showing up.
This is a daisy wheel typewriter. Either:
1. The daisywheel is for a different model.
2. The daisywheel is inserted incorrectly, IE upside-down, or if it is in a cartridge the wheel is in the wrong position when the cartridge is inserted. It might have had a little stop in it to prevent this that has worn out. You might be able to move it around to the right position by aligning that stop before inserting the cartridge.
3. If you can still buy those daisywheels, get a new one... maybe Ebay.
Jan 04, 2016 | Olympia Supertype 330 Typewriter
Daisywheel doesn't print the correct letter when typed
Probably the print wheel homing pawl is broken you need atech.
DickyO
Nov 30, 2012 | Brother SX-4000 Typewriter
Letter E is malfunctioning?
If it is only the capital (E) and not the lower case (e), remove the daisywheel (print wheel) and inspect it for damage. Don't worry about the letters being out of order the machine knows what order they are. You will likely see one spoke broken off or bent to one side. If so replace the daisywheel.
If both E & e are malfunctioning, the problem is that the keyboard is malfunctioning. The keyboard is not hard to repair, but it takes well over an hour to train someone how to disassemble and put it back together again, so I cannot explain it here. Besides you will (likely) need a conductive pad to replace the pad under the E/e key.
For your sake I hope it a damaged daisywheel. Best of luck!
Ron
Jan 08, 2011 | Brother EM-430 Typewriter
When I push the letters on the keyboard, different letters or symbols are appearing. I pushed "Code" "Q" to reset, but it will not type the proper letters.
BACKGROUND - When you turn on the machine, close the top cover, or press [Code]+[Reset} (on some models) the print head moves to the side, the daisywheel spins, and the ribbon jumps up and down, that is the machine resetting its self.
If a reset does not work the reset tab may be out of alignment. If a reset does not correctly reset the daisywheel, I would
  1. Turn off the power, open the lid. On the bottom of the case there is a metal frame on the side of the frame (where the carriage goes were it homes) you will see a small metal tab pointing towards the middle of the machine. When the machine resets its self, it uses that tab as a reference.
  2. That tab can be easily bent which causes the reset to be incorrectly done. Most people can bend it by hand, DON'T use a pliers! The tab can break off completely. It does not take much pressure and it does not need to be moved very far at all. Just nudge it towards the back (or the front).
  3. Power up the typewriter, close the lid and test it. It might take a couple of tries in either direction to get it right. Be ready to turn off the power if you bent the tab too far the tab will not enter the print head correctly, and the carriage will jam. Just nudge the tab in the other direction.
CAUSES - This reset tab most often gets out of alignment by a child playing with the machine, or when a foreign object is in the machine when the print head is moving.
Dec 23, 2010 | Brother ML-100 Typewriter
The bottom of some of the capital letters is not printing correctly.
The letters on the Daisywheel have slightly curved faces to match the curvature of the paper around the platen and the hammer will contact the letters and apply pressure to the top, bottom left and right depending on where it is adjusted. Test the machine by typing Capital MWMWMW and also /////// along with the rest of the alphabet including gggyyyqqqppp. The solution may be as simple as replacing the Daisywheel (may be worn from use). If all of the letters strike more heavily on the top than the bottom, the hammer may be adjusted closer to the paper which will apply more pressure to the bottoms of the letters. Also the face of the hammer could be worn and need replacement. If the Daisywheel is in good shape, you might try adjusteing the hammer position, but it can be tricky to get perfect.
Dec 29, 2009 | Brother GX-6750 Typewriter
Types funny symbols instead of the number I
The typewriter will print the incorrect letter, or the face of the hammer if it does not spin properly to the correct position. 1. Turn the machine offf for 15 seconds and turn ON, or Depress MODE RESET(the Q key). This will rehome the Daisywheel.I If it prints correctly for awhile then looses its' position, check for ribbon or correction tape interference with Daisywheel movement. If it does not print correctly as soon as you start typing, remove the Daisywheel and inspect the spokes to see if any are bent. Reinstall the Daisywheel and power ON. If the Daisywheel has a bent spoke or two, you can try to straighten them, howvever the cause of bent spokes is a concern. While typing, carefully watch the print hammer movement. It should always return to the same position and not move towards the paper until a letter is pressed. If it does not come to rest properly, the hammer is not in proper timing and may enter the Daisywheel while it is spinning to the character, thus causing damage to the Daisywheel or causing it to lose homing. .The hammer cams would require adjustment ore replacement. If bent spokes is a persistent problem, make sure to get the hammer problem repaired before buying a new daisywhel.
Dec 29, 2009 | Brother SX-4000 Typewriter
Brother gx-6750 is typing incorrect numbers and letters. how do i fix?
Removed and reinstall the Daisywheel. Inspect the ribbon and lift-off tape to eliminate interfering with Daisywheel spinning. Make certain the daisywheel has no bent spokes. Type slowly while carefully watching the hammer come to rest after printing. If you see the hammer moving towards the paper after a print cycle, the hammer is probably causing the Daisywheel to lose homing and will need to retimed or have the hammer cams assembly replaced.
Dec 27, 2009 | Brother GX-6750 Typewriter
37 people viewed this question
old marine
old marine
