Question about Candy CPCA240FFK Bottom Freezer Refrigerator
Freezing frosting fridge
I have a candy fridge freezer is not working righ,t the fridge is freezing up and all my fridge items are frozen.
please help
  • irenee1 Jan 13, 2009
    hi who did you get to replace the control board?
    many thanks.
    Problem Solver:
  • 5 Answers
I had the same problem recently with all my fridge food freezing up, this all seemed to start when i discovered the interior bulb blown i replaced it still nothing also noticed warning lights on front out,i could hear the motor going so i knew it was on i removed back cover and found the heater covered in ice it turned out it was the failure of the control board causing these problems had it replaced and working fine now hope this is of help dmb23
Posted on Jan 11, 2009
  • dmb23 Jan 13, 2009
    call mike from CHILLING REFRIDGERATION ON 07956362479 he fitted mine
My Frost Free Fridge-Freezer has a problem. Upper portion, freeze all the fruits and vegetable, and lower portion not freezing any poultry meat etc. We have contacted a local dealer, and he need spare...
Most times this is a bad cold control, but there are other things to check for. Make sure the condenser fan is working and the coils are not covered with dust. A separated heat exchanger ( small capillary tubing soldered to the large suction line ) can separate from one another and make the fridge run too long. - tape tubing back together. A poor working evaporator fan motor could also make the fridge run too long and freeze - replace the fan motor. An inefficient compressor or refrigeration system could make the fridge run too long and freeze - have a service tech check this out. A misaligned control settings, make sure the air damper and cold control have not been bumped and are out of normal settings. Stuck open air diffusers or air dampers are becoming more and more common for allowing too much air to be blown into the fresh food section and freezing things. On all frost free fridge's the freezer temp air is blown into the fresh food section, if you have "easy" to freeze items ( eggs, veggies in water, etc ) in front of or under where the freezer temp air comes out, they could freeze - store them in a different spot. Doors not closing properly making the fridge run too long is something else to check for.
Check the cold control and the air deflector. As you know, the deflector directs the freezer air toward the front of the frig and the rear of the cold control.
Hope this helpout .....
Aug 08, 2010 | Refrigerators
Brandt apollo fridge/freezer - food defrosts + salad freezes
Check the vents in the fridge side and close a little if you can. On the freezer side just for good measure>>>>
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Jan 05, 2010 | Freezers
Candy frost free fridge freezer .freezer working ok
The thermostat might be turned up too high or is faulty. It should click when turned up and down from the setpoint.
May 12, 2009 | Freezers
Fridge is freezing stuff
try to call a technician the defrost system of Ur fridge might be damaged or u have a leak of gas on ur system.. tell him to check the thermostat.. also
Mar 09, 2009 | Candy CPCA270FFK Bottom Freezer...
you can decrease the setting of your thermostat for a start.
tnx 4 using fixya,
drcool
Sep 07, 2008 | Candy CPCA240FFK Bottom Freezer...
Fridge freezer
Defrost timers usually cause this type of frost build up. However it can also be caused by the defrost heater and/or heater thermostat, and these items are behind the panels therefore not easy to get to. Also before you attempt to take the panels apart make sure the refrigerator is unplugged.
Aug 04, 2008 | Candy Freezers
Frost free fridge
Check and set both temperature adjustments, one for freezer should be no more than 1/2 and the refrigerator also as a starting point.
May 05, 2008 | Candy CPCA240FFK Bottom Freezer...
Candy CPCA240FFK Bottom Freezer Refrigerator Logo
666 people viewed this question
Top Candy Refrigerators Experts
Charles T Nevin
Charles T Nevin
Cesar Quant
Cesar Quant
Are you a Candy Refrigerator Expert? Answer questions, earn points and help others
