Question about Kipor Electrical Supplies
Kipor generator runs fine but overload light stays on what could be wrong
CarlGehrke
  • 169 Answers
SOURCE: Problem with a kipor 12 ta generator
I just guessing here but it could mean that the oil pressure is too low.
I'd check the oil level first, then look for the oil pressure switch and temporarily disconnect it.
Regards,
Carl
Posted on Feb 23, 2009
  • 1632 Answers
SOURCE: honda eu 6500 gen overload indicator light will not shut off
Check the Ground Fault Indicator circuit breaker for triping, and look for the high limit on generator. Reset the main breaker by triping it full right and then back. Vitally
Posted on May 22, 2009
adnanbhatti
  • 1188 Answers
SOURCE: Kipor 6700TA displaying charge fault (P5)
Check for loose or rusty battery cables. Unscrew the rear cover and locate the red battery wire. Disconnect it and, using a multi meter, check its resistance: it should have a very low value. Do the same with the other wire.
Start the generator and remove battery wires. If the voltage between them is zero then a fuse is blown.
Next open the front panel (where the display is), there you will find two blue wires with covered fuses, check and replace those fuses if found faulty.
If the problem is still there then it could be the charge regulator. Open the back cover by removing the six nuts. Near the edge you will find a component with silver cover resembling plates. There are three wires leading from it. Check resistance between these wires (one by one) and its body: it should be infinite, if not then replace it. remove the charge regulator and take it to a generator spare shop. The person there will further inspect it and will tell you if you need to replace it or repair it.
Hope this solves your problem.
Thank you for using fixya!
Posted on Aug 20, 2009
  • 905 Answers
SOURCE: I have a kipor ig6000 generator.When i connect my
Your generator is running a bit too fast, and the frequency is greater than 60Hz. Most generators are setup for 62-63Hz no load. You can adjust this at the governor for the engine.
Another possibility is that the alternator is providing electric with a large amount of harmonic distortion, which some appliances don't tolerate well (dirty power). Try adding a noise filter between the generator and espresso maker and see if that helps. The espresso maker may also expect to be grounded, which the generator is not able to provide (unless you are driving a ground rod). The noise filter may also require a ground as well.
Posted on Jan 04, 2010
  • 342 Answers
SOURCE: Iam looking to download a manual for a Kipor KDE
looks very similar to the kde 6700 ta
Posted on Apr 04, 2010
My kipor 7000 diesel generator is burning avr. Replaced avr don't last beyond few days. Can someone tell me cause
You need to run these tests in the video to see the state of the alternator. How to test your Electricity Generator AVR Brushes and Alternator on... With this info we can assist you further. :)
The Generator Guru Team
Jan 11, 2017 | Kipor Electrical Supplies
My Kipor KDE16STA3 shows p03 error after 15 min runing and shuts down after 3 sec.The voltage drops to 30,40 whta's happening?
[PDF]DIESEL GENERATING SET
www.kipor.com/upload/spec2011053011590766.pdf
3/KDE16STA3/ ..... P-03 Undervoltage: Indicating voltage higher (lower), the generator will self- braking. P-04 Generator ... KDE16STA3 KDE19STA KDE19STA3.
[PDF]2
www.kipor.com/upload/spec2011061109073968.pdf
P-03. Decrease load less than the related load, turn on the breaker. P-04. Replace the fuse of the same type. Check the circuit and inserter. Replace the starting ...
Oct 31, 2015 | Kipor Electrical Supplies
Generator will not stay running
The toggle switch automatically resets all faults when it is turned to the off position. I would turn the toggle switch off, turn off the breaker on the generator and then turn off all the loads in the house except a few lights. Turn the generator breaker back on, then turn the toggle switch back to automatic. If it starts and stays running, you were overloading the generator. Turn on other loads slowly and keep track of what is on so you don't overload it again. If it still does not stay on, you may have a problem with the panel. Let me know what happens.
Nov 20, 2013 | Briggs & Stratton 15,000 Watt Home Standby...
Generator starts and runs fine but not getting power to outlets and no indicator light
Please check the capacitor and the rotor brushes and rotor rings for cleanliness
Oct 09, 2013 | Kipor Kge3500ti
The generator starts but when i plug in something it overloads with only one thing plugged in and stops generating
what watt is the jenny and what whatt is the tool ur using are u drawing to much power ?
My kipor KGE 6000 Ti generator overload light is on, and there is no current output
Speak to us and we can help you diagnose this error.
www.generatorguru.com
Dec 25, 2012 | Electrical Supplies
Kipor ig6000 overload alarm
most warning and alarm's are set less than what the manufacture rating is. it's a safety feature without it we would overload all our stuff
Sep 23, 2012 | Kipor Electrical Supplies
Kipor IG3000 generator stepper motor bad?
I just experience the same issue. Mine was a broke wire at step motor. Now to find parts as I hv soldered the wire and works great... I'm sure the others will fail soon enough
Aug 12, 2012 | Kipor Generator IG3000 CARB
My kipor KGE 1000Ti starts fine but after several minutes stops generating and the red overload light comes on, with the demand for power left connected and the generator still running electrical...
You may be UNDERLOADING the generator and it may be unstable with such a light load... see if it might behave running a heavier load... put a 100 watt light on it as a test,
Jul 25, 2010 | Electrical Supplies
Electrical Supplies Logo
206 people viewed this question
Top Kipor Electrical Supplies Experts
jhnolson
Jay Finke
Jay Finke
Chuck Graybill
Are you a Kipor Electrical Supply Expert? Answer questions, earn points and help others
