Question about Toro Electric Ultra Blower/Vac 12 Amp
Toro 51599 switch
Is there an aftermarket switch I can fix my Toro 51599 blower/vac with? It could be purely on off or a 3-speed instead of the variable sppeed that comes on it. My blower/vac is in good shape except for the switch.
  • 398 Answers
SOURCE: toro 51591 and torro 51599 will not start
try some starting fluid and change the gas
Posted on Feb 27, 2009
vincob
  • 718 Answers
SOURCE: I bought a Toro ultra electric blower vac (model
Common sense tells me it is not that hard you probably do not need an instruction manual, does life come with a instruction manual O Yeah the Bible. Believe in yourself review the situation, think it over you can do it!!!!!!!!!
Posted on Nov 25, 2009
SOURCE: Toro Blower..No power. Like a blown fuse. Does it have a fuse?
I have the Toro 51591 model. Yesterday, mine did the same as yours. I opened up the case and found that a small cylinder had broken off of the switch. So it could be that your switch is the problem. I have been unable so far to find a replacement anywhere.
You should consider using your warranty.
Posted on Dec 12, 2009
Testimonial: "Thanks. I checked the manual first though and read that the impeller cover if not properly closed will not allow it to turn on. That worked. Thanks"
  • 138 Answers
SOURCE: how do replace the impeller on a toro 51591 super
Toro and Sears blowers are pretty much the same. It is not worth the trouble to replace. Good Luck
Posted on Jan 06, 2011
barterjoe
  • 344 Answers
SOURCE: my toro ultra 51599 stopped
It is very common for the bottom cover to not push in the safety button and render the machine "dead" a simple fix. you can get a new cover through a shop like www.arcolawn.com
cheers
Joe
Posted on Feb 12, 2011
Need switch for toro blower vac model 51599
get on Amazon or craigslist type what you want
Nov 12, 2017 | Toro Garden
Why will my toro 5198 leaf blower not start?
If you're Toro electric blower is slowing down, throwing sparks, or not starting you may need to replace the carbon brushes. Replacing brushes and cleaning commutator early can prevent damage to motor armature!
There are Electric Motor replacement carbon brushes on E-bay for all three motor sizes (7 AMP, 10.5 AMP, and 12 AMP) of Toro Leaf Blowers (Toro Rake and Vac Super and Ultra Blower and "850" Vacuums)
Search E-bay for: "Toro Blower Carbon Brush"
- 12 Amp leaf blowers Toro Super (Old model 51552) through Toro Ultra (New model 51609).
- Toro 850 Super Blower Shredder-Vac 12 Amp (model 51575).
- 10.5 Amp leaf blowers Toro Old through Toro New model 51573.
- 7 Amp leaf blowers Toro model 51586 and other Toro 7 amp blowers.
Jun 28, 2014 | Toro 51599 Electric Blower 12 Amp
Toro blower-vaccuum stop working
Replace the variable speed control with a toggle switch. Cut the 2 power wires that go to the big rotary knob and wire to a toggle switch that you can install by drilling a hole near where the power cable enters. Works great and full power all the time.
May 25, 2014 | Toro Electric Ultra Blower/Vac 12 Amp
Motor won't turn on
There are Electric Motor replacement carbon brushes on E-bay for all three motor sizes (7 AMP, 10.5 AMP, and 12 AMP) of Toro Leaf Blowers (Toro Rake and Vac Super and Ultra Blower Vacuums)
Apr 14, 2014 | Toro 51599 Electric Blower 12 Amp
Snow blower shorted out
If you're Toro electric blower is slowing down, throwing sparks, overheating or not starting you may need to replace the carbon brushes. Replacing brushes and cleaning commutator early can prevent damage to motor armature!
Feb 17, 2014 | Toro 51599 Electric Blower 12 Amp
My toro model 51599 ultra with metal impeller began to overheat and shut it self off... is there a reset switch...this happened after moderate use tnx
If you take it apart there is a little spring on the bottom of the motor. When overheated it "trips" and looses contact with a wire. Need to reset the spring.
Feb 17, 2011 | Toro Blowers Rake and Vac - Electric...
Problem is my hardly used Toro Blower Vac is getting no Power
If it has not run for awhile, check the brushes. they might need to be replaced. The plug is usually moulded right on power cord. That might have to be replaced because if there is a problem with a broken or disconnected wire right at plug there is no way to see it. Hope this helps.
Dec 07, 2010 | Toro 51599 Electric Blower 12 Amp
After a couple of hours of use last week, the motor started slowing down. Turned it off and it would not restart. tried again after an hour and it started but sounded really rough. stopped it and took it...
sounds like the motor is worn out. Toro does not sell the motor separate. It is considered a throw away unit.
You will have to purchase a new one.
Sorry.
Good Day.
Nov 05, 2009 | Toro Electric Ultra Blower/Vac 12 Amp
Toro Electric Ultra Blower/Vac 12 Amp Logo
162 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
