The bluetooth disengages ever once an s while how do a make it stay engaged?
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 77 Answers
Common problem with the CoolStream transmitters, it might not be 100% compatible with your Altec Lansing device.
Posted on Nov 28, 2012
Why does the solenoid not stay engaged when trying to start?
check for shiny clean battery posts and terminals and ensure that hey are tight. Have a load test done on the battery as it may have an internal fault (bad cell)
Jul 20, 2014 | 2001 Oldsmobile Aurora 3.5
Blades to disengage
On mower deck there is a pulley that engages the belt to turn blades. Find it, While tractor is shut off check that spring is on the bracket that moves pulley back when disengaged.If gone replace it. If its there, slide bracket back and forth to find out what it is catching on.
Jun 24, 2014 | Mtd Garden
My pto belt doesnt disengage
have you recently replaced the belt? It might be to short. Also, check the belt tensioner and routing
Feb 05, 2013 | Garden
I've noticed the starter drive gear does not stay engaged On the E-Drive starter with the flywheel if the engine does not start as in the older Prestolite style starters. Why?
Becausethe starter drive gear disengages after each starting attempt, the engine ismuch easier to hand prop should the battery be too low to provide normalstarting voltage. Though we do not recommend had-propping an engine, it doesoccasionally still happen in the field.
Jul 09, 2012 | Sport & Outdoor - Others
Transmission won't engage
sounds like its time for a new mower
Apr 24, 2012 | John Deere Garden
Does a 2006 ford expedtion need a vaccum on front hubs to make engage and disengage
The vacuum is to keep the 4x4 disengaged, once vac is removed the IWE ( Integrated wheel end ) is engaged, so the front hubs are locked.
Block diagram from the F150, EXPY should be the same routing ( could be slightly different )
The f150 had a TSB for the IWE solenoid where water could get into the system, and cause the IWE to not be disengaged in 2WD ( slightly engaged, ratcheting the IWE gear ).
Right Click, Save As
http://my.voyager.net/~sscully/file_tsb06_08_15.pdf
Jun 16, 2011 | 2006 Ford F-150
PTO CONTROLS. How do you engage and disengage PTO.
The tractor is not a 6300 is it.If it' not you need to adjust the cable for the p.t.o. until it will stay down.Don't turn the turnbuckle too much at a time because there is a fine line between the won't engage and the won,t disengage adjustment.
Sep 06, 2009 | John Deere 6300,6300l,6400,6400l Tractor...
 Grubhead
Grubhead
