Question about Audiovox D1805 Portable DVD Player with Screen
DVD player picture keeps rolling
Picture on DVD player keeps rolling. We were looking at the 9508 IC.
  • Anonymous Jan 21, 2009
    AUDIOVOX D1805 - screen rolls. Tried the following to no avail;
    1. cleaned the DVD Lens
    2. cleaned internal boards.
    3. Reseated connections.
    Still doesn't work.
Picture rolls
it come from TV itself because a difference synchronization IF YOU HAVE SUITABLE KNOB IN TV TRY TO MOVE IT A LITTLE IF NOT YOU NEED A TECHNICIAN TO SEE BOOTH A TV & DVD
May 29, 2009 | Cyberhome CH-DVD 300 DVD Player
Picture on tv rolls when dvd player is on.
Radio Frequency Interference (RFI) being generated by you rDVD Player.
That, or you have the DVDs settings on PAL instead of NTSC.
Mar 13, 2009 | Prosonic PD-007 DVD Player
DVD player - b+w rolling picture
it mey be change invideo out put has been changes i.e. ntse or pal mode to changes that mode on remote threr is p/n switch
Mar 03, 2009 | Televison & Video
DVD picture rolls vertically
Somehow the TV setting on the DVD player was set to PALS so we changed it to the proper setting.
Dec 15, 2008 | Digix HT1056A DVD
Vcr
f you accidentally set Progressive Scan to ON (within
Analog TV), press STOP for five seconds to restore the
picture to normal operation.
Aug 07, 2008 | Philips Magnavox DVD/VCR Dual Player
Cyberhome 402 DVD "rolls"
I think I had switched to the PAL format by mistake. Fixed the problem by buying a new DVD player, was cheaper than the factory fix.
Jul 30, 2008 | Cyberhome CH-DVD 300 DVD Player
Picture rolls
Same as sherpi here, player was fine, and all of sudden started rolling and never stops. Rolls with or without a disc in it...seems to play the discs fine, but never quits rolling.
Mar 08, 2008 | Spectroniq PD-1100 DVD Player
The picture on the VCR keeps rolling. How do I remedy this? I have a Sylvania cca-132a2 model.
i know this may seem old-school, but try turning the vertical hold knob. it used to solve all vcr problems with rolling picture.
Jul 07, 2007 | Sylvania (SRDD495) DVD Player/VCR
APEX AD1201
buy an rf modulator and run it through that instead
Dec 30, 2006 | Apex Digital AD1201 DVD Player
Picture keeps rolling
The picture rolling is simply because the PAL decoder can't lock up to the 60Hz vertical sync pulses, even if your DVD player is set to NTSC-PAL conversion and there is no vertical hold adjustment (either external or internal) on this model set to achieve this. There is a possible alternative only if your DVD player has RGB output (not component). The JVC for example has direct RGB drive capability via the SCART input on the back panel. If you get a suitable lead you could try getting a picture this way as it bypasses the decoding and sync sep circuits in the PAL decoder chip.
Oct 03, 2005 | Panasonic DVD-F87 Multi-disc DVD Player
Audiovox D1805 Portable DVD Player with Screen Logo
138 people viewed this question
Top Audiovox Televison & Video Experts
Jaime Hernandez
Dave Naylor
Dave Naylor
Are you an Audiovox Televison and Video Expert? Answer questions, earn points and help others
