HP 3070a all in one printer
New original cartridge HP324 black does not work
SOURCE: cannot get the printer to accept the new HP black cartridge
On my officejet 5510, I decided that the printer was toast and decided to throw it out and buy a new one. After making that decision, I decided to pound on top of it it a few times. Guess what??? You guessed it.....it reset itself and started back working. That was about 6 weeks ago and I haven't had a problem since. I have since turned it off and on many times, and it works like a charm. GO FIGURE!! (I only recommend this to those who have given up and are planning to trash it anyway).
Posted on Feb 04, 2008
jmassengill
  • 345 Answers
SOURCE: The printer doesn't recognize the new original HP color cartridge
There is a small spring that holds the ink cartridge in the ink holder. You will see it stick out from the right hand side of the ink holder where the ink cartridge slides in. If that spring isn't being held to the ink holder by two plastic tabs, (I.E. the plastic tabs are broken) the printer will never recognize the cartridge. If the printer is still under warranty I would contact HP or an authorized repair center for HP. Both the black and color ink holder has this spring. I know of no way to repair this kind of breakage.
Posted on Jan 08, 2009
JackHeath
  • 1049 Answers
SOURCE: hp c7820 printer 02 black catridge
Open the printer and remove the ink. Clean around the ink carriage and the under the ink with alcohol and a cotton swab. Pay special attention to areas with copper contacts. Keep in mind too that some printers will not print, even with full ink, if the exact type of ink it expected you to have installed is not right. Double check that the ink is correct against the manual or written instructions inside the printer using the number not the shape or color of the cartridge. Not every cartridge that fits the printer necessarily works.
Posted on Nov 13, 2009
SOURCE: HP photosmart C4480 printer cartridge incompatible error
Well....I solved the problem......bought a new Canon printer!!
I tried everything...unplugging, cleaning everything that was mentioned above. I was onto HP online support several time, but they were absolutely no help at all...they basically told me that the cartridge must be damaged or ink dried up and to buy a new cartridge to see if the error persisted.....I don't think so!!!
I will never by HP again after having issues with the last two I have had. I love my new Canon printer it is EVERYTHING that HP wasnt.
Posted on Jan 16, 2010
  • 5 Answers
SOURCE: installed new hp black cartridge 56 ink but won't print
it shows if your using refill cartridge. & if you r using refill cartridge clear cartridge sensor with soft hands your problem would be resolved.
Posted on Jan 22, 2010
After refilling my black ink cartridge my hp printer software gives me a message "not the original cartridge" and will not print a document i send to the printer
Not necessarily that you have to buy a new cartridge just refill an original cartridge instead of an alternative replacement one!
Jan 22, 2015 | HP Office Equipment & Supplies
Help with HP 950 printer
Are you using original HP garbage? If not, the printer is designed to not work with refills.(there is a work around on the web)
If it is an original cartridge, perform a test print to see what happens. Should work if not, make sure that the printer driver you are using is compatible with OS. If all that checks out and still nothing, you can try to hard reset the printer. If still nothing, get a new printer, not an HP. When they work, they are fine - but their customer service SUCKS big time. They will only render assistance during warranty period. After that they refer you to a forum or suggest you get another unit - an hp of course!
Sep 10, 2017 | HP PSC 950 All-In-One InkJet Printer
I have a Dell Dim 2400 and no connection with HP Deskjet 3070A.
Charles, has this combination worked previously, have you been able to print from your Dell Dimension 2400 to your HP Deskjet 3070A successfully?
If the answer to the above is Yes, then if you believe that the printer is still working correctly and you can test this with a different computer able to print to it, you should consider uninstalling and re-installing the HP software and device drivers for this printer.
If you have not printed to this printer successfully previously, have you tested the printer with a different computer and proven it is still working fine?
If the printer works fine to a different computer then providing you are using the same USB cable to connect to your Dell 2400, the problem needs to be narrowed down further.
Check that you can plus other USB devices into the port on the Dell used for the HP printer - if these work, then your USB port is good - if not, try another port if you have one.
If your USB hardware is good, then again you are left with the need to uninstall and re-install the HP software and device drivers - it may be worth trying to download the latest version of such software if available. HP tend to update their All-in-One software on a regular basis.
Dec 30, 2011 | Dell Dimension 2400 (24006YYVP31) PC...
HP Officejet 4500 Incompatible Black Cartridge
I have an HP officejet 4500. When I replace cartridge the printer reported Incompatible print cartridge. How can I get the printer to accept the cartridge and start printing again? The color cartridge is original to the printer and the black cartridge is the "new" one.
Feb 26, 2011 | HP OfficeJet 6110 All-In-One InkJet...
I have an hp deskjet 5550 printer which used to be connected to my previous computer. My current pc has Windows Vista and although the printer works it just prints in tiny faint text and won't use my new...
Sounds like the working cartridges are badly clogged. Is the new cartridge HP brand or an "internet special"? Try HP originals and see if the machine still works ( I imagine it will). If not, then yes the machine is probably and the end of its life.
Jun 08, 2010 | HP DeskJet 5550 InkJet Printer
HP psc2170 printer does not says there is no black cartridge.
1- take it out
2- then clean the chip that stick on your cartridge and the pins in the box that the cartridge chip get together with
3- put it in again
4 - if it still not working buy an original cartridge
May 22, 2010 | HP PSC 2175 All-In-One InkJet Printer
Black and color cartridges refilled. originals back in printer...printer says no color cartridge installed.. have cleaned contacts on cartridge and machine, NO difference. can we print just in black if...
You need to have both black and color cartridges installed with functioning electronics to use your printer. Sounds like your original color cartridge and the refilled color cartridge you purchased both have bad electronics. I recommend Cartridge World or Office Depot for cartridge refills because they electrically screen their cartridges before selling them. You need to buy either a new or refilled color cartridge for your printer to work.
Feb 09, 2010 | HP PSC 950 All-In-One InkJet Printer
I put a refilled black ink in my HP PSXçC
the problem with the refilled ink is that the ink is NO WHERE near as good as the original HP ink and the ink cartridge is now damaged - just replace the cartridge with a new HP cartridge and you should be OK!
Dec 09, 2009 | HP PSC 1315 All-In-One InkJet Printer
PRINT FADING ON RIGHT HAND SIDE WHILE BLACK CARTRIDGE SHOWS FULL.
your cartridge is third party toner insert new hp original cartridge before cleaning
Jun 23, 2009 | HP Color LaserJet 2600n Printer
Will not print black , HP PSC 1610 All-in-One
Is it a new genuine cart? If so, I have had this problem. Run multiple copies of black only text, Run 50 copies, will still spit out blank pages.Then head clean. If no black repeat. I did this for around 200-250 copies then Volia! black. Hope this helps
Apr 28, 2009 | HP PSC 1610 All-In-One InkJet Printer
k24674
jasbo
jasbo
