Question about Microsoft Windows Vista Ultimate Edition
Device Manager is blank
When starting my Vista box I get RegisterDeviceNotification Faile: 1066. I get this twice. I've checked the PNP service and it won't start. Checked the System Error Logs -
The Plug and Play service terminated with the following error:
The system cannot find the file specified. and I have a bunch more like it or service didn't start because of dependency services didn't start. I started looking around....and my device manager is completly blank. I'm not sure of what might have caused this. Nothing was installed that I know of. Just booted one morning and walla....things are in disarray.
Any ideas???
    Novelist:
  • 93 Answers
Somehow you've lost at least one dll file that Vista needs to load. This could be due to a bad sector on your hard drive, or something like a virus might have maliciously removed it.
The first thing I would try is to repair your Vista installation from the install CD. Boot from it, follow the prompts, and it will re-copy all of the essential system files. Reboot after the repair, and anything that was missing should now be there.
In any case, let me know how it goes.
Cheers
Nick
Posted on Jan 10, 2009
Cannot connect to internet router is working properly it is connected to my regular computer but cannnot get singal for my notebook
Hello, bevybuns5!
First thing, make sure your WLAN card is turned on, however, without knowing your specific laptop model, I can't help locate it for you. After that, check your router's wireless security code, and assure that you're entering it correctly. Then, if you still aren't able to connect, try manually unplugging the ethernet cable from your PC, then plug the Ethernet cable into the laptop. If you get a signal, skip to the third paragraph, if not then read the next paragraph.
If you aren't getting a physical connection, it could indicate that there is something wrong with some type of software, or operating system settings that aren't allowing you to connect to the internet (leave the network cable plugged in for troubleshooting). Try checking firewall settings (windows firewall is infamous for blocking almost all connections at will). Then, if you're using windows xp, go to the start menu, open the run command, and type "CMD" without quotes (if you're using Vista or Win7, then just type CMD in the search box at the start menu. When the command prompt screen appears, enter this text without quotes "ipconfig /all". If you have an IP address, subnet gateway, and IPv4 configuration, then you're ready for the next step (if not, let me know in a comment, and I'll leave the instructions for that solution). If you're using xp, then right click computer, click properties, go to the hardware tab, then click "Device Manager" (for Vista/Win7, just type Device Manager in the start menu search box). Scroll down (if you have to) to Network, click on it, find your physical network card, right click and uninstall it (don't worry, this won't hurt anything). Wait for a few moments, then right click anywhere in the Device Manager window, then select "scan for new hardware". This will find the NIC you just uninstalled, and reinstall it (with original drivers, unless you've upgraded your Operating System, then you'll have to get the drivers from the manufacturers website via your desktop). Reboot the laptop, and try connecting with the LAN cable again. If this solution doesn't work, leave me a comment describing what you've done, and any error messages that have come up.
If you recieve a signal from the LAN cable, and still cannot connect via the wireless card, then back into device manager we go! For xp users, go to the Start Menu > right click Computer > click Properties > go to the Hardware tab > then click Device Manager. For Vista/Win7 users, open the Start Menu, then type Device Manager. Scroll down and find your wireless card, and if you've tried the solution in the second paragraph, you know what we're gonna do. Right click it, Uninstall the wireless card, wait for a few moments, then right-click anywhere in the Device Manager screen, and select Scan for New Hardware. Reboot the system, and you should be working!
Aug 02, 2011 | Computers & Internet
Tip
USB PORT FIX WIN 7
Method 1
*For Microsoft Windows Vista (and windows 7) Click Start, and type device manager in the Start Search box. Click Device Manager in the Programs list. If you are prompted for an administrator password or confirmation, type your password or click Continue. In the Device Manager dialog box, expand Universal Serial Bus controllers. Right-click USB Root Hub and then click Properties. In the USB Root Hub Properties dialog box, click the Power Management tab. Remove the check from the Allow the computer to turn off this device to save power check box. Repeat steps 1 through 4 for each USB Root Hub listed in the Device Manager.
Under Power settings, check the 'USB settings' -> 'USB selective suspend settings' and make sure it is disabled.
Check Thumbnail, highlighted: Open Device manager, Double click on Universal Serial Bus controller at the bottom, Double Click USB Root Hub, Click Power Management on top right, Uncheck Allow Power...
Method 2
*You can disable the USB Selective Suspend feature as a workaround by editing the registry. The USB device may become unresponsive because of a race condition in the Selective Suspend feature. The Selective Suspend feature suspends the USB device to efficiently maintain battery power by enabling the computer to turn off the USB device. However, sometimes this feature may not correctly wake up the USB device. Therefore, the USB device is unresponsive when you try to use it. You might want to disable this feature for server products where power management is not important or required. *To disable the Selective Suspend feature, follow these steps: Click Start and then click Run. Note If you are running Windows Vista, click Start, and then use the Start Search box. Type reedit, and then click OK. Registry Editor opens. Locate and then click the following registry subkey: HKEY_LOCAL_MACHINE\System\CurrentControlSet\Servic es\USB If the DisableSelectiveSuspend registry entry is present, double-click it. If it is not present, create the entry. To create the entry, follow these steps: On the Edit menu, point to New, and then click DWORD. Type DisableSelectiveSuspend, and then press ENTER. On the Edit menu, click Modify. In the Value data field, type 1 to disable the Selective Suspend feature, and then click OK.
on Feb 14, 2010 | Computers & Internet
Mic not workig making a noise but the mic is built in
Uninstall and reinstall the audio driver.
For windows vista
a. Go to start
b. Type "device manager" on the start search box (windows vista).
Type "device manager" on the search for programs and files box (windows 7)
c. Expand "sound and video game controller". Usually audio driver is "realtek high definition".
d. Right click on to that audio driver and select uninstall. Do not check the box for delete. Just click ok.
e. Restart the laptop.
f. Once restarted, wait for the message that the "device software is being installed". Or go back to device manager if the audio driver is back. It should come back.
g.Test the mic.
Mar 02, 2011 | Toshiba Computers & Internet
XPS 210 with XP Media Center has unknown driver in device manager. I think it might be the TV tuner because I get a Decoder error when I try to watch TV in the media center.
Here's something to try. In Device Manager, double-click the unknown device to open its properties. Click the Details tab. In the Property drop-down menu, choose Device Instance ID (or Device Instance Path for Windows Vista/7). You'll see a string of characters in the Value box.
In this string of characters, look for the letters VEN_. The numbers following this are the vender ID. Then look for the letters DEV_. The numbers following this are the device ID.
Go to the PCI Vendor and Device database here:
http://www.pcidatabase.com/
and enter the vendor and device ID for your search. This doesn't always find the right device, but it often does. After you figure out what the device is, you should be able to determine whether you can download the right drivers.
Feb 26, 2011 | Dell My XPS 210 (dxcwpf1_7) Intel Core2...
My monitor goes dark after 1 second and won't come back until cycled off and on again
It is the picture picture board on your monitor that is malfunctioning, since the power led or button is on, but the display screen goes blank after a second, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity or any service center to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
May 07, 2010 | ViewSonic VG710b 17" Flat Panel LCD...
PnP Driver NotFound
ur PnP is corrupt or broken so it needs to be re-installed. check your device manager and go to USB settings and check if the drivers are installed if not thats the problem u will need to to re-install the drivers or buy a new PnP card driver.
Dec 07, 2009 | Computers & Internet
USB works under BIOS, doesn't plug'n'play under WinXP
Seems u r having plug and play problem.
When the second problem appeared? after the upgrade?
Some weird things like this, exists with SP3.
Does Windows ask u to install them?
Check whether the PnP is enabled from the BIOS.
U can try installing your chipset driver (Update).
Go to action menu and Click on Show Hidden Devices. Go to Hidden devices and check whether there are entries related to usb with yellow marks. Parport,Mountmgr (non PnP). etc. Check whether you have any Viruses.
Important :
Check whether these services are functioning properly.
Go to Device Manager
Click On - Services
Plug and Play (Automatic-Normally) Service
and Such services as PLFlashDeviceIoControl Service, Portable Media Serial Number Service, Windows Management Instrumentation (Set to Automatic) and Windows Management Instrumentation Driver Extensions (Start it). They are the people who are responsible and caused these errors. Double Click an set each one's Recovery options.
Then go to Event Viewer and check System (ans Application) for specific erroneous entries.
Did u do a system restore. Anyway if you have upgraded u can't of cause. U could try that. Check whether ur usb root hubs are functioning. U have to upgrade drives for XPSP3. There are many compatibility issues.
Try the latest chipset drive.
Try removing these.
Then reboot and check.
If this solution works or helped you, please kindly RATE the answer.
Wish you luck!
Thanks.
Lasitha
Jun 28, 2009 | Microsoft Windows XP Professional With...
PnPDeviceProblemCode
Even i had this problem.
Follow these steps it may be of help to you.
1. Go to Device manager.
2. Insert the SD card.
3. When the SD card shows up in the device manager with an alert, right click and say disable device.
4. Go to Services and start PNP related services if it is not started.
5. Again right click and say enable device.
6. It shud update the driver software and your device may be detected successfully.
7. Enjoy :)
Cheers,
Raghu
May 27, 2009 | Dell Studio 1537 Laptop Computer PC...
I need Vista drivers for an Agfa Snapscan 1212U with in/off switch
download unknown device identifier from google and the use device manager find the driver in unknown device identifier and click the plus sign, find the part where it says pnp maximize that and right click then find driver and it will take you to the page.
Apr 14, 2008 | Computers & Internet
Microsoft Windows Vista Ultimate Edition Logo
78 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
