We have a Nordyne AC/Heater model # E2EB-012HA. My problem with the unit is that the heater will not turn off and the blower motor also won't turn off unless we switch the breaker to off. Also I noticed that one of the breakers on the unit has red on it and the other one is black, I don't know if that would make a difference. And we also changed the batteries in the thermostat and still nothing. Please help.!
My nordyne e2eb-012ha after running shuts off most of the time we have to reset the element breaker to get it going again. any ideas can"t find directions to how to get behind breakers thanks morris
Posted on Dec 21, 2012
  • 10 Answers
SOURCE: Properly installed electric baseboard heater won't work.
I am an electrician. You must measure the voltage across the black and red wires. Measuring each wire to the neutral will not cut it. If both your red and black wire are on the same phase the heater will not work.
To double check your wiring, measure the voltage across the two screws feeding your subpanel, they should be 240v or 208v depending on your power company. Then do the same at the breaker feeding your thermostat. Again it should read 240v.
If you have no potential across the screws it is possible that you installed an incorrect breaker. Not all breakers with two screws on them are 240v breakers. There is what is called a twin or split breaker that has two screws that are on the same phase. These are for wiring two 110v circuits, when you run out of spaces in the panel.
Double check everything. This is a relatively easy circuit to wire, even for homeowners. If the heater does not work them something is wrong so do not leave the circuit energized.
Posted on Mar 16, 2009
  • 147 Answers
SOURCE: wireing the baseboard heater
I can help you if you still here.
Posted on Nov 06, 2008
muttandjeff
  • 359 Answers
SOURCE: Baseboard electric heater installed properly, yet won't work.
DID YOU CONNECT TO TH SAME END YOU TOOK OUT WHEN PAINTING WE ARE DOWN TO THE CONNECTION @ THE HEATER MAKE SURE THE OTHER END OF TH ELEMENT IS CLOSED WITH WIRE NUTS AND TIGHT , LIKE I SAID WE ARE DOWN TO THE HEATER CONNECTIONS SO LOOK THERE
Posted on Dec 23, 2008
SOURCE: Installing a Dayton G73
How many amps is your service? And what gauge wire did you use for the heater?
If your service is only 40amps that is your problem. You don't have enough amps for the heater and the rest of your house, you will have to upgrade your service.
Posted on Jan 18, 2009
SOURCE: thermostat wiring diagram for heat and cool unit
use an ON-OFF controller whose output can be given to themostat or a circuit breaker....
Posted on Sep 04, 2009
Heater won't turn on
Do you mean the blower motor ?
Have you checked the fuse to see if it has power ?
Jan 28, 2013 | 1997 Ford Taurus
I have a intertherm e2eb-012ha. I need to know what size run cap to use. . The plastic coating has been melted so I can not see the run cap info.
It appears you may already have located your problem, the capacitors are very coming to burn out, if a motor will run after you spin by hand, mmore times than not the capacitor is the problem. The name tag on the equipment itself sometimes has the capacitor size and the motor nameplate usually does as well. you can call Nordyne support at 18004224328 and with your Intertherm Model number they can give you the correct capacitor size, which you can purchase at any HVAC supply house. If I had to guess, I would say you need a 5 mfd capacitor based on the blower size. but call them and verify. Also, most all supply houses that sell that capacitor can run the Intertherm numbers and see the correct size as well.
Jan 06, 2013 | Heating & Cooling
Nordyne Split System Blower Won't Start
It's the fan motor. A relay problem would cause the motor not to run at all.
May 08, 2017 | Heating & Cooling
CHECK AC AND HEATER CONTROL FUSE. IF FUSE OKAY CHECK BLOWER SEE IF POWER GOING TO BLOWER MOTOR IF YES BLOWER MOTOR MORE LIKELY FAULTY.IF NO POWER GOING TO BLOWER MOTOR CHECK BLOWER MOTOR FUSE ANDRELAY.
Oct 28, 2011 | 2000 Kia Spectra
My blower motor won't come on the heater nor ac
fan motor,fuse or fan ressistor.hope this helps
May 26, 2011 | 2000 Volkswagen Beetle
The heater/ac fan only works on speed settings 4 & 5
you might check your switch sounds like to me that your two lower speed sides of the switch maybe burnwed out.
Dec 19, 2009 | 2002 Chevrolet TrailBlazer
Heating & Cooling Logo
481 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
