Question about Hi-Pro (HP-P401W) (HPP401W) Power Supply
HiPro HP-R650FF3 power supply - Hi-Pro (HP-P401W) (HPP401W) Power Supply
4 Suggested Answers
  • 1738 Answers
SOURCE: I have 115 v. power to the end of the power cord,
If you are getting 115 v to the power supply and no power it is the power supply.
Posted on Aug 11, 2009
Testimonial: "thanks-I was afraid that was the answer"
joecoolvette
  • 5660 Answers
SOURCE: The LED on my HIPRO D3057F3R power supply is
Yes, it does.
More than likely Electrolytic Capacitors, have gone bad in the power supply.
Electrolytic Capacitors are used in the Input, and Output stage of the HiPro power supply, as Filters.
In the Input stage they filter the incoming AC voltage.
In the Output stage they filter the rectified AC.
(AC is rectified into DC. The capacitors are filtering DC at this point.
AC = Alternating Current
DC = Direct Current
A flashlight battery is an example of stored DC)
The HiPro power supply you have produces three main voltages. Three voltage Rails.
A.3.3 Volts
B.5 Volts
C.12 Volts
When Electrolytic Capacitors go bad, or are failing, there is a weak voltage rail.
HiPro power supply's are cheaply mad.
1.The wiring is too small. (The gauge of the wire is below standards)
2.The Electrolytic Capacitors are of low quality.
3.The rectifier bridge has cheap diodes, and too small of a heatsink.
I could go on, and on.
When you have a power supply with a weak voltage rail, there is not enough power for the Processor.
1.ALL the lights use less than 1 Watt.
2.EACH fan uses 2 to 3 Watts.
3.A typical Processor can use 55 to 125 Watts!
[Depends on what processor it is.
This is why lights - light, and sometimes fan's will spin, but the computer won't run.
Not enough power for the Processor.
Solution?
Replace the power supply.
Viewing this link,
http://www.pcmarketusa.com/product_view.aspx?product_ID=18498
,you can see the HiPro D3057FR3 power supply has just the usual ATX shape, and size.
The ATX 'Form Factor' power supply, is used in approximately 90 percent of computer towers.
[Form Factor usually denotes towards a motherboard. An ATX form factor motherboard is 9.6 inches by 12 inches. Form Factor means the size, and shape.
The Form Factor designation, has been used towards certain hardware parts in a computer, as well as the computer case, but this is erroneously used. It does make it easier to identify with, though. That's why I used it here]
Point I'm getting to?
1.See if you have another Known, GOOD, ATX power supply to use for a test. Test my statements above before you go out, and buy another power supply.
Do you have another computer that has a good power supply, but may have other issues, that you can borrow the power supply out of, to use for a test?
Another thing. This manufacturer overstates the actual rated Wattage. The actual wattage is more like 70 percent of what is stated.
They state 300 Watts - Maximum, but in reality it is more like 210 Watts.
It is for this reason, and the reason that components used in the above power supply are cheap, that I would recommend buying a different power supply, than buying another HiPro.
(Therefore,.NO, I do not recommend the one in the link above, as a direct replacement)
What power supply that fits your needs would I recommend, that is a decent quality power supply, and won't break the bank?
This one,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4675269&CatId=106
OCZ StealthXStream 400 Watt.
Why?
Because it has 80 percent of the true rated wattage.
320 Watts actual.
Because it is reliable.
Because it has all the power cables you need.
Because it is $28 USD after the rebate.
I'm sticking my neck out recommending a particular power supply here, as this goes against our TOS, but if you have no background in this area, how are you going to know what to look for?
I am not recommending the website. But I have used them repeatedly, and always to my satifaction.
Any questions?
Posted on Nov 27, 2009
SOURCE: Hipro HP-d3057f3r computer power supply broken?
I have the same problem. I found this:
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=bph06788&product=12455#bph06788_section_2
  • Replace the side panel, plug in the power cord, and examine the light on the back of the power supply:
  • If the LED is on solid and is not flashing, the power supply is probably good and the problem is most likely caused by a defective component (processor, memory, PCI card) or a defective motherboard. Have the computer serviced, or remove the components and replace them, one at a time, to find and replace the defective component.
  • Posted on May 18, 2010
    I am looking for a schematic for a Dell Optiplex GX280 power supply. The supply is model HP-U2106F3.
    I just replaced my GX280 power supply (mini-tower) with the following 400W for $30.
    http://www.cputopia.com/hp-400w-dell-optiplex-gx280-mini-tower.html
    The only place I can think you will find an actual schematic for the PSU is from the manufacturer.
    Feb 13, 2011 | Hi-Pro Refurbished HIPRO POWER SUPPLY FOR...
    HAVE A HIPRO PSU PART NO. HP5187-4875
    A replacement is very inexpensive to replace. Bestbuy, MicroCenter, small computer shops and buy replacement from Amazon.com, newegg.com.. Just make sure you have the correct information for your replacement. The model number on the power supply would be your best bet in most cases. Good luck and have a great day. I buy power supplies as low as $15 dollars Generic
    Nov 11, 2009 | HP Computers & Internet
    I have a HIPRO HP-305 power supply. The green
    the 4 pin connector is for cpu power. the hipro power supply are not very reliable.
    Jun 14, 2017 | Hi-Pro (HP-P401W) (HPP401W) Power Supply
    When is the Hipro HP-A2007AE power supply cooling fan to be on?
    The fan should run constantly. It needs to be replaced. Otherwise the power supply will shut down when it gets hot. It can usually be replaced, but if the supply is cheap, just go out and get a new one.
    Mar 17, 2009 | Computers & Internet
    My SMPS burnt before 1 month.I want a new one.HP COMPAQ cabinet does not fit with ordinary SMPS.So plz help me
    Please contact your nearest HP Service Centre or call HP helpline for a replacement as it would be under warranty.
    Jan 19, 2009 | Hi-Pro Hipro 200W ATX Power Supply p/n...
    Hi-Pro (HP-P401W) (HPP401W) Power Supply Logo
    474 people viewed this question
    Top Hi-Pro Computers & Internet Experts
    danielle yancer
    danielle yancer
    De ice
    De ice
    Are you a Hi-Pro Computer and Internet Expert? Answer questions, earn points and help others
