Question about HP Office Equipment & Supplies
Print cartridge is missing or not detected but is there
It says cartridge is missing or not detected but it is installed
dumbtrucker
  • 102 Answers
SOURCE: keep getting message "Print cartridge(s) missing or not detected"
If these are new cartridges then you can try wiping the contacts and the pins with a dry paper towel then re install them. do not us tissue as some of them have lotion on them. If these are remanufactured cartridges return them for an exchange.
Posted on Mar 24, 2009
Roop1980
  • 228 Answers
SOURCE: print cartridge missing
Please remove the cartridges from the printer. Take a dry lint free paper towel and gently wipe the contacts on the back of the cartridge (not the bottom from where ink is present). Wipe the contacts inside the printer (on cartridge carrier). Please snap the cartridges back into the cartridge carrier.
Next, try this printer self-test by following the steps given below:
1. Please turn OFF the printer.
2. Press and hold the "Color copy" button.
3. Now, turn ON the printer.
4. Once you see "0" on the display, release the "Color copy" button.
5. Press the Up arrow button until "2"appears on the display.
6. Press the "Black copy" button to start the self test. Once the page has printed, the printer will stop printing.
The self-test should at least print out a set of either black or color bars, if not both (if you have a printer with both color and black installed simultaneously). Should this test fail, try it again without cartridges installed. If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service. If the self-test completes without any cartridges installed, run the self-test again with the color cartridge installed by itself. (If you have both black and color cartridges, after this test, run the test again with just the black cartridge installed.) If you find that either cartridge causes the self-test to fail, please let me know.
If the self-test prints, but has lines or smudges or other print quality issues, let us know. This includes any print quality issues, we need to know if the problems you have with your black or color are based in the printer, or communications with your computer, or the computer's software.
If the self-test prints your test bar(s) clearly, the printer hardware is not at fault.
Posted on Apr 14, 2009
SOURCE: print cartridges missing or not detected
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Please try follow these steps to resolve your issue:
  1. Take the ink cartridges out of the printer.
  1. Turn off the printer and wait a few minutes.
  1. Turn the printer back on and insert the cartridges, and make sure that cartridges are properly inserted in place.
  1. If problem still persists, clean the ink cartridges.
Are you using OEM, compatible or refilled ink cartridges? Refilled ink cartridges have a high defective rate, and they may also damage your printer, so it is best to use high-quality print cartridges. OEM and certain brands of compatible print cartridges (such as MSE brand: http://www.dependablesupplies.com/search.php?search_query=MSE&submit_search=Search) are the best choices.
Posted on Oct 12, 2009
  • 46 Answers
SOURCE: HPPhotosmart C4250 mgs "Printer Cartridge missing or not detected
There may be debris that is blocking the communication between the cartridge and the printer, especially if you are using a remanufactured cartridge. Remove the cartridge and unplug the printer from the power supply. Take a little bit of rubbing alcohol on a cotton swab and wipe off the contacts on the cartridge as well as the contacts inside of the printer. Allow both to dry for a few minutes before plugging the printer back in and re-installing the cartridge. This should clear up any miscommunication between the two.
Posted on Mar 15, 2010
  • 5479 Answers
SOURCE: The print cartridge missing or not detected light
There are several things you can try. Make sure you are using HP original cartridges (not refilled/remanufactured).
Remove the cartridges and reinsert them.
Clean the contacts on the cartridges (remove one cartridge (unplug the unit after the cartridge carrier stops moving), wipe it with lint free clothes or cotton swabs that were dampened (squeeze or wring out excess water) with bottled or distilled water. Wipe the copper colored contacts until they are ink free. Avoid the nozzles. Allow to dry for 10 minutes or dry with another cloth. Then reinstall the cartridge (make sure it clicks into place) and repeat with the other cartridge. Work quickly, after 30 minutes you have an increased risk of the ink drying and clogging the nozzles. Plug in the printer and see if you can print.
Reset the printer. Turn on the printer, then unplug the power cord from the wall. Remove the other end of the cord from the printer. Wait 20 seconds before plugging in the power cord (wall outlet first). Turn on the printer and wait for it to initialize. Try printing again.
Try new cartridges and do a cartridge alignment. The problem could be with the cartridges themselves.
If the issue persists, then the printer needs service.
I hope this helps.
Posted on Aug 06, 2010
Missing color ink cartridge...have full black cartridge...Printer won't print.
Hello, this is to be expected . You will need to have all cartridges installed and with ink in, even if you only want to print in black, or the printer will detect an error and won't work.
Regards,
nicam49
Jan 26, 2011 | HP Photosmart 3180 All-In-One Printer
I have installed colour cartridge 351XL and black 350 cartridge but my printer still says Print cartridges missing or not detected
Have you removed the shipping tape from the print cartridge? It covers the print head on the cartridge to protect them so they won't leak ink.
Nov 01, 2010 | HP Photosmart C4280 Aio Printer
Print cartridges missing or not detected message
I tried to solve this problem but still persist
Mar 22, 2010 | HP Photosmart C4280 Aio Printer
I have a problem with my hp c4380. Says print cartridge missing or not detected?
Feb 23, 2010 | HP Office Equipment & Supplies
HP Officejet printer, says cartridges are missing or not detected
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.hp.com/printer/prob676ijt65/solution
astrtr11
Aug 13, 2009 | HP Officejet 5610 All-In-One InkJet...
Printer won't print-says color cartridge is missing and it is there
Just a shot in the dark, was it a refilled ink cartridge. I know HP has a problem detecting the remanufactured cartridges from time to time. And too, if it is not refilled cartridge perhaps you just have a bad cartridge.
Oh, of course Julie remembered to pull the tape off of the bottom of the ink cartridge, correct?
Hope this did some good, please leave rating,
thank you kindly.
Apr 27, 2009 | Lexmark X2470 All-In-One InkJet Printer
Keep getting message "Print cartridge(s) missing or not detected"
Mar 21, 2009 | HP PhotoSmart C4280 Laser Printer
Printer 4355show in message
may i know if the INK that you are using is a HP genuine ink cartridge??if it does clean the copper contacts on the printer and try to check also if the ink cartridge that you are trying to insert is the compatible ink cartrdiges of the PRINTER
Sep 03, 2008 | HP Officejet 4355 All-In-One InkJet...
Can't install lexmark x4530...get spooler subsystem app has encountered a problem,etc.
Print Cartridge(s) Missing
The following print cartridges appear to be missing, not detected, or incorrectly installed:
Cartridge on Right
Cartridge on Left
May 21, 2008 | Office Equipment & Supplies
Light is flashing
check cartridge compatibility first:- HP Deskjet 810c HP15................black cartridge compatibility HP 23 ....................colour cartridge compatibility Issue ---A print cartridge is missing. Solution Install the missing cartridge. Issue --The printer detects a faulty, incompatible, or improperly installed print cartridge. Solution 1. Open the top cover of the printer. 2. Make sure the correct print cartridges are installed. Click here to go to the printer/cartridge compatibility chart. 3. Replace or reinstall the print cartridges. 4. Close the top cover of the printer. Issue ---The print cartridge contacts are dirty and the printer does not recognize the print cartridge. Solution Clean the contact points on the cartridges with a dry, lint-free cloth. 1. Open the top cover of the printer. 2. Remove the print cartridges. 3. Clean the copper-colored contact points on the cartridges with a dry, lint-free cloth. NOTE: Do not wipe the nozzle end of the cartridge or touch the silver-colored nozzle plate on the bottom of the cartridge. 4. Use a dry, lint-free cloth to remove the moisture from the contacts. 5. Insert the cartridges back into the printer. 6. Close the top cover. 7. Try printing again.
Sep 11, 2007 | HP DeskJet 810c InkJet Printer
27 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
