Question about GPS
GPS is taking a long time to connect to a satellite. Is this normal or something I should have my product replaced for?
  • 36 Answers
Well, the TomTom's now have a 'QuickGPS Fix'. To download this, connect your TT to your computer and download and install HOME (www.tomtom.com/home). When HOME checks for updates for your device is automatically downloads the quick gps fix as well.. once every 7 days, I believe.
Posted on Jan 10, 2009
Why does it take a long time for a satellite
Yes, sometimes it takes a long time to find a satellite, works best when it is fully charged, then it finds the Sats quickly
Jun 01, 2014 | Tomtom ONE 3rd Edition GPS
Garmin Nuvi 360T won't find satellites
Please try going outdoors in to a clear area and walk around for a while to see if you get a satellite lock, it might take a moment.
Jun 23, 2008 | GPS
GPS Garmin 1450 poor satelittle signal- can't find satelittloes
If the Garmin nuvi 1450 could find satellites at the same location and time before there's something wrong with the built-in receiver / antenna. Because it's not accessible from the outside it needs to be opened to check the antenna connections. Best is to check battery at the same time and replace it - once the problem is fixed.
At some locations there can be poor GPS sat reception - due to line of sight obstructions, such as trees, buildings. For a 2D fix it needs to "see" at least 3 satellites signals.
Jul 05, 2011 | Garmin nuvi 1450 GPS Receiver
When I turn my device on indoors, it won't pick up a signal. Also, I can be out in the car or in the plain open field and when powering up my device, it always seems to take a very, very, long time to...
GPS needs to "see" the GPS satellites to work normally. When you are outside the GPS is capable of seeing those satellites. GPS works with something called triangulation principle to get a position fix. Simply put a GPS needs to see at least 3 satellites to work. Even when inside a car, the GPS sees 5 to 8 satellites (or more) at any given time through the windshield and windows. When you go inside a house, GPS would not be capable of seeing enough satellites. And on top of it GPS do not like it, when the SNR (signal to noise ratio) is not at an appropriate level. The program inside the GPS may be in such a way to reject those satellites to give you more accuracy. So GPS goes into a search loop to get more reliable satellites. It is best not to switch on a GPS inside a completely blocked out room. If you have to work on a GPS inside a room, place the GPS near a window and open the curtains. Also make sure there are no trees just outside those windows that completely block out the sky. Once you have acquired some satellites by keeping the GPS on for a few minutes outside in the open and switch it off before you go inside a room, next time onwards yours GPS should acquire a lock much faster.
May 03, 2010 | Garmin nuvi 250W GPS Receiver
I have a garmin 260 and lately when I turn it on it takes a very long time to acquire satelites.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} As GPS units are used, data is gathered which helps them acquire satellites quickly at the start of each use. If a device is used daily it should be able to acquire satellites in a minute or less. Using a GPS device while it is outdoors with a clear view of the entire sky is the ideal condition for acquiring satellites. Please know that there can be several different factors that may cause a GPS unit to not acquire satellites:
  • If your unit is trying to acquire satellites for the first time, it may take longer than normal to establish an initial position. If the unit is powered on and outdoors with a clear view of the sky this should not take more than 3-5 minutes.
  • If your unit has not been used for an extended period of time (more then a month), it may take 3-5 minutes to acquire satellites.
  • If your unit is indoors, it may not acquire satellites. Even standing next to a window indoors will block a majority of the sky which is needed for a device to locate and lock onto a satellite signal.
  • If you have just finished updating the software in your unit or you have performed a master reset, your unit may take 3-5 minutes to acquire while outdoors as the data that is used to locate satellites may have been erased.
  • If your unit has traveled over 500 miles while turned off or not tracking your travel, it may take 3-5 minutes to acquire even in ideal conditions.
  • If your vehicle has a protective coating on its windshield or electronic devices which interfere with the unit receiving signal, your unit may need an external antenna* in order to acquire satellites.
    • If you suspect this to be an issue, try taking the unit outside of the vehicle with a clear view of the sky for 3-5 minutes so that the unit can acquire satellites. If your unit loses satellites once moved back into your vehicle you will most likely need an external antenna*.
If your unit is still having trouble acquiring satellites, please ensure that it has the latest version of operating software by using our WebUpdater program. Once your unit is updated please allow the unit to acquire satellites outdoors in a stationary position with a clear view of the sky.
*Note: Some units may not be compatible with an external antenna. Please check the Products tab on the external antenna's page to see if your unit is listed.
Jan 16, 2010 | Garmin nuvi 260W GPS Receiver
I takes close over 3 minutes for my garmin 765T to locate a sattelite and I leave in a major east coast city. is something wrong with the system or is this normal
Holding the satellite signal strength indicator icon (upper left hand corner of screen) for a few seconds with your finger brings up a visual display showing signal strength of various satellites, accuracy, speed and elevation.
From a cold start - I too have experienced 2 to 3 minute wait times for satellite aquisition, so I would presume this is a normal. I own three different Garmin units apart from the 765T and satellite aquisition times vary on all three, most aquire satellites in under 4 minutes. Traffic on the other hand seems to take a while to load as this is dependent on availability in your area.
Nov 30, 2009 | Garmin nuvi 765T GPS Receiver
Why does my GPS system have a difficult time locating satellites?It says ''acquiring satellites'' for about 5 minutes. Then it says it can't locate satellites. Should it continue trying? Why does it do...
this is what my navigon says about gettting the gps to connect.
Initializing the GPS receiver
In the upper right-hand corner of the display, the GPS symbol appears. As soon as
data from at least 3 satellites is received, the symbol changes to (GPS Ready). Note: If possible, position the device with a clear line of sight to the sky to successfully
receive messages from the GPS satellites.
Note: GPS initialization requires data from at least three satellites. If GPS data is not
available, the receiver will not initialize.
Note: It can take up to 20 minutes to initialize the integrated GPS receiver for the first
time.
Note: Each time you turn on the device, GPS receiver initialization begins. When GPS
data is available, reception starts within one minute.
If the navigation device has been switched to standby for more than a week, the next initialization
can take up to 10 minutes.
Jun 19, 2009 | Garmin GPS
Hello i have the garmin 250 i had brought it on the water a few weeks ago and as soon as i got of the water it has a question mark and says aquiring satatiles but never picks up a signal and doesnt work...
Question: Why won't my unit acquire satellites?
--> Answer: There are a several different factors that can cause a GPS unit to not acquire satellites:
  • If your unit is trying to acquire satellites for the first time, it is normal for it to take a while to establish its initial position.
  • If you have just finished updating the software in your unit or you have performed a master reset, your unit may take longer than normal to acquire.
  • If your unit has traveled a long distance while turned off or not tracking your travel, it may take a longer period of time to acquire.
  • If your unit has not been used for an extended period of time, it may take a longer period of time to acquire.
  • If your vehicle has a protective coating on its windshield or electronic devices which interfere with the unit receiving signal, you may need an external antenna.
If your unit is not acquiring satellites, it is recommended that you place the unit in a stationary position where it has a clear view of the sky. In some cases it may be necessary to take the unit outside of your vehicle as certain vehicles inhibit the unit from acquiring satellites. As the unit receives signal from the satellites, it will begin to lock on to them individually until it has acquired enough information to establish your position.
If your unit is still having trouble acquiring satellites, please ensure that it has the latest version of operating software. You can do this using our WebUpdater program which can be found at the following link:
http://www.garmin.com/products/webupdater/howtoinstall.jsp
Sep 25, 2008 | GPS
Coordintates seem to ALWAYS be off by 20-50 feet
How are you determining your error? If you are comparing your position to a map and you are getting error consistently, it could be that your map datum does not match the datum set in the GPS. Without WAAS turned on, your error should be @15'. With WAAS on it should be @ 6 to 9'. If you are using the Sattelite screen to determine your error, remember that is just estimated error. Higher estimated errors can be caused by satellites that are blocked or not visible to the GPS, or poor satellite geometry. It is normal for example, to have more error in high northern or southern latitudes due to less satellites being visible. With good reception you should be able to see 8 to 12 satellites on your satellite page. Signal strength is also important, You can have a lot of visible satellites but if the signal is weak your error wil increase. The signal can be weakened by heavy tree cover or high objects such as buildings or mountains. Such interference is called signal path error. Another form of signal path error is when the signal gets reflected off something before it gets to your GPS. For example; you're in a canyon and satellite 1 is to the east of you. The eastern rim of the canyon blocks the signal from satellite 1, however the signal bounces off the western rim and your GPS then picks it up. Because it took longer to get to your GPS, the GPS thinks that the satellite is farther away than it really is, causing a postion error. (This would not show up on your estimated position error shown on the satellite page because the GPS does not know this is happening.)
When WAAS is turned on it takes a channel that would normally be dedicated to a GPS satellite. It's possible that turning off WAAS helped you because having an extra GPS satellite improved your geometry which improved your accuracy more than the corrections WAAS is designed to make. The next time your error seems high, check how many satellites are being tracked and how strong the signal is.
Feb 13, 2008 | Garmin eTrex Legend Cx GPS Receiver
Garmin Nuvi takes a long time to Acquire satellite
No. 98% of the time it took 45-56 seonds for your NUVI 660. Thats the compagny set up time acquisition and it did very well.
Be sur you had your flip antenna parallel to earth surface.
660 has THE BEST SIRF Chipset for acquiring satellite.
I had 2 NUVI 660 since 2 years. It work much better than those new 7xx series who it really took 2-3 minutes to acquire satellite.
Be sure you update your version to the last one.
----> https://buy.garmin.com/shop/store/downloadsUpdates.jsp?product=010-00540-00&cID=134&pID=400
Best regards
Jan 12, 2008 | Garmin Nuvi 660 GPS Receiver
GPS Logo
338 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
