Sharp copy machine model AL-1551 keep showing E 7 what should I do to clear it
  • mansosaccent Jan 10, 2009
    Is there any other advise (pressing the on button for 5 seconds) does he mean the one on the side of the machine
  • 818 Answers
E7-01 GDI Memory Board error (Graphical User Interface)
E7-03 Laser Output Error. Make sure the Right Side Door is closed securely...try turning machine off and back on to see if the fault will clear.
E7-04 CCD ('Charge Coupled Device' or 'photoelectric converter) white level error
E7-05 CCD black level error
E7-12 CCD shading level error
E7-14 ASIC communication error (try clearing by turning off and on...otherwise Main PWB is bad)
E7-15 Copy Lamp Problem
Posted on Jan 10, 2009
  • 470 Answers
Common E7 problems and background in copy or send mode usually indicate a bad power supply unit, There are time when sharp has a back -order on this Toner Cartridge(FO-28ND) you can buy a FO-26ND toner. It will work and fit very snug, will get your fax going temporary till you get the FO-28ND The yield on the FO-26ND if use on the FAX FO-2850 will give you less yield, but the objective is to get the fax going till you find the correct toner cartridges.
    Sergeant:
  • 378 Answers
E-7 error indicates an initialization problem in the optical cavity. The scanners are supposed to move back and forth at start up in order to detect the home pozition. For some reason this is not possible. Remove the exposure glass, unplug the machine (the scanner is connected to power even when the main switch is off) and try to move the scanner assembly see if there are any obstructions and remove if necessary. This error does not need to be reset from simulation mode.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 448 Answers
Unplug, wait 5 minutes, plug back in. Could be a boot up problem. Is the machine under warranty. Call a Sharp warranty center and they can tell you what the code is for free. If this has been found helpful, please list as such. May want to go live chat
  • bob collins
    bob collins Jan 10, 2009
    I would go with solution number 2 as this will give a repair for now.
    Sergeant:
    Novelist:
  • 326 Answers
Unplug the machine from the main ower outlet for some time and then plug it again .power on the machine by keeping the on button pressed for 5 seconds to clear the error.
    Sergeant:
  • 431 Answers
May in trouble in the software
  • nematics
    nematics Jan 10, 2009
    trouble will be in the embedded software
How to reset the alarm indicator drum cartridge replacement in my copier machine sharp AL-1217D and it is necessary to reset the machine if you install a new drum unit? please help.
to reset drum counter u have to go in simulation clear density clear density enter 24 press start button where u normaly press to make copy then enter 7 again press start button off your machine and back it on that,s it
Aug 28, 2013 | SHARP AL-1217D
Printer driver for sharp al-1551
You can download the printer driver from the Sharp WEB site.
http://www.sharpusa.com/customersupport/productdownloads.aspx
Apr 03, 2012 | Sharp AL-1551 Laser Printer
Sharp AL 1551CS copier flashing '4' 'H'. Will not clear. This is a stand alone unit, not connected to a computer. How do we clear
To reset the H4 condition on just about any Sharp AL series copier press the following key's in sequence and as quickly as possible (with 4 seconds for the first 4 keys)
Press "C" then the far left key (exposure mode) then the "C" key then the far left again.
So in other words C, far left, C, far left
Some model's use 2 other initial codes, so you may need to use one of these 2 alternate codes to get your display to go blank. The rest of the procedure is the same.
Alternate codes are: #, * , C, * or pound,star,C,star and also
#, Interupt, C, Interupt
If done correctly the display should go blank.
Now key in 14 as if you were going to make 14 copies.
Now press the print button.
The machine should reset and the code should be gone.
9 times out of 10 this is a false code that pops up due to power surges or noise.
If the code comes back this means you have a heater lamp or thermal fuse (more common) failure in the fusing area and will need service.
Good Luck and Thank You for using Fixya.
WheatlandServices
Jan 31, 2011 | Sharp AL-1551 Laser Printer
Reset drum counter on Sharp AL-1644
This works on MOST sharp AL series copiers.
Press these keys in sequence:
Clear → Density select → Clear→ Density select
display should go blank. Then enter:
24 as if you were making 24 copies then press print
then enter 7 as if you were making 7 copies then press print
if successful you should see flashing 000
turn machine off then on again and the drum light should be gone.
Good Luck
Nov 03, 2009 | Sharp Office Equipment & Supplies
E 7 error on the screen
You have problem with your laser unit ( LSU ), you should replace it
Jun 03, 2009 | Sharp Office Equipment & Supplies
Sharp AL 1551 CS RSPF not feeding
This can be a fault of the controller of the direct current. Apply to service This fault can be not eliminated by you.
Mar 23, 2009 | Sharp AL-1551CS Copier
Flashing ''4'' then ''H'' on my Sharp AL-1551CS
Disconnect printer from computer.
Switch on printer.
Type quickly: C "Auto" C "Auto", than 14 (number of copies) than "start"
"Auto" is the second button from the left.
Nov 16, 2008 | Sharp AL-1551 Laser Printer
Sharp al-1551
Did you replace the drum with a Sharp brand drum? I recently replaced a drum in my Sharp AL-1642CS, the replacement drum fits ok, and the lights you describe are gone now, but it does make an annoying noise that is new. I wish I would have spent the money to get a Sharp drum, then you can call them directly for support. When I have called them they have been very helpful.
Dec 14, 2007 | Sharp AL-1551 Laser Printer
282 people viewed this question
jasbo
jasbo
