Question about Garden
What is coil gap for stihl blower BG 75? - Garden
2 Suggested Answers
  • 257 Answers
SOURCE: Kill switch on Stihl BG 75 leaf blower not working
when engine cool,, spray wd 40 into the switch and work it a dozen or so times and clen it out
Posted on Aug 12, 2009
STIHL BLOWERS BG 56/C and BG 86/C
I don't have much experience with Stihl products but I do have a couple of disc cutters, both of which had a short life and suffered piston damage.
I suspect the air cleaner isn't as efficient as it should be.
Apr 26, 2017 | Stihl Garden
Coil air gap setting on stihl BG 85 C blower
The box the coil came in should have a paper card for setting the gap. It isnt written on the paper....it is the paper! Put it between the coil and the flywheel and bolt it up! If there isnt a gap paper in the box use a paper business card in its place. The stock gap size of 0.0125 inches is virtually the same as the 12 point paper used for a business cards in the US. I would recommend checking spark before reassembly just to be sure everything is right. Be safe and good luck!
Mar 08, 2015 | Stihl Garden
Gap setting for bpmr 74 for stihl blower bg 85
http://www.stihlusa.com/WebContent/CMSFileLibrary/instructionmanuals/BG-55-65-85-SH-55-85-Blower-Instruction-Manual.pdf
a quick search on google revieled that its details is in the manual
so here is a link to the manual
all else fails read the instructions lol:))
Apr 15, 2014 | Stihl Garden
Air gap setting ignition coil
if you didnt adjust it you dont need to know
it is the gap between the rotor for the pickup coil and the coil pickup face
the ignition coil makes energy from the rotator to feed the spark plug
you need to tell us what is up
your question is incomplete and lacks details
Dec 05, 2013 | Stihl Bg 55
Has sprak and new fuel pick line, filter ,carb still will not run
Clean carb and or replace diaphrams and needle or replace carb, sometimes it's cheaper to replace carb than to clean/rebuild it
Dec 01, 2013 | Stihl Bg 55
Bg86c stihl blower no spark new spark plug new coil gapped right take ground wire off still nothing
Sounds like a tricky one. Have you checked the magetism/functioning of the flywheel.? Tracking back the problem by having a new spark plug and coil would next point you to the flywheel. Coil to flywheel gap should be 0.25 feeler guage.
Hope this proves useful. :)
Mar 15, 2013 | Stihl Bg 86c Handheld Blower Cylinder...
Stihl BG 75 blower doesn't seem to have any spark
These units are very promt to gas fouling of spark plugs, try replacing plug. If you still have no spark then possibly the flywheel has a metal strip in it that is prone to rusting, especially if unit does not get used alot, can be cleaned up with 180 or 22 grit sandpaper. If this strip is rusted then coil cannot communicate & therefore you get no spark. Lastly if all above check out good then most likely you have a bad coil. If coil is to be replaced make sure to gap the coil away from flywheel by placing a peice of paper folded over between coil & metal strip-(magnet) coil will pull itself to strip, tighten bolts & remove paper, gap is set.
Nov 10, 2010 | Garden
Aug 12, 2009 | Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
