Question about Nikon COOLPIX L20 Digital Camera
Nikon cool pix s2550. Showing battery exhausted
What is wrong with battery and how can I fix it, it won't charge up
SOURCE: Nikon Cool Pix 5000 will turn on
your description says will turn on..but it looks like you describe will NOT turn on.. a dead unit.. ok, i have same issue and lucky enough to have TWO of these, the second one with a very different problem. I will troubleshoot between the two and get one working, will post results back here.. preliminary web search suggests unit has a DC to DC onboard voltage converter and DOES incorporate a fuse or more.. hopefully only a fuse is blown.
Posted on Jan 09, 2008
Obertelli
  • 3006 Answers
SOURCE: Battery door is broken cool pix 3100
No, but I do.
You're asking about that stupidly pathetic little plastic loop moulded onto the body, seemingly designed to break.
I've fixed a few of these now using carefully shaped and trimmed paperclip wire held in place using thirty minute epoxy resin. Longer setting epoxy is better if you're patient (essential if you're in a warm climate), but five minute epoxy is a definite no-no.
You'll need a pair of electrician's pliers (preferably miniature ones) with a wire cutter, a small craft knife/scalpel and a set of jewellers files.
Use the knife to cut of the stumps of the original tab.
Straighten out the first two bends only of a regular paperclip (the wire needs to be around 1mm in diameter).
Select a flat file of about the same thickness as the wire, and use the teeth on the edge to cut two small slots where the legs of the old catch used to be. Test the fit using the wire as a gauge.
Now use the pliers to reshape the final bend of the paperclip so that it's nicely squared off with sharp 90 degree bends. You may find that it takes a few clips to get it right. Lay the paperclip into the slots regularly as you do this to ensure that the width of the bent section is correct.
When you're happy with the fit, sit the wire right down in the slots to the correct height for your door to catch tightly.
This is when you'll discover that there are some reinforcing plastic webs (ridges) deeper in the battery chamber which interfere with the fit. Cut slots in them to allow the wire to sit flush. The longer leg of the wire will need to be shortened to around where the first bend in the wire used to be, leaving it around 5cm (2") long.
Now, if you have some, smear a little grease (or even margarine) anywhere that you don't want epoxy resin to stick. Test fit your clip once again, if you've made the slots really snug the wire will sit in place sufficiently for you to test the battery catch engages correctly to give you an idea of how the wire should sit when you glue it.
Use the file to roughen the wire legs and mix the epoxy resin. Using a suitable implement carefully fill the spaces in the strengthening webs through which the wire will pass. Don't just glue the slots, fill in the little squares bounded by the webs.
Apply a thin coat of resin to the legs of the wire, and then lay the wire firmly into the slots which you've prepared. Make sure that it sits flush and will not obstruct the batteries when refitted.
Wipe off any excess epoxy around the rim of the battery chamber and sit the new loop which you've made so that it's at the correct height to enable the battery cover to engage, but no so far out that the cover is a loose fit. The slow setting time of the epoxy will ensure that you have time to get this just right.
When all's well, leave the camera for around twenty four hours to allow the resin to cure. If you've used twelve hour resin then leave it for a couple of days. Shortly before the initial thirty minute/twelve hour setting time though, you may wish to make sure that the battery catch is fully open to make really certain that you don't glue it closed by accident.
When the glue has set, clean of any excess protective grease which you applied and fit the batteries. If you've taken the time to do the job carefully then you'll have a perfect repair to a truly brilliant camera. Even the 2.1 MP version, the Coolpix 2100 was capable of outstanding outdoor shots which I could print to A4 size.
If the loop is slightly loose, then you can usually carefully bend in the top of the loop to tighten it. If it's a bit tight you can usually loosen it a little by gently bending in the sides slightly to give the loop a bit more height.
Click HERE to see how the final repair should look. (Credit to www.uthunter.com for photo).
The same technique and materials can be used on the later Coolpix 2200 and 3200 models, but the wire is fitted to a slot cut along the rim of the battery chamber cover instead and shaping the wire is *much* more fiddly.
I hope that this has helped; all I ask in return is that you return the favour by rating my answer.
Note that a faster, simpler, but far uglier repair can be made by using a metal or plastic plate screwed into the tripod socket. See here for details.
Posted on Jan 12, 2010
  • 6771 Answers
SOURCE: My Nikon Coolpix S3000 says
The rechargeable battery probably needs to be replaced, I would take it to a camera shop let him have a quick look to make sure the charge light is coming on and try a new battery.
Posted on Jan 14, 2011
SOURCE: How come my battery wont charge on my brand new
We had this same problem...battery indicator light not showing and battery not charging. We found out by accident that if the battery cover is open, it won't charge. So open the battery cover, open the USB cover, shut the battery cover and then plug in the USB as normal. It worked for us, hope it will work for you too.
Posted on Mar 21, 2011
afterhourspc
  • 106 Answers
SOURCE: nikon s8000 coolpix the battery
if your charging it by usb from pc make sure it is directly into the pc and not into a usb hub...some usb hubs don't provide enough power to charge it.
Posted on May 08, 2011
Blank screen on Nikon cool pix s9100
This could be battery issue. however try the link below to fix this issue. This requires a bit of mechanical/technical work which you have to go thru.
Troubleshoot Camera Issue
Regards,
Suhail
May 16, 2012 | Nikon Cameras
Nikon Coolpix S8100 battery won't charge
I have had mine for over 3 years and this just started happening. I bought a new battery and it seemed to fix the problem for about a week but is doing it again. It seems like it won't fully charge now like it formerly did!
Apr 24, 2012 | Nikon Coolpix S8100 Black Digital...
Nikon cool pix s4100 won't charge.
Take the camera back to the place of purchase, should be under warranty and let them sort it out, at the very list they should offer a battery replacement.
Mar 14, 2012 | Cameras
Cool pix s4100 won't charge
If this is a brand new camera, take it back to the place of purchase and have it checked, if battery is used then it will need to be replaced.
Mar 14, 2012 | Nikon Coolpix S3000 Digital Camera
My Nikon Coolpix S2550 says the battery is low when I need to use the flash - but I have fully charged the battery please help
try leaving the camera on to drain the battery down, then try charging it again.. or could be a bad battery
Dec 30, 2011 | Nikon Cameras
Camera turns off itself
This is likely because:
  1. You are using the wrong types of batteries (Alkaline, Ni-Cd or Ni-MH batteries are recommended for digital cameras) NOTE: don't mix different types.
  2. The battery is out of charging cycles and won't retain charge. (Most rechargeable batteries can be charged only about 1000 times after which they won't hold charge)
  3. The batteries aren't 'powerful' enough. (low quality rechargeable batteries with low capacity shouldn't be used on digital cameras, Always buy batteries specialized for cameras (from camera stores or studios))
  4. The wrong battery type is selected in the camera's settings. (Most cameras let you select the type of battery you are using from it's settings. Browse through the settings and see if this is the problem)
Hope that fixed it. Good luck.
Apr 28, 2011 | Nikon COOLPIX L4 Digital Camera
Battery exhausted
ur battery is gettting weak it is not supplying enuff power is it in built re chargeable proprietory batt or its a normal AA or AAA cells let me know for more help , pls try replacing it
pls do rate me if i fixed ur problem
Feb 27, 2009 | Nikon COOLPIX L18 Digital Camera
Nikon cool pix L11lens error
Remove the battery, wait a couple of minutes, replace battery. (assuming the battery is fully charged. Check there is nothing jammed in the mech. if it still stays stuck.
Dec 30, 2007 | Nikon Coolpix 5700 Digital Camera
Nikon COOLPIX L20 Digital Camera Logo
76 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
