Speechexec pro dictate freezes with speechmike iii
3 Suggested Answers
  • 13433 Answers
SOURCE: Loss of words during reording
I suggest that you allow little more silent time before pressing the pause or stop. also when you start regording again let it go for a second or two and then start talking.
you may also tap the mic pefore starting speaking, performers always tap the mic pefore starting to make sure its working.
Posted on Jun 18, 2008
SOURCE: Can I use Speechmike Pro 6274 with Macspeech/Dictate
use the software "usb overdrive"- it lets you configure all buttons customarily. works fine! assign shortcuts from macspeech or applescripts from actions. only my magic mouse didnt scroll any more. I installed magicdriver from plentycom.jp then for my magic mouse. It's much better than the original driver anyway!
Posted on May 15, 2010
Jun 18, 2008 | Philips SpeechMike Pro Plus 5276 Handheld...
Our 9500 series Philips digital pocket memo will not clear the old files when complete. As a result, we are unable to download new files. Any help would be appreciated. Thanks! Jill
Hello You need to Use Philips SpeechExec software for automatic
download, conversion and routing of files
recorded with a Pocket Memo dictation
recorder. How and which files are downloaded after a
recorder is connected can be configured in
the settings menu of SpeechExec or with the Configuration Wizard
Configure the download process
from the Pocket Memo
Pocket Memo is connected can be configured in
the settings menu or the Configuration Wizard.
1 Connect the Digital Pocket Memo to the PC
using the USB cable.
2 Click Settings > General Settings on the
menu bar, select DPM/DT Configuration >
DPM Settings from the list on the left side.
3 Click the Start... button. The DPM configuration
dialog is displayed in a new window.
4 Select Download in the left pane.
5 Select which files will be downloaded
(download file type):
• All files
• EOL (recordings marked as finished/endof-
letter)
• File selection (SpeechExec prompts the
selection of specific files to be downloaded)
• File with keyword 1 (specify a keyword)
6 The download settings also allow the user
to specify if files will be deleted on the
Pocket Memo after they are downloaded.
7 Click OK to save the settings and confirm
the transfer of the new settings to the
Pocket Memo.
Apr 05, 2011 | Philips Pocket Memo 9500 (256 MB 1 Hours)...
With have Dell Optiplex 780 PC and have problems
It's known! The bad news is that the only way to make sure the device is recognized is to attach it through an external USB-hub (it requires 300 mA continuosly, and you can only trust the PC to allways deliver 100 mA - allthough USB 2.0 must be able to deliver 500 mA at occassions).
You should also disable any other sound devices, like built in Realtek, SoundMax etc.....
May 06, 2010 | Philips SpeechMike Pro 5274 Handheld Voice...
Textual serial key for SpeechExec
We do not provide serials, keys or authorization codes on this site, For Problems with it contact company you bought it from. Please read the Terms - http://www.fixya.com/terms
Jul 14, 2009 | Philips SpeechExec Pro Dictate Full...
Sorry, the Philips line for Mac support is: "the market is not big enough". Appauling isn't it?
Mar 18, 2009 | Philips SpeechMike Pro 6274 Handheld...
My windows vista crashed and I had to reinstall it. All my programs were erased with the reinstall and so I am now reinstalling my speechexec pro transcribe, but it is rejecting it saying the serial no. is...
Philips SpeechExec Pro Transcribe doesn't have a serial number type licensing; it uses Dongle or SmartKey licensing, a physical device attached to a USB port on your machine.
However, if your software was version 5, and you had a SmartKey license (it is black, like a memory stick, with a red barcode), you might have downloaded the license from the SmartKey to your PC, an option which is handy to release a USB port, but which obviously proves costly if your PC crashes.
If this is the case, uninstall the software, and reinstall it; during re-installation, choose to run the SmartKey Wizard, and make sure your SmartKey is connected to the PC; the Wizard will recognise that your license has been downloaded, but it will give you a 30 days grace, during which you can use the software. Incidentally the Colour of the LED on the SmartKey will change from Amber to Red.
You then need to contact your Philips equipment provider, and explain that your PC crashed and you lost the SmartKey license in the disaster; if they are proper suppliers (MDCi or MDCe), they will ask you to send the SmartKey, and will send you a new one...
I hope this helps!!
Jan 15, 2009 | Philips SpeechMike Pro 6277 Desktop...
Repair for Philips speechmike pro LFH52774/00
We had the same problem with our speechmikes,
If you are based in the UK,you can send them to a company called premicom.They fixed ours for a fixed price of £35 each plus vat.
They were very quick to repair and we had them back in a couple of days.
Dec 19, 2008 | Philips SpeechMike Pro Plus 5276 Handheld...
Won't playback or transcribe
2 things to check:
1. is the speechmike set as default playback device: go to Control Panel--> Sounds and Audio Devices; and in the opening window, go under the Audio tab; in the Sound Playback, the default device should be set to SpeecMike II if you want the sound to come out of the SpeechMike.
2. Playback volumes: still in the same tab, click the Volume button of the default device; it opens a set of volume controls; you need to ensure that for the WAVE, and Speaker (or Volume Control), the Mute box isn't ticked; you also want to set this volume to something not equal to zero (i.e. move the cursor up to at least 1/3 of the level).
I hope this helps.
Sep 01, 2008 | Philips SpeechMike Pro 5274 Handheld Voice...
49 people viewed this question
 Grubhead
Grubhead
