Question about Whirlpool MH3184XP Microwave Oven
Where's the fuse?
Took off control panel per instructions on other posts, but still don't see fuse. Model MH3184XPT. Don't see it referenced on any of your diagrams.
    Problem Solver:
  • 4 Answers
Yup, I had the same problem. The unit just stopped working. I gather that this is a common problem with this model. I followed other posts elsewhere, and found the fuse behind and near the top of the control panel. There's a white, cylindrical plastic thing about 1.5-in long in one of the wires that run down from the main fuse in the upper right corner. Pop open the case (you may have to cut a plastic tie around it). I replaced the fuse. My microwave is working now. We'll see how long it lasts.
It's hard to tell what kind of fuse it is, but reading elsewhere, it's a 250V 4A 5x20mm slow-blow fuse.  I haven't found a ceramic one just like came out, but a 4-pack of glass fuses that fit the specs are $3 at Radio Shack. PN 270-1066. (No endorsement implied, it's just where I found something that worked.)
No, the fuse in question (and there appears to be another like it lower behind the control panel) isn't on any of the diagrams or parts lists.
Posted on Apr 04, 2009
  • DKG8143 Jan 15, 2011
    My problem was solved by replacing the ceramic fuse on the upper right hand corner of the microwave above the control panel. I had to take off the grille on top of the microwave and take out a screw at the bottom of the screening in front of the fuse. The ceramic portion of the blown fuse was a brownish color because it was blown; new ones are white. I would imagine the coloration allows a technician to more easily see if the fuse it blown without taking things apart.
    I bought a four pack of the ceramic 250V 20A fuses for microwave ovens from Radio Shack for around $3 Model: 270-1041 (as mentioned above, no endorsement, just where I found them).
Model 1880LS. How do I replace the fuse?
You will have to remove the outer cover. You should be aware that doing so exposes you to potentially lethal voltages, even with power disconnected.
Dec 24, 2015 | Sharp Microwave Ovens
In oven the start button is not working
see the details and fix it. God bless you
Touchpad and Control Panel If the microwave buttons don't work the touchpad and control panel assembly are probably defective.
Touchpad If the microwave buttons don't work the touchpad might be at fault. Generally speaking, if the dishwasher display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
User Control and Display Board If the microwave buttons don't work the main control board is most likely defective and will need to be replaced.
Main Control Board If the microwave buttons don't work the main control board is most likely defective and will need to be replaced.
Nov 15, 2012 | Whirlpool Microwave Ovens
I want whirlpool oven mechanic in kakinada
see the details and proceed according. fix it. God bless you
My microwave keypad wont work the light is on and the reading says please touch clock and set time of dry
SEE THIS CAUSES AND FIX IT. God bless you
Touchpad If the microwave buttons don't work the touchpad might be at fault. Generally speaking, if the display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
Oct 01, 2012 | Kenmore 80809 Microwave Oven
I have GE JVM1540DN1BB microwawe. It beeps all the time and says "keypad sorted" and service needed. The beep sound is annoying and it beeps every 30 seconds
see this causes and fix it. God bless you
Oct 01, 2012 | GE Microwave Ovens
Maytag microwave keypad
Oct 01, 2012 | Maytag MMV4205 Microwave Oven
I have a whirlpool undercounter model # MH3184XPS-2 an has no power
On this model, this is usually a blown fuse or thermostat.
This model has three fuses, a 20A, a 4A, and a .25A and three cavity thermostats.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
mini_manual_behind_grille_small.jpgdee77f7.jpgAt our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Accessing the cavity thermostats for testing and possible replacement will require you to remove the oven from the wall.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
If for some reason you don't still have yours, you can download Whirlpool owner's manuals and installation instructions here.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
If none of the fuses or thermostats are blown, then the problem is probably on your control circuit board, which is especially common if you recently had trouble with your cooktop lights or exhaust fans.
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid with a one year guarantee.
Oct 17, 2011 | Whirlpool MH3184XP Microwave Oven
After Changing Lamps in my over the counter GE microwave they still don't work.Is there a fuse?
There is a fuse in GE models, but if that were blown, the oven would be totally dead.
If you prefer, you can buy a new control circuit board and install it. It's a pretty simple job.
here.
Oct 17, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Model pod712mw microwave doesnot work oven simply stopped working
If there is a fuse, it will be located inside the oven behind the control panel. Gain access to the panel and inspect for signs of fuse. If not, and the oven has no power whatsoever, for any function, and the power supply is good, then there will be a fault in the appliance somewhere. Most likely the brain.
Generally, the fuse is located in one of the panels on the front, behind the control panel/knobs. Keep in mind that a lot of stoves don't have the fuse no, its silly really. I reemmber in other customer problems that the problem was a temperature control regulator that had burned out,
Will need to check and re-check all internal components in your device.
Hope helps.
Jul 14, 2011 | Microwave Ovens
Where is the fuse located
It would be helpful if you could reply back with your brand and model number, but I can give you a good answer without it.
First of all, this won;t be a problem with the fuse. When a microwave's fuse blows, the unit will be dead.
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
If you someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
If yours is not listed, please reply back with your brand and full model number.
If you think the problem is on the control panel, which we repair these nationwide by mail for $39.95 postpaid.
We're happy to help and we appreciate your thoughtful rating of our answer.
Mar 25, 2008 | Microwave Ovens
Whirlpool MH3184XP Microwave Oven Logo
764 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
