Question about Plantronics CS55/HL10 Wireless Office Headset System with Lifter 69702-01 Headset
All of a sudden my CS 55 with plantronics stopped working. It shows that its on but the headpiece isnt charing and also doesnt work. Any ideas why?
  • 83 Answers
If the Plantronics CS55 wireless headset shows that it is on, you have to make sure of the following things.
a. the green LED on the base turns on when you turn the call switch on from the headset.
b. the small green LED on the side of the headset is blinking.
c. the telephone headset is lifted from the cradle.
d. if the headset is not charging and the Amber light on the base does not blink when you place wireless headset on it; trying placing the headset more firmly.
e. If the headset is not charging and the Amber light on the base does not blink even after placing the wireless headset firmly on the charging cradle, you may need to change the battery.
Alternately you can try resetting the Plantronics CS55 wireless headset.
Reset Plantronics CS50, CS60 or CS55 Wireless Headset
If you have problems with the sound or connection of your Plantronics CS50, CS60 or CS55 wireless phone headset, you may want to try to hard reset it using the following steps:
Note: Ensure the IntelliStand switch (on the right side of the charging base) is in the - position and NOT the = position.
1. Press both the call control button and the listening volume/mute button for 5 seconds. When the indicator light blinks release both buttons.
2. Press the call control button again. The talk indicator light will again blink to indicate the headset is back to normal.
3. Disconnect the AC charger from the AC charging jack for 5 seconds.
4. Reconnect the AC charger.
Now give the Plantronics headset a try.
Posted on Jul 19, 2009
What if that doesn't happen?
Posted on Jan 21, 2012
What is the price of a headset
anywhere from $11
http://www.amazon.com/Plantronics-M214C-Headset-Adjustable/dp/B000ANOY7M/ref=sr_1_1?ie=UTF8&qid=1294360480&sr=8-1
to $170
http://www.amazon.com/Plantronics-CS-55-Digital-Wireless-Headset/dp/B000C12GH2/ref=sr_1_3?ie=UTF8&qid=1294360480&sr=8-3
Jan 06, 2011 | Panasonic KX-T7730 Corded Phone
I was using the headset for nearly a half year now and it suddenly stopped working i can listen but my microphone isnt working
Probably one or more of the strands of wire in the mic cord have become damaged. If you are still within the 1-year warranty, take it back to your retailer for warranty replacement or call Plantronics at 800-544-4660 x5 x5538 for warranty service.
Good luck from Headsets Direct!
Nov 01, 2010 | Plantronics GameCom 367 Closed Ear Gaming...
Toshiba laptop with IOgear bluetooth adapter installed will recognize phone but won't detect plantronics explorer headpiece. I would like to use it to chat on skype
If the Bluetooth adapter can detect the phone but not the Plantronics headpiece, then there's no problem with your computer or your Bluetooth adapter. The problem has something to do with the Plantronics.
Try to turn the headpiece off, then turn it back on. Set it to discovery mode, then try to detect it using your computer. If that did not help.
Try to detect the Plantronics, using your phone. That will help you in isolating the problem.
Aside from that, make sure that no possible wireless interference while you're searching for the headpiece. Cell phone, base of the cordless phone should be away from the computer while you're searching for the headpiece. Because Bluetooth and cellphones/cordless phones are running on the same 2.4GHz frequency RF signal. They might interfere with each other.
Apr 14, 2010 | Plantronics Explorer 220 Bluetooth Headset...
Hi, I have a plantronics CS60 that was working until a few days ago.I made sure it fully charged for the owner last night after it was reported faulty. The green light does not go on for the wireless...
Plantronics CS60: Hard Reset.
NOTE: Before re-subscribing the system make sure the IntelliStand switch (on the right side of the charging base) is in the "_" position and NOT the "=" position.
2. Press the call control button again. The talk indicator light will again blink briefly to indicate the headset is back to normal.
4. Reconnect
Jul 29, 2009 | Plantronics CS60 Professional Headset
Plantronics voyager 510 headset
Make sure the headpiece is charged. Turn the headpiece off by pressing the little black button on top of the earpiece and holding for about 5 seconds. Turn the earpiece back on again the same way. You should have a slow flashing blue light on the mic boom. The base station will now try to find the earpiece and within about 20 seconds the red light on the base should be steady and blue light on top should be on.
If this doesn't work you may need to manually pair the earpiece to the base by pressing and holding the Listen Volume Adjust + Button and headset Call Control Button on the earpiece until the light on the mic boom flashes red and blue repeatedly. As above, the base station will now try to find the earpiece and within about 20 seconds the red light on the base should be steady and blue light on top should be on.
Nov 05, 2008 | Plantronics - Bluetooth Headset Plus Base...
Lost manual
Since it was already paired with your cell phone it should show up in your phones bluetooth device list, it should be as easy as navigating to the bluetooth settings in your phone (usually found in tools) and selecting the Voyager 520 and selecting the connect button. Give it a try as I have to reconnect mine periodically also.
Aug 07, 2008 | Plantronics Hama Voyager 520 Bluetooth...
220 Plantronics stopped working
Look under my name and find the previous 10-20 posts helping others with similar problems on adding/removing the existing connected device. However the Plantronics 220 Express and regular have connection problems with phones if they are far away, and sometimes get corrupt, unfortunately, for a $28.00 headset, its build for $28.00 of use.
Please review my previous posts and see if this can help you at all..
ManOwar
Aug 05, 2008 | Plantronics - Bluetooth Headset Plus Base...
Sny ericson w850 and plantronics 340 not communicating
MIne connects to my phone and tells me it is connected but i do not get the headset picture on my mobile anymore, and when i make calls it isnt connected I still have to pick my phone up and use that..
Why should I have to do that when I bought it for that specific reason, I bought a Blueant one and it works perfect for three months..
Fix you problems plantronics and STOP using computer generated feedback!!!
And get someone with more than half a Brain to sort this out.
Nov 17, 2007 | Plantronics Explorer 340 Wireless Headset
Plantronics CS55/HL10 Wireless Office Headset System with Lifter 69702-01 Headset Logo
1,851 people viewed this question
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
shaun taylor
Michael Vincent Cruz
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
