Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Removing water despenser on Kenmore 79575196401 fridge
I need to remove the front panel of door water dispenser in my Kenmore 79575196401 side by side fridge. The fridge i beeping randomly and changing the temperatures. I already changed the main board and now think it has to be bad or dirty contacts on the control panel. There are no screws on it and I don't want to break it, so I am looking for instructions on how to remove it.
    President:
  • Kenmore Master
  • 2,651 Answers
This is an LG made machine, ther eis no simple way off, youll need to pry it off form the edges, no screws hold it, merely plastic tabs and pressure. I hate this dispensor for this reason , but the dozen or so i removed, i havent broken any yet. pry slowly and youll get it
Posted on Jan 11, 2009
GE Mongram Model# ZISS420DRJSS replacing ice despenser flap
You are correct, The door panel would need to be removed to access the dispenser. Be-careful of the ground wire and the waterline that is/will be exposed when you removed the panel. they are easily damaged if your in a rush when removing the panel. Remove all screws, start removing panel on hinge side first (thats where the waterline and ground wire is) then it will come off easy. Good luck
Sep 11, 2014 | GE Refrigerators
I have a Kenmore side by side fridge with ice/ water dispenser in the front door. When I push the water dispenser the water comes out the spout but also some comes out behind the spout making a mess. Is...
sounds to me that the line inside of the door is cracked. Their is no easy way to repair that, either the entire door must be disassambled to replace that line,or replace the outerdoor panel with the line embedded into it,to replace the door panel it requires transfering all the compentents fmor old to new door panel, a partial list of things that must be transfered parts from old to new outer door include but not limited to
inner door panel
door gasket
dispenser asm (which cant come out as one piece and must to disassabbled into appx. 20 parts)
wiring
hinges
door handles
Jul 26, 2011 | Kenmore Side by Side Refrigerator
Electrolux side by side door refrigerator. White
This can be pulled out of the door and replaced with new tubing.You may need to remove the front dispenser panel in order to get the tubing out of the dispenser.
Once you do that then you can pull the remove the tubing and replace it with new line.
Jan 01, 2011 | Electrolux 25.9 Cu. Ft. Side-by-Side...
My brother moved and the movers removed the side by side doors
The dispenser assembly comes apart from the front. It should give you access to the waterline as it comes up from the bottom.
Eric
Jan 19, 2010 | Amana SXD524VW Side by Side Refrigerator
Water Dispenser leaks from rear of fridge
the answer to the problem is behind that back panel.
Nov 23, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Water dispenser not working on my Kenmore fridge
NO,YOUR RIGHT YOU NEED TO REPLACE THE WATER INLET VALVE ON THE LOWER BACK OF FRIG.-MIKE
Mar 01, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
My Frigidaire refrigerator water dispenser leaks water inside the door, the water runs down the front of the door from the bottom of the front panel. How do I remove the panel to repair or replace the...
lift up & out on the drip tray (it will come out) after removing it you will see 3 screw. unscrew the screws & lift the face plate of the despenser & it will come off. Be careful though. There is a ribbon wire connected to the back of the face plate. make sure to dissconect the ribbon wire from the control board not the back of the face plate (its alot harder to reconnect to the face plate & pretty simle to reconnect to the control board).
May 11, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Kenmore Side by Side Model 253-56953601
does it have a lockout on the despenser area that you can push to reactivate the despenser
Apr 06, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore refrigerator
1. Remove the switch cap and unsnap the two (2) tabs at the bottom of the front cover from the
housing first. Pull the bottom out and lift and the front cover from the housing. (Fig. 27)
2. Remove the two (2) hex-head screws securing the metal control panel cover to the dispenser
housing. This will also free the control bracket from the housing although it will remain tethered
to the freezer door by the wiring harness. (Fig. 28)
3. Disconnect the wiring harness connectors from the terminals
on the switches and light fixture in the control bracket.
Removing the Dispenser Assembly
1. Do the previous three procedures.
2. Remove the eight (8) hex-head screws securing
the dispenser housing to the freezer door. (Fig. 29)
3. Carefully pull the housing from the door.
4. Pull the water supply tube from the top of the dispenser housing.
5. Pull the wiring harness leads from the dispenser housing.
6. Disconnect the wiring harness connectors to the electric
foil heater that should get you in there
Feb 17, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Sears Kenmore Refrig #363-9554710 (side by side) - Remove panel on left front to access funnel guard
You will need to unplug the fridge or unplug the wires going to the dispenser from behind the grill at the bottom of the fridge.
Pop off the front cover over the switches and pop off the soft button cover that you mash to activate the dispenser.
You will see the screws that hold the dispenser assembely to the housing. remove them and the unit will slide toward you.
Post back if you need more help, I may have forgotten a step somewhere.
Oct 30, 2007 | Refrigerators
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
198 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
