Question about Kenmore 72802 Gas Dryer
Pilot light Can someone help! I can not find where to light the pilot light on my Kenmore 72802 Gas Dryer. There is a square removable cap on the front of the dryer but I'm not sure if this is it. I can't find my manual or instructions for lighting on the web.
  • 1 more comment
  • Rich Paramus Jun 06, 2007
    Your right I'm not the handiest guy around ...I'm thinking like ny burner for my heating system.
    OK I guess it's the glow ignigtor thats not working properly. There's no heat in dryer at all.
  • Rich Paramus Jun 10, 2007
    The dryer is about 3-4 years old. Will not heat up. How do I check if this glow thing is working or not?
  • Anonymous Jul 26, 2008
    location of gas ingitor
  • 5,911 Answers
Pilot Light? Are you sure? All the gas dryers I've ever worked on were pilot-less. There should be a glow-type ignitor that heats up when the dryer is turned on. When it reaches a certain current potential a gas valve is opened and the burner ignites. How old is this dryer? Maybe this is something I've never seen before.
Posted on Jun 05, 2007
  • Jeff Rockwell
    Jeff Rockwell Jun 20, 2007
    You need to gain access to view the inside of the dryer, first. With the dryer plugged in, push the start button. If you hear a "click" and the igniter still does not come on, you probably have a bad igniter. If you don't hear a "click", the radiant heat senor is probably bad causing the igniter not to glow. You have to listen very carefully for the clicking noise, though. It's not very distinct with some dryers. Now, the igniter can glow sometimes and still be bad. The way your dryer works; it looks for a certain current potential with the igniter before it will open the gas valve to ignite. If the igniter is weak, the gas valve may not open. This is a safety feature that prevents gas from leaking into your home. Looks like you could have a simple igniter issue. If you can see it without taking it out look to see if there are any scorch marks on it. I hope this may help you. Let me know if I can assist further.
How do I relight the pilot light?
There is no pilot light on many of the dryers of today. They light with a hot surface ignitor.
Here is a tip that I wrote about dryers and no heat on gas dryers...
Apr 01, 2010 | Kenmore 72802 Gas Dryer
My Kenmore 60 series gas dryer will not heat up. I checked the lint trap and it is clean. How do I open the front panel to check the pilot light?
Some dryers have a small inspection hole covered by a small platic cap.
Remove cap and look inside unit for pilot. Newer dryers have an igniter that glows when the dryer is turned on. It ignites the gas then goes out.
Jul 30, 2009 | Kenmore 73952 Gas Dryer
We have hooked up the dryer and not getting hot is there a pilot light on it
Hi, Is this a gas dryer? There are no pilot lights. Remove the small plastic cap in the lower front corner and start the dryer. If the ignitor glows but goes out before the flame lights, you will need to change the coils on top of the gas valve. If the ignitor does not glow, you will need to test the fuse. Here is how to test the fuse on the more popular dryer:
UNPLUG the dryer! Remove the rear panel of the dryer and locate the fuse. It is white and ¼” wide and 3” long. It is located on the blower housing. Remove the wires and check to see if it has continuity. If it does not, you need to replace it.
If this is not your model, please get me a model # and I can look your up.
Please let me know if this help or if I can assist you further.
Jul 11, 2009 | Kenmore 63942 Dryer
Drum rotates but does not give off heat
If the pilot will not light then there is an obstruction between the gas line and the pilot. Most times there is a particle that sticks in the pilot. The pilot needs to be disassembled to clear the blockage.
Usually the the pilot is a simple construction and one of the parts has a tiny hole that easily gets clogged. Obviously this needs cleaned.
If the problem persists, the must be a problem further up. check any elements in between. You could try to blow air through the system with various parts disconnected to identify the obstruction.
May 18, 2009 | Kenmore Dryers
How do I light the ignite pilot light
Most new dryers don't actually have pilot lights. They use an electric heater that turns red hot, and ignites the gas at the right time. If your trying to light the pilot light (which probably doesn't exist) because the gas isnt being ignited,,, its possible that the electric igniter needs to be replaced.
Mar 13, 2009 | Kenmore Elite HE4 Electric Dryer
Whirlpool gas dryer heat goes on then off then on again
should have electronic igniter that light gas after turned on.
Jan 03, 2009 | Kenmore 73952 Gas Dryer
How to light the pilot?
If this is an electric dryer, it doesn't have a pilot either. If this is a gas dryer it will have an electric pilot. but then if it were a gas dryer, it would have a removable lower front panel for servicing the burner. So you must have an electric dryer. if the dryer runs but does not heat, the electric element is most likely at fault. If you really were looking for a pilot light on an electric dryer, I must recommend that you call a reputable appliance service regarding repairs so as to not jeopardize your safety.
Aug 31, 2008 | Kenmore 84052 Dryer
How to light the pilot light on a Kenmore gas dryer.
no pilot light has glow bar ignition to see if bar glows when start button is pressed should be small plastic cap on bottom of dryer front remove it to ckd for glow and burner operation
Aug 29, 2008 | Kenmore 75962 Gas Dryer
Pilot Lighting for Neptune Dryer
there is an electric igniter but no pilot light in the Maytag 5500 gas dryer. you can change it yourself.. let me know
Aug 23, 2007 | Kenmore 67082 Electric Dryer
Kenmore 72802 Gas Dryer Logo
261 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
