How do I connect my Samsung soundbar to my Sanyo 40" led tv. My Sanyo tv only has a digital audio out connection.
Why does the soundbar play with Roku but no sound comes from the bar when on regular t.v.
You have to go into the audio set up screen on the TV and direct TV sound to the output cable connector you used for the sound bar. Example: Optical, digital.
Jan 01, 2016 | Samsung Refurbished 5003 Series - 40"...
How do I connect my Sanyo DP42D23 TV to my Sanyo FWSB415E soundbar?
I doubt that the instructions say to connect to a headphone connector on the rear of your TV. More likely, the supplied cable connects to some other kind of AUDIO output. It might be identified as EXTERNAL AUDIO or AUDIO OUT.
Jul 18, 2015 | Sanyo 42" 1080p LED-LCD HDTV - DP42D23
I have a Craig stereo bluetooth soundbar trying to connect it to my sanyo LCD TV getting no sound coming from the sound bar
How have you connected it? Remember the cables must be coming from the TV's AUDIO OUT port(s) into the soundbar's IN port. If both devices are compatible, the best option would be an optical audio cable (TosLink, etc).
Mar 09, 2015 | Sanyo Televison & Video
I have a Sharp Aquos LC-60LE640X TV and I am trying to connect a Samsung HW-H751 Soundbar to it. I have hooked up the optical cable, adaptor and sub woofer, I have tested the Bluetooth function throug
If you are connecting the soundbar to your TV with the digital audio cable, make sure to select "D IN" using the source button on the soundbar. Bluetooth (BT) is a separate source from another device. (phone, etc.) The TV will need to be set to use the digital audio output and probably PCM format. (?) The subwoofer is preconfigured at the factory to mate up with your soundbar. (See below instructions - your soundbar includes the amplifier:)
Digital audio output setting:
After connecting an amplifier with digital audio input and
external speakers as shown, you should set an audio
output format compatible with the programme you are
watching or the device connected.
Go to "HOME" > "TV Menu" > "Setup" > "Option" >
"Terminal setting" > "Digital audio output" > select
"PCM" or "Bitstream".
NOTE
• When set to "Bitstream", Dolby Digital is output when the Dolby
Digital or Dolby Digital Plus audio formats are received. When
set to "PCM", PCM is output no matter what audio formats are
received.
• When set to "Bitstream", HE-AAC audio formats can be output
as Dolby Digital.
Jan 24, 2015 | Sharp Aquos Televison & Video
Does the Samsung UN50f6300af smart led tv support the Samsung Wireless audio soundbar HW-H450?
Because your TV is not Bluetooth-enabled and you are trying to connect it to a Bluetooth-enabled soundbar via Bluetooth. There are other ways to connect your TV to the soundbar:
1. analog AUDIO OUT (L/R) of your TV to the AUX IN on the soundbar (use a 3.5 mm.-to-RCA audio cable).
2. Optical OUT on your TV to Optical IN on the soundbar.
3. HDMI port to HDMI port (this may not work if your TV is not ARC compliant you have to try).
You get better sound quality with option 2.or 3. (if this one works for your TV)
Here is the link to download the soundbar's User Manual for help with the connections:
http://downloadcenter.samsung.com/content/UM/201411/20141114104022428/HW-H450-ZA-1114_Bookmark.pdf
Jan 05, 2015 | Samsung 2.1 Dolby Digital Wireless...
Hi, I have a hwh450 soundbar, I cannot get any volume to TVs, the tv is telefuken
Here is a link to your product description. When you get to the web page, click on the "Manual" tab to read the user's manual to find out how you can connect your soundbar to your TV.
HW H450 Wireless Audio Soundbar Samsung Home Audio
Jan 04, 2015 | Samsung 2.1 Dolby Digital Wireless...
How do I connect Samsung soundbar 550 to sanyo dp55441?
Use the audio out ports on the Sanyo to get audio to the Soundbar. You can use a single digital audio cable or the legacy RCA audio cables. The Audio Out ports are marked in white on the back of the TV. If it doesn't work, turn off the TV Speakers in the TV's menu.
Jan 03, 2015 | Samsung HW-D450 Sound Bar
How do you connect Samsung sound bar to my Sanyo dp52440A. TV has no receptacle which fits the audio aux which came with the sound bar
You don't have an optical digital connection on your TV but you do have a coaxial digital audio output that you can connect to the aux in on the soundbar!
Jan 01, 2015 | Sanyo Televison & Video
How do i connect a soundbar to a Sanyo TV.Tried all connections with both RCA cable and 3.5mm Line in cable.No luck.thanks
Make sure you are connecting to the TV's audio-OUT jacks, not the audio-IN jacks. Also, check the TV options menu. Some TVs have a choice of internal or external speakers and you have to select one or the other; obviously, you would select "external".
On the soundbar make sure you have selected the correct input jack for the audio cable.
Sep 26, 2014 | Sanyo 42 in. LCD TV
I have a new samsung 40" led tv and i have
The specs say that it has an optical audio in on your home theater system. So the easiest way to hook up is to connect the optical audio out of your tv to the optical audio in of your home theater system and walla! What ever play on the tv will play on the home-theater system. You are looking for a Toslink optical audio cable
http://cgi.ebay.com/6-OPTICAL-FIBER-OPTIC-TOSLINK-DIGITAL-AUDIO-CABLE-6-FT-/370402436177
Jul 14, 2011 | Samsung UE40B7020 40 in. LED TV
Televison & Video Logo
162 people viewed this question
Top Televison & Video Experts
Electro Med Services...
