Question about 2wire Computers & Internet
How to change gateway in surf n300 wireless router
  • 2,878 Answers
The router is the gateway. Same IP as well.
Posted on Nov 28, 2012
illinois68
  • 131 Answers
SOURCE: I have a new Belkin
If you dial back the security to WEP, does it connect?
Back to WPA though... when editing the Network Connections... Check SSID is correct. Mode "Infrastructure". IPv4 Settings is Automatic (DHCP). IPv6 Settings method is Ignore. Wireless Security is WPA & WPA2 Personal and the password is correct.
Posted on Sep 02, 2010
Holygrass
  • 443 Answers
SOURCE: I have just bought this
I have the mentioned all the possible ways to get this issue resolved.
First Lets try changing the Wireless password and user name,In most of the cases this works.
1) Open a new web page delete whatever you see in the address bar(press F4 and press delete).
2) Type in 192.168.2.1 and press enter button on your keyboard.
3) Then comes the Router Configuration Page.
4) If it is asking for Password,do nothing just click submit.
5) Towards your left on the page you will see Wireless. Under that you would also see a sub Heading Channel and SSID.
6) To edit the wireless settings click on Wireless tab in the setup page. You can edit the Wireless network name and wireless channel.
Wireless name (SSID) is the name of your wireless network. The most recommended wireless channel is 6. You can use wireless channel 1 and 11 too.
Now change The SSID,delete the current SSID and give it a new name.
7)To enable wireless security on click on security under wireless tab. And follow the Picture below.
For further assistance refer the link below.
http://www.corenetworkz.com/2009/07/setup-belkin-wireless-n-router-by.html
Posted on Nov 26, 2010
Tom Marvolo
  • 708 Answers
SOURCE: my belkin surf n300 password has changed need new
BELKIN ::::
WIRELESS SECURITY ISSUES
Step 1 : Connect Router - Computer ( Wired)
Step 2 : Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left under wireless click wi - fi protected setup
Step 4 : Leave the password blank and click on submit
Step 5 : Disable it and Click on apply changes
Step 6 : On the left under wireless click Security
Step 7 : Enable 64 Bit WEP
Step 8 : Type a 10 digit number on the key 1 ( 2 in each box )
Step 9 : Click apply changes
Step 10 : on the left under wireless click channel and SSID
Step 11 :Change the Wireless channel to 6
Step 12 : Change the SSID to a different name ( no Spaces )
Step 13 : Click apply changes
Step 14 : Now Scan and connect to this network ( Wireless )
Let me know if it works
Regards
TOM
Posted on Dec 27, 2010
Tom Marvolo
  • 708 Answers
SOURCE: I have the Belkin Surf N300 router and when i try
PS3 And XBOX :: BELKIN
Step 1:Connect Modem - Router - Computer (Wired)
Step 2:Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3:On the Left click firewall
Step 4:Leave the Password blank and click submit
Step 5:Disable it and click apply changes
Step 6:Scan and connect in the Xbox/PS3/Wii
Step 7: Get the IP Address of the Xbox/PS3/Wii
Step 8:Open Router Setup in the Computer
Step 9:On the left under Firewall Click DMZ
Step 10:Enable the IP Address of the Xbox/PS3/Wii in it
Step 11:Click Apply Changes
Step 13:On the left Under Utilities click System settings
Step 14:Scroll down to the bottom
Step 15:Enable UPnP
Step 16:Click apply changes
Step 17:Test the connection ,Check the NAT
If working then let me know
If it is still not working
Open Router setup
At the middle Under internet settings check the WAN IP
IF it starts with 192.168. or 172.16 Then you will have to contact your internet service and ask them to bridge the modem
Regards
TOM
Posted on Jan 08, 2011
Tom Marvolo
  • 708 Answers
SOURCE: can ps3 connected to belkin
Step 15:Enable UPnP
Open Router setup
Posted on Jan 22, 2011
Why only my wireless network is not appearing on this device?
Surf N300 can support 20/40 MHz bandwith.
Try to disable wide bandwidth (fix to 20MHz bandwidth).
May 01, 2014 | ASUS Transformer Book T100
Belkin N300 Surf problems
The router has to be manually configured in the gui page within it to allow remote wireless access point. This is not done by default as a security feture on routers. The way to find out the ip address of the router to set up a wireless access point or remote configuration is to go on your machine that has active working internet and click start, all programs, accessories, right click comand prompt, select run as administrator, confirm, then once in comand prompt admin, typ in ipconfig /all, then look for default gateway in the first list shown this is the ip of your router. Hope this helps.
Sep 03, 2012 | Belkin Surf N300 Wireless N Router
Can't connect to a second wireless SONOS via Belkin Surf 300
Go to the router web UI and see if is there then grant access to it.
May 26, 2012 | Belkin Surf N300 Wireless N Router
Router
use its web-based configuration page, do that by opening your browser the the router's IP address (your computer's obtained "Default Gateway")
good luck
Majdi
Dec 28, 2011 | Belkin Surf N300 Wireless N Router
I'm installing a Belkin N300 wireless router using a desktop PC with a wired interface card for the installation. Will this work if I connect the PC to one of the LAN ports on the Belkin router, and...
you can only comunicate one way not both ways disable wireless apps and windows will find a conection by wired and accept.therfore will always ose the ared until is changed to another method. if password is required thats is yours to know.
Oct 29, 2011 | Belkin Surf N300 Wireless N Router
How to install belkin surf wireless router N300?
Hi Friend,
Please read this pdf file...it will help you for installation
http://docs.google.com/viewer?a=v&q=cache:ViTLfewsf9MJ:en-us-support.belkin.com/app/answers/detail/a_id/4861+belkin+wireless+router+n300+review+installation&hl=en&gl=in&pid=bl&srcid=ADGEESgAExquF1wvYD_BDm4Xejb0doz6IBGAB73NO1C5LsarXb5qj_Ouuu7RnE_k6D8oX_MOh-xE57DN69Kxpqc6TxENHgKaafqaSrtZhpdC8vCAfQmibVd3azzPcpSFQYE-wfbDjYTb&sig=AHIEtbSAUbX8W4HrpZJ_Sopmbm2UfeM7Ew&pli=1
Thanks and Regards
Trinoj
Aug 06, 2011 | Belkin Surf N300 Wireless N Router
Computers & Internet Logo
19 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Bruce Silvernagle
Bruce Silvernagle
Level 1 Expert
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
