Question about Kitchen Ranges
Can I pull a gas kitchen stove out carefully to see side panels
To repair door spring that's broken
    Sergeant:
  • 311 Answers
Sure.if gas watch to see how long gas line is,.you can put dishs soap with water at the leg areas so will slide on floor or just lift at front and pull out.
Posted on Jan 10, 2009
How do i remove the glass on the door to clean it
You need to remove the inner door panel, (a bunch of screws hold it in) then remove the glass. You can either lock the door in the down position, if your model has locks on the hinges, or remove the door from the stove. If you can't lock it down, and do it while its on the stove, be careful because the door springs are quite strong, once you remove the inner panel it will want to spring up on you, since it will be much lighter.
Feb 21, 2015 | Kenmore Kitchen Ranges
Broken door hinge on Stoves 900dfa oven
STOVES 900DFa - how can I download the USER MANUAL and the TROUBLESHOOTING and MAINTENANCE MANUALS
Dec 30, 2012 | Stoves 900DFa Dual Fuel (Electric and Gas)...
How do I remove the door on a Stoves 900DFa oven?
My range is a different brand, but the door comes off real easy. Open it to the first detent, and then pull straight up on it to slide it off the hinges. Be careful though, the hinges are spring loaded and if you bump them they will easily come off the detent and slamm to the closed position. This will not only scare the sh..it out of you, but will also pinch your fingers real good if you're not careful.
Good luck,
Gary B.
Feb 07, 2011 | Stoves 900DFa Dual Fuel (Electric and Gas)...
Apparently a spring on my oven door is broken (DCS-RG-4844GG). On the large oven door, the left hinge has no tension in it. I can latch the hinge to remove the oven door for cleaning. However, when I...
spring is broken on the side that is 'slacked' without return tension. may be necessary to get underneath the stove chassis. move away from wall, carefully disconnect the gas fitting after turning off the gas spigot. Pull away far enough from wall to 'tilt' the whole chassis rearward to access the underside. Technicians use a 'jack' to raise stove....
Dec 02, 2017 | DCS RGS-484GG Gas Kitchen Range
How to remove door on stoves EL716 toop oven
I can only say for the 720. You have to remove the whole oven from the kitchen furniture and then unscrew/remove the top and side panels. You will then see the springs on either side of the door.
Important. Remove the inner glass panel from the door first, before you release the springs.
To remove the springs, ensure the door is closed and then unhook them. You then should be able to remove the door frame.
May 07, 2010 | Stoves 720EF Electric Double Oven
Our magic chef gas stove oven door spring has broken how to replace it
Pull out the oven. If it has no side panels then GREAT you can replace it very easy from the side. If not then you are going to need to take off that one side. IF neither of those are possible, then you might have to replace it from the backside of the oven after removing the panel. And finally there is a VERY rare last way which the oven is dismantled from the inside. I don't know what model you have so I am betting it is from the side when you pull it out.
Mar 14, 2010 | Ovens
The door on my Okeefe and Merritt antique stove will not close snugly against the frame. There is a slight gap at the top of the door. I have been told that the spring inside the stove needs to be...
O'Keefe and Merritt is always a challenge to the inexperienced because, although two stoves of the same year and model can look identical, there are subtle differences in both, especially in the door spring mechanism, that make it difficult to explain without seeing the stove and/or asking you a series of questions in person. Here it goes anyway: Some models have access panels that are visible when you pull out the broiler drawer. This makes changing a spring a breeze, as long as you know which spring you need. A sample of a broken one, or and intact one always helps when buying a replacement. Other models operate on a system of hooks, cables and springs. These often require a skilled technician to come out and repar for you. Most of the time, the door has to be physically removed from the frame so that new cables (and sometimes rods) can be installed on the hinge and then the door would have to be re-installed fishing the cables through a small opening on the bottom of the stove. A spring then attaches to the cable and the hook of the spring is then attached to one of three small aligned holes on the bottom stove panel.
One constant i s that there are 2 sets of springs for each of the door panels. You are right, there are springs in the middle. And you are also right that the white panel removes from the door after you remove the truss head sheet metal screws.
You might want to give me a call and chat about this further at RMR Company, Inc (RMR Stove Company) 619-231-2808
Dec 04, 2009 | Stoves Ovens
Interior Range Window cracked - How to Replace
It is simple enough not to need a manual.
1- open the door, then pull outwards. The door mounts slide right out.
2- lay flat on a towel on the floor. Remove screws on the inside of the door.
3- remove each piece and layer of the door and glass panels. Set them aside in order so you know how it goes back together
4- replace broken inner glass panel
5- put each piece back together, install screws
6- slide door (mounts) back into their homes on the front of the range
It is surprisingly simple. All you need is a #2 Phillips screwdriver and a bit of patience.
Tip: make sure to clean each glass panel while you have the door apart. Use a razor blade for those stubborn burnt on stains.
Apr 06, 2008 | KitchenAid KGRT607 Gas Kitchen Range
Oven Door
did it lift off in upward pulling>?
Jan 01, 2008 | Whirlpool GS475LEKS Gas Kitchen Range
Kitchen Ranges Logo
100 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
