Question about Swisher 60" 13 Hp Trailmower #T1360h
Need a wiring diagram for swisher 60" 13hp b&s trailmower
Mower will not turn over, but when jumping the selinoid it bumps the motor but then nothing. wiring seems to be messed with white wire coming straight from ignition and cant figure out where it goes. help?
3 Suggested Answers
  • 4 Answers
SOURCE: cable streched on swisher trailmower
Pull the belt cover off on the side of the engage lever and you will see that it is not a wire cable that engages the idler pulley. It's a rod connected to a long spring. Perhaps the spring came off or is defective as it puts tension on the idler pulley against the drive belt when you engage the blades. Further, there is a return spring to pull the idler pulley away from the drive belt when you disengage the blades. Check all the connections for the springs and see that the engage lever is mounted tightly. Also check the idler pulley itself.
Posted on Jun 26, 2009
tbreeze47
  • 3083 Answers
SOURCE: i have a swisher model
Unless you get lucky and find someone that has one of these, and can just tell you, you will need a service manual. Here's a user manual:
http://www.manualnguide.com/manual-get/3441/
If you could, you might just run it by a mower repair shop and see if they could tell you where the wires go- that would be the easiest way. Otherwise you will have to get a repair manual from the manufacturer, and they usually charge for those.
Sometimes if you look closely, you can figure out the cable connections, but the wires are the problem. If the switch just had two wires on it, they could go either way, the on/off function would just be reversed.
Wish I had more specific information for you, but good luck, thanks for using FixYa, and hope this helps.
Posted on Sep 09, 2010
Swisher manual
I BELIEVE IT'S 22 INCHES I JUST REPLACED MINE, SEARS HAS THEM OR YOU CAN GET THEM AT SWISHER.COM WITH PART #6046 FROM THE MANUAL OFF THEIR WEBSITE. I'M FINDING I HAVE TO ORDER EVERYTHING SO I'M GETTING 2 OF WHATEVER I NEED AT THE TIME
Jul 29, 2014 | Swisher 60" 13 Hp Trailmower #T1360h
How to replace belt
SWISHER 44 Finish Cut Trailmower Tension assembly belt bra Parts Model...
If you look at the diagram ( zoom in) part #94 , idler spring, is what puts tension on the belt.
Jun 07, 2014 | Swisher 44 Iinch 11.5 Hp Trailmower...
I NEED A PART NUMBER FOR THE MOTOR TO DECK BELT
should be able to give serial & model # to distributor or dealer to get your belt #
Aug 07, 2013 | Swisher T14560 T - 60" Trailmower with 14...
Need repair manual for u11360 60 in swisher finish mower 199-288003
Your best bet would be to go to your local dealer. They can get for you what you need, answer any questions , or print out diagrams showing you a picture of what you need.GOOD LUCK.
Jul 08, 2011 | Swisher 60" 13 Hp Trailmower #T1360h
What size belt for my swisher 44" pull behind
I just replaced the belt on my 44" Trailmower and since I had to get it up and running without waiting for new Swisher 4220 belt I found an ordinary V-belt 1/2"X72" whith overall with of 74" works OK
Jun 28, 2011 | Swisher 44 Iinch 11.5 Hp Trailmower...
I need a belt diagram for swisher t60 trail mower
Here's the manual for it - section 12 belt replacement, page 16. It goes over all pulleys except the idler - it goes under the idler pulley.
Aug 30, 2009 | Swisher 60" 13 Hp Trailmower #T1360h
Cable streched on swisher trailmower
Jun 22, 2009 | Swisher T14560 T - 60" Trailmower with 14...
My swisher pull behind was working fine and I was
take the cover off above the ignition switch ckeck 4 loose wires if nothing is found wrong jump it at the selinoid if it starts go to the nearest perts store and buy a selinoid for an ole ford truck transfer wire exact and it should wrk fine
May 03, 2009 | Swisher 60" 13 Hp Trailmower #T1360h
Swisher 60" 13 Hp Trailmower #T1360h Logo
19 people viewed this question
Top Swisher Garden Experts
lnbn1975
Tim Whalen
dannydoesita
Are you a Swisher Garden Expert? Answer questions, earn points and help others
