Question about Maytag Washing Machines
Capacity of a Maytag LAT 9314 AAE washer and a Maytag LD7314 ACE dryer?
4 Suggested Answers
  • 2336 Answers
SOURCE: I have a Maytag washer MOD # LAT 2300 AAE
If the machine does not start.
Make sure the circuit breakers or fuses are functional in the main electrical panel.
Try to turn them OFF and ON again.
You might need to check the thermal or non thermal fuses inside your washer.
If all appears in working order, you might have a burnt motor if no noise comes from it when you pull out the knob.
Posted on Apr 09, 2008
duby1990
  • 370 Answers
SOURCE: When washer finishes there is a dripping of water inside unit
What has happened is you have sand in your water valve from your water. This pluggs the water valve and also sticks it open so when the water valve shuts of there is still a small trickle of water coming through the washer. Replace the water and it will fix the problem (no way of cleaning the inside of the valve.) Replace water valve.
Posted on Nov 24, 2008
  • 784 Answers
SOURCE: Maytag dependable care plus washer (Model LAT
The belt turn the pulley, but the height of the pulley is worn out so it didn't push up a mechanism to release the brake and to engage with the clutch to make the spin.
You have to takethe shaft out to study how it works then it makes sense on what I 'm talking.
The pulley cost only $11 but it is a major laboring exercise. It is a good learning to have hands on to this problem. Good luck on replacing the pulley.
Posted on Aug 09, 2009
Maytag model lat 9605 aae fills with water but want agitate or spin out but works fine on delacate cycle thought it was timer put one on still doing the same thing
replace the motor brushes this is common it wont spin or do main cycles but easy go it does is worn brushes
take one and and check the lenght if its less than 50mm replace them
when they get shorter the motor draws more standing current etc running hotter so....
also check the vacume switch and for and rubbish inside the drum skin
Sep 24, 2014 | Washing Machines
Maytag clothes washer model 2500 aae leaks along bottom edge
Sounds like a hose leak inside the machine. Possibly remover front bottom cover then check all hose connections.
Nov 14, 2013 | Maytag Washing Machines
Maytag LAT 9804
tub capacity of my LAT 9804 top load washing machine?
Jul 12, 2012 | Maytag Washing Machines
Dryer Maytag LDE 9316 ACE -what is the capacity of that model dryer? Thank you!
Capacity is a key consideration when shopping for a dryer. The more you are able to dry in a single load, the less time and money you will spend doing your laundry. Most importantly, look for a dryer with approximately twice the cubic foot capacity of your washer.
Typical dryer capacity ranges from approximately 3.4 cubic feet (for a compact model) to over 7 cubic feet for an extra large capacitor
In addition to saving time by drying on fewer loads, and money on lower energy costs, a large capacity dryer often means spending less time once the laundry is dry. There is typically less wrinkling when clothes have more room to move around inside the drum.
Whirlpool brand offers dryers with a range of capacity and flexibility.
Dec 16, 2010 | Dryers
Bearing on dryer motor sqealing. what to do?
LAT is a washer
Noisy motor need to be replace
Mar 03, 2010 | Maytag Performa LAT2500A
How old is this machine
I have the lat 9334 aae washer and still have my sales slip from 12/20/1994. Still runs like a top! Hope that helps!
Nov 24, 2009 | Maytag Dryers
I NEED TO REMOVE THE FRONT OF THE WASHING MACHINE T
There are 2 screws down toward the bottom of the front of your washer. You remove these and grab the front panel and pull toward you and up and the 2 clips at the top will snap out. Hope this helps!
May 20, 2009 | Maytag Washing Machines
Nov 24, 2008 | Maytag Washing Machines
Apr 07, 2008 | Washing Machines
Washing Machines Logo
266 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
