Wiring diagram for air/heat conditioner model #GB3BM-060KC-10A
Connect electric wiring
yalmer
  • 549 Answers
SOURCE: Carrier Thru-Wall Heater and Air Conditioner won't heat
http://www.residential.carrier.com/support/troubleshooting.shtml
Here is some troubleshooting tips.
Also service available.
Posted on Feb 25, 2008
SOURCE: Wiring Diagram for Ruud Heat Pump
Unfortunately, the wiring diagrams for heat pumps are not so easy to come up with. The outdoor unit will have its own diagram, but may not include the indoor air handler and will probably not include the thermostat. That said, the orange wire is commonly run from the thermostat to the reversing valve in the outdoor unit. This wire is usually not connected to the indoor airhandler. The orange wire is usually used in a unit that has the reversing valve energized in cool. Ruud, however has its reversing valve energized in heat. Probably not useful but maybe helpful
Mike
Posted on Mar 26, 2009
SOURCE: wiring diagram for portable air conditioner
I think the wiring diagram is on a printed sticker on the side of the water collector, just pull it out of the right side as you look at it. There should be one on there hope this helps as i have the same unit in the other room. regards Richard
Posted on May 29, 2009
SOURCE: Wiring connection for a Ruud air handler & seeking its wiring diagram.
we are trying to install a goodman heat pump with a rheem air handler, the orange wire is hook up and the unit is still staying in the heat mood. does anyone have a wiring diagram for the air handler, their is some white wires in the air handler one with a purple strip and one with a black strip we need help
Posted on Aug 19, 2009
  • 82 Answers
SOURCE: i need a wiring diagram for a tempstar gas pack
Go here - http://www.gotempstar.com/go/index.asp?t=86&s=477
enter PGAA in model box.
Posted on Mar 14, 2010
I need to know the wiring diagram for the thermostat, which is a 24 vac heat pump thermostat TA2000? HELP!!
What is the thermostat brand name? You can do a search in the Internet for the wiring diagram
Jan 20, 2016 | Gibson Nordyne/2 Ton Heat Pump Package...
Need wiring diagram to include: Underfloor heating downstairs (wet system,polyplumb) combi boiler for the heating and hot water
could you provide the exact model number or the product you need the wiring diagram for
Thanks
Proton
Oct 30, 2008 | Honeywell Heating & Cooling
Blower humms doesntwork
ck. mfd on blower capacitor
Aug 20, 2014 | Gibson Heating & Cooling
My Emerson model k55hxjcp-2593 electric fan motor has 5 wires connecting to the motor. The replacement motor only has 4 wires. I need to know how to connect the new motor seeing there is only 4 wires
the motor should have wireing diagram on side. i would expect 2 of the wires go to a run capacitor & the other 2 are your 110 or 220 depending on unit need.
Jun 17, 2014 | Coleman Mach III Air Conditioner
Air conditioner wiring diagrams
What brand of A/C is it? Are you looking for the thermostat wiring? Different Brands use different wiring, but the usual is as follows:
R terminal at furnace is 24 volt Hot
W is the control for the heating cycle
G is used to start the furnace blower
Y is used to start the outdoor A/C
B or X depending on Brand is the 24 volt common
Yellow and B or blue is the other wire that goes to the outdoor unit
If you want more info, I need Brand, and type of unit, gas furnace and A/C, electric furnace and A/C, or is it a heat pump for the outdoor unit?
Hope this helps./
Sincerely,
Paul Gibson
Mar 29, 2010 | LG LWHD1800R Wall/Window Air Conditioner
KINDLY SEND WIRING DIAGRAM OF DIAKIN PACKAGED ROOF TOP AIR CONDITIONER MODEL UAT08KAY-1
Hi; Call California number 1-310-769-0105 This is from what I can find to be correct.Also make sure You have the exact model and serial numbers. You can find the wiring diagram usually on the inside cover of the electric compartment covers...alpharome416
Feb 10, 2010 | Dometic Rooftop RV Air Conditioner
INSTALL HEAT TO A INTERTHERM
Wiring diagram is normally included and fixed to the inside cover of the electrical end cover of the control compartment. Instructions for wire size required and fused disconnect should be on the unit name plate.
Nov 09, 2008 | Heating & Cooling
Heating & Cooling Logo
51 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
