Question about Texas Instruments TI-83 Plus Calculator
How do I determine 4X4 adjoint and inverse matrices on TI-83?
I'm given 4 linear equations, need to determine the adjoint [A+] and inverse [A-] matrices. To help, my initial matrix using the linear equations should look like: 1-2-1-1 2-(-1)-3-1 3-1-1-(-1) 1-2-(-1)-(-1)
2 Suggested Answers
SOURCE: ERR:SINGULAR MAT when finding inverse of matrices
If a matrix has a determinant of 0, this error appears. If you get this error, your matrix doesn't have an inverse.
Posted on Jun 06, 2009
A linear equation is given below. Determine the steps to solve the equation for its inverse. y=6x+24
Step 1 - replace each x with a y and replace each y with an x
x=6y+24
Step 2 - Solve for y to get the equation in the slope intercept form y=mx+b
Step 3 - get the 24 to the other side by subtracting 24 for both sides
x-24=6y + 24 - 24
Simplify
x - 24 = 6y
Divide by the coefficient in front of the y to get y by itself.
x/6 - 24/6 = y
x/6 -4 = y
Write in the normal format by switching the sides.
y = x/6 - 4
Good luck.
Paul
May 07, 2016 | Office Equipment & Supplies
How to solve linear equation
For two linear equations, one can use
comparison, substitution, or addition/combination.
For more linear equations one uses the Cramer Rule that involves matrices and their determinants.
Sep 16, 2014 | Office Equipment & Supplies
How to find the adjoint of a matrix by scientific calculator
Adjoint of a square (non singular matrix) = product of the determinant of matrix by the inverse of matrix. Adjoint([A])= det( [A]) * [A]^-1.
To get the inverse of a matrix, have its name displayed on command line then press the reciprocal key [x]^-1
May 23, 2014 | Casio Fx-991es Scientific Calculator
How to solve matrix
What do you mean by "solve matrix"? Do you want its determinant? Its inverse? The eigenvalues and eigenvector? Solve a system of linear equations?
Jun 11, 2013 | Casio FC-200V Scientific Calculator
How do you compute a matrix on a ti-34
The TI-34 doesn't work with matrices.
Even if it did, you'd have to define what you mean by "compute." There are a lot of things that can be computed from a matrix, such as determinant, row and column norms, inverse, and eigenvalues.
Nov 21, 2012 | Texas Instruments TI-34 Scientific...
How to do gauss jordan
You should consult a Linear Algebra book. Besides, these calculator cannot handle matrices of dimensions 4x4 or higher . With matrices of dimension 3x3 and less it is probably easier to use the Cramer rules directly.
Nov 06, 2012 | Texas Instruments TI-30 XIIS Calculator
How to find rank of matrix using casio991 es??
The FX-991ES offers simple matrix operations like basic arithmetic, plus the slightly more complex operations determinant and inversion. Furthermore, it is limited to matrices with a maximum size of three rows and three columns.
The rank of a matrix is defined as the number of linearly independent row or column vectors. You can perform a simple partial test for square matrices by calculating the determinant of the matrix:
  1. Enter the matrix into matrix variable MatA.
  2. Press [SHIFT] [4] [7] [SHIFT] [4] [3] [)] [=]
The display now should show det(MatA) and the determinant of the matrix in the result. If the determinant is not 0, the rank of the matrix equals the dimension of the matrix, otherwise the rank is less than the dimension.
Unfortunately, this is all support the calculator offers. For small matrices (i.e. 4x4 or smaller), you should familiarize yourself with the Gau? Elimination Method algorithm for solving linear equation systems. It is a two-step procedure where a matrix first is converted to its row echelon form, and second to row canonical form to solve the LES.
You need to follow the algorithm only through the first part, the number of non-zero rows after this step equals the rank of the matrix. With a little exercise you will be able to do it faster on paper than trying to do it with your calculator only.
For larger matrices I suggest to use a PC with more powerful math software (Maple, Mathematica, ...) or, if you know some basic computer programming, just write the necessary program yourself, which is also a very good exercise both in programming and understanding the algorithm.
Jan 16, 2011 | Casio FX-115ES Scientific Calculator
I am trying to solve imaginary number equations with matrix using the TI-84 For example: (8+15i)x-8y = 10 -8x-(8-10i)y = 0 8+15i -8 10 -8 8-10i 0 should i convert to another form?
I am afraid you cannot use the TI8xPlus family of calculators to solve linear systems in matrix form. In this calculator, matrices must have real coefficients.
You can however separate (expand) the problem into a linear system of 4 equations in 4 unknowns and try to solve it with the calculator.
  1. define X = a+i*b
  2. Define Y=c+i*d
  3. Rewrite the first equation substituting a+i*b for X and c+i*d for y.
  4. Gather all real terms together, and all imaginary terms together on the left.
  5. You will have (8a-15b-8c) +i(15a+8b-8d) = 10 +0i
  6. This equation can be split into two equations by saying that
  • the real part pf the left member is equal to the real part of the right member, this gives 8a-15b-8c=10, and
  • the imaginary part of the left member is equal to the imaginary part of the right member, this gives 15a+8b-8d=0
Similarly, you rewrite the second complex equation substituting a+ib for X and c+id for Y, then expand the binomial products, gather the real parts on the left together, and the imaginary parts on the left together. After that you equate the real part on the left to the real part on the right, and do the same for the imaginary parts.
If I did not make mistakes during the expansions and the gathering of terms you should get the following equation
-(8a+8c+10d) +i*(-8b+10c-8d) =0+i*0 from which you extract an equation for the real parts, -(8a+8c+10d)=0 and another for the imaginagy parts i*(-8b+10c-8d) =i*0
If I did not make mistakes (you should be able to find them, if any) your system of two linear equations with complex coefficents has been converted to a system of 4 linear equations with real coefficients.
8a-15b-8c=10
15a+8b-8d=0
8a+8c+10d=0
-8b+10c-8d =0
Now, you can in theory solve this system with help of the calculator, to find a, b, c, and d. When these are found, you can reconstruct the X and Y solutions.
Now get to work: Ascertain that my extracted equations are correct, then solve for a, b,c, and d, and reconstruct X and Y.
I am no seer, but my hunch is that this system is degenarate. I will not explain what that means.
Feb 10, 2010 | Texas Instruments TI-84 Plus Calculator
Im looking for the best electrical calculator for ohms law and kirchoffs law
To solve Ohm's law you need no sophisticated calculator. If you know two quantities, you readily calculate the third. Application of Kirchhoff's (two h) laws to linear circuits, gives you a linear system of equations. If a calculator can solve linear systems, or handles matrices, the limitations would pertain to the maximum dimension of the matrices.
I just tried the TI83 to define a 45x45 square matrix and a 55x45 matrix. The maximum number of rows or columns is 99. But it will depend on memory.
If you have the TI84PLUS Silver Edition it should be fine. You can upgrade to a TI 89 Platinum, which can handle symbolic calculations (with undefined coefficients a, b, c).
Hope it helps.
Sep 17, 2009 | Texas Instruments TI-84 Plus Silver...
Jun 02, 2009 | Texas Instruments TI-84 Plus Silver...
Texas Instruments TI-83 Plus Calculator Logo
78 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
