Question about Dewalt 18 Volt Compact Drill Kit
Drill bit stuck in dc759 dewalt 18v drill
When I put it in reverse to release the bit, the claws move around but don't widen to release the bit. Help please
  • 1019 Answers
SOURCE: chuck will not release bit
the Chuck should be 2 Part.
Use 2 pair of stillsons Or pipe wrenches, Tight On the 2 Chuck Parts, Crack in opposite Directions.
Alternative, Use Wrench On Chuck Jaw, Short sharp Blow With Hammer.
Mike @ compurepair.
Posted on Feb 28, 2008
  • 313 Answers
SOURCE: i HAVE A DEWALT DC729 18V DRILL
is this a north american model.all i can find is model DC727 & DC728 model. charger model 9116 & battery is DC9096 may work.charger volts 110v ac. if your buying the individual part like batt & chgr its more expensive than buying the whole kit is cheaper. hope i answer your question
Posted on Jun 21, 2008
SOURCE: problem with the chuck
Had the same problem on mine. Remove the chuck, then remove the snap ring on the back of the chuck( carefull, the housing will fall out once the ring is removed), on the side of the chuck you'll find a cam and small odd shaped spring held in by two cylender pins, on mine the spring had a gap in it and I just spread the gap to about twice the size in was and put everything back together and it has worked fine ever sence. Hope it works for you.
Posted on Dec 16, 2009
  • 10865 Answers
SOURCE: jammed chuck
Use a pipe wrench to turn the chuck open. J.
Posted on May 31, 2010
SOURCE: Can't remove bits
I had this problem on my De Walt DW912- I simply couldnt turn the keyless chuck to remove the screwdriver bit and there was no obvious reason why.
I placed the unit on a solid surface so that the chuck/ drill bit was pointing vertical. I then used a mallet and a metal chisel to gently tap each of the 3 chuck jaws back into the chuck body. It worked!
Turned out that there was the absolute tiny amout of corrosion between the jaws, and the chuck and my tapping had just broken the siezure. I now remember that it started to rain slightly last time I used it.
Some spray release agent or perhaps WD40 would probably have done the same job but I wouldnt have believed so little corrosion could have done this so didnt realise this was the problem.
Posted on Jul 23, 2010
My bit in my drill is stuck into a large tree stump... that had been cut close to the ground. How can I get the bit unstuck? My dewalt drill is unable to drill in & drill out.
If it's a twist bit try putting a vice-grip pliers on the end and turn it so the fluting pushes the bit out. If it won't move or if it's a spade bit you'll have to split the wood around the bit. You may or may not be able to do this with the offending part of the stump in the ground. Using a wedge, drive it into the stump near but not next to the bit so you don't damage the bit. Don't drive the wedge flush into the stump or you may get the bit out and then have the wedge stuck. Worst case, carefully use a chainsaw to cut out the stump so you can split the wood around the bit.
Feb 01, 2012 | American Tool 6 each: Irwin Metal Drilling...
What other tools will the Dewalt DC9098 18v battery power?
Hi Joe,
Welcome to fixya!
Dewalt says it is compatible with all their 18v tools, except the univolt.
Please place a vote.
Thanks,
Handie Andie
Jun 24, 2011 | Dewalt 18v 18 Volt 1/2" Compact Battery...
I have a drill bit stuck in the head. I put the bit straight in and now its stuck. Is there anyway to take it out?
Grab the drill head as hard as you can put the drill on drill setting and the highest number setting and put it reverse
Jun 09, 2011 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
I have a dewalt cordless drill, dc759 18v, I need the instruction manual, I lost mine! How do I get one?
Hi there! Here is a link to the support manual - http://servicenet.dewalt.com/Products/Detail?productNumber=DC759KA# Here is the support back for your drill. - http://servicenet.dewalt.com/Products/Detail?productNumber=DC759KA
To get dewalt manuals, go to servicenet.dewalt.com and search for your product there.
Alex
May 30, 2011 | Dewalt DC759kar heavy - duty 1/2" 18v...
I have a new DeWalt DC725 cordless compact 1/2" drill/driver/hammerdrill. The only problem so far has been that the keyless single sleeve chuck will now not open to release a 1/2" drill bit. I have twisted...
place the bit in a bench-vice and take a little benchhammer and with a plastic hammer .
hold the hammer with chisel tip on the claws of the chuck and tap with the plastic hammer on the other side of the bench hammer and beat gently on the three claws tighten the chuck three-step around gently around so the bit slowly from the drill bit comes slowly loose.
if the bit is out you can turn the chuck free, if this problem repeats go to the dealer for warranty .
Aug 17, 2010 | Dewalt Garden
My drill bit has stuck in the chuck of my dewalt sds chuck ,have tried wd40 but still stuck
I had the same problem. I put the drill onto Hammer/Chisel action and it helped release the bit.
May 16, 2010 | Dewalt DC925B Heavy Duty Xrp 18V Cordless...
How to remove brushes in a dc759 drill?
you cant replace the brushes on this drill it is a sealed motor. go this site the replacement motor is $ 38.77 http://www.ereplacementparts.com/dewalt-dc759ka-type-18v-cordless-drill-parts-c-1009_
Jan 20, 2010 | Dewalt 18v 1/2" Compact Drill/driver Kit...
My DC759 drill has no bearing clip
http://www.ereplacementparts.com/dewalt-dc759-type-18v-cordless-drill-parts-c-1009_1162_2837.html
Here is the parts diagram. I hate to say it but I always have problems getting the chuck out of the clutch/transmission without breaking something. I havent figured out how to keep the spindle from moving while I try to turn the chuck. Sorry if this doesnt help much.
Nov 26, 2009 | Dewalt 18 Volt Compact Drill Kit
Chuck will not release bit
Mike @ compurepair.
Feb 28, 2008 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Dewalt 18 Volt Compact Drill Kit Logo
270 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
