Question about Boss CHAOS CH450 Car Audio Amplifier
What size fuses does a boss 1600 watt 2ch mosfet power amplifier ch900 use?
2 Suggested Answers
97F350diesel
  • 1326 Answers
SOURCE: boss c705 chaos "manual" try-en to find
What info do you need? All amps are exactly the same and the manual only differs for specific specs and db ratings!!
Posted on Nov 04, 2009
I have a boss rt645 2ch 1400 watt amp would this amp properly push a pair of 12 inch mtx terminators.
That all depends on the wattage of the subs. also the independance of the subs. If your amp is 1400 watt, maximum you want is 2 600watt subs. if your subs are higher you will blow your amp eventually as your amp isnt powerful enough to pump out to that level.You should never have your amp fully turned up to max, 80% is perfect and will not make your amp blow. Hense why you want your subs less than the max output of your amp.
Mar 04, 2011 | Boss AUDIO RT-645 2-Channel Riot Series...
Bought a car and this amp was in it(Pyramid Crystal PB781X 2ch MOSFET). it is missing the fuse. what fuse does it require?
25 to 30 amp fuses are the most commonly used fuses in any amp and since yours is a 1000w amp, I would use the 30a.
Sep 05, 2010 | Pyramid 2CH 1000W CRYSTAL AMP Car Audio...
Boss c705 chaos "manual" try-en to find
Nov 03, 2009 | Boss C700 Car Audio Amplifier
Pb1281x pyramid crystal 2ch mosfet amplifier 1600w what size fuze i got a 20amp in it it blows when i got it terned up
Hello sunshanel,
You did not say what you have the amp connected to and what the impedance load is. It is only stable at 4 ohms and if a lower impedance is connected, say 2 subs in parallel, it would try to produce more power when you turn it up and would most likely blow the fuse. 20 amp sounds right for the amp. The power rating of 800 watts per channel is peak power, not RMS, and many low-end manufacturers tend to state bigger numbers in the ratings.
Hope this helps.
Apr 26, 2009 | Pyramid PB1281X Car Audio Amplifier
Legacy 1800 watt amplifier
HI ...NO, YOU CANT JUST CHANGE THE TRANSISTORS..YOU ARE RIGHT THERE IS MORE TO IT THAN THAT.......
Feb 06, 2009 | Legacy 2 Channel 1600 Watt Bridgeable...
Blown amp, on circuit board, connecting fuse and power connect.
These amplifiers dont employ reverse polarity protection that most higher priced ones do.
The amplifier(s) are definately in need of repair - probably power supply - IF boss sells parts.
Chances are, however, the repair will meet or exceed the cost of a new (appropriately rated) entry level amplifier.
Just about anything can be repaired.... question is, are you willing to pay?
Jan 14, 2009 | Kenwood KAC-X501F Car Audio Amplifier
Speaker amplifier calculation
for $85 i can sell you an Almani 900 watt 2 channel amp i would stay way away from those 3 brands they are all really poor quality and i can get you any major name brand cheaper.
I can get you a hifonics 4008 amp (800 watts peak 100 watts per channel rms) for $100 shipped with full factory warranty. you find an amp you like and i will get you a price. I am a factory wholesale distributor for most brands.
Jan 08, 2009 | Legacy 2 Channel 1600 Watt Bridgeable...
Need to know what size fuse do i put in this amp .
Owner's manual
According to the manual, the maximum current draw is 30 amps.
Nov 09, 2007 | Legacy 2 Channel 1600 Watt Bridgeable...
Boss CHAOS CH450 Car Audio Amplifier Logo
60 people viewed this question
Top Boss Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Are you a Boss Car Audio and Video Expert? Answer questions, earn points and help others
