Iomega 31802900 windows 7 compatability
Working fine connected to a machine running Vista but not recognised when connected to a machine running Windows 7. Online support says I am out of warranty but there should be no problem! Help!!
gwbm
  • 353 Answers
SOURCE: epson c60 printer not compatable with windows vista need a driver but have no idea where to download it
The driver for the Epson C60 printer is included with Vista - all you need to do is connect the printer to the computer with Vista running and turn it on. If you have already done this and the printer does not work properly (but see the info about the Status Monitor below), turn the printer off, uninstall the printer using the Control Panel-Programs and Features-Epson Printer Software, then reboot the computer. Once Vista is running, turn the printer on and it should then install OK.
HOWEVER, the printer Status Monitor (SM) is not included in this process and if you try to install the XP version of the SM, it will not work. Epson appears to have no intention of remedying this problem. This means you have no means of monitoring your ink levels, nor of changing the cartridges, cleaning the heads etc via the computer, although some of these tasks can be carried out via the printer control panel (see your hand book on how to do this).
A good solution is to use the free SSC utility as your SM - download from:
http://www.ssclg.com/epsone.shtml
Install it, and double click the ssc printer icon in the bottom right corner (System Tray). Choose Configuration and set your printer type (C60), then close the ssc window. Now right click the ssc icon in the sytem tray and choose the SM function you wish to use.
If you have any further queries on this, please post a new comment.
Posted on Mar 12, 2009
  • 489 Answers
SOURCE: I need drivers
Go to www.toshiba.com and search their support site for your laptop model number (not the hard drive model you have listed) to download the drivers you need.
Posted on May 25, 2009
SOURCE: My Vista machine can't see the iomega network drive
You need to connect to the IOmega drive using windows xp and add a user.
In the explorer view in Vista at the top click on Map Network Drive.
At the bottom click "Connect using a different username" and enter the credentials that you created earlier.
In the box above for the location type in "\\IOmega's IP Address\Folder that you want to map".
Click on connect at the bottom should be done straight away and then you should be able to see it in "Network Places" as well. Let me know if this fixes the problem or not.
Posted on Sep 11, 2009
  • 289 Answers
SOURCE: Not recognised by computer
You gotta partition it first. http://windowshelp.microsoft.com/Windows/en-US/help/d9a4d35e-efdf-406c-a049-0860180129a71033.mspx
Except don't format the ones that already have a Letter (or u screwed urself there)
Posted on Sep 27, 2009
RescueTechLA
  • 2653 Answers
SOURCE: AutoCAD 2004 / Windows 7 compatibility?
If it works in Vista you shouldn't have any problems. Easiest way to find out is to install it!
You can always just uninstall the program fi you run into problems.
Posted on Dec 06, 2009
Lost my driver for iOn pics2pc
When you connect something to an USB port for the first time, don't hope to much. You have to be sure the computer has the correct software to recognise the hardware and can work with it. From Windows 7 and up, for all hardware that is certified with Microsoft, you can download the drivers from Microsoft. Lots of hardware is recognised when connected and will initiate a download from Microsoft. But not all hardware will do so and not all hardware is compatible (same as not certified by Microsoft from Windows 7 and up) with the new operating systems.
Most things that worked fine with Windows XP and or Vista, can fail with Windows 7 and 8, because the factory that made the hardware in the first place does not ask for certification with Microsoft for their old Hardware. They only spend time and money to get their new hardware certified on the new operating systems. So to make sure your hardware is compatible with the OS. Check the manual and find out, what you have to do so it will work on your computer.
If your device was working on a USB2 port, it also should work on an USB3 port, on the same computer. But don't expect another speed, because the slowest part decides the speed.
Oct 20, 2014 | Computers & Internet
Navman n40i smart st compatability problem with vista.
Are you not able to run the activesync program despite the Vista warning? Did you try running it in compatibility mode? What happnes when you try to connect with sync center (what happens...any error messages)? Regarding the mobile device centre...did you check that McAffe and windows firewall is not blocking it from internet access?
Jan 26, 2008 | Navman NavPix N40i GPS Receiver
Need driver for FMW0085503
Oct 15, 2014 | Audio Players & Recorders
Hello,I can connect to my iomega device fine via a windows 7 computer, but when I try it on my windows 8 it does not find the device, neither via localhost nor via the myiomega web interface.. which worked...
Windows 8 is not very friendly with much. you will most likely have to upgrade your devices to windows 8 compatible ones. The only other thing I can think of is a patch in software, firmware upgrade on devices not working or an emulator of some kind if they exist for you products.
Feb 03, 2014 | Iomega StorCenter ix2 1000 GB Network...
Iomega floppy usb-powered external floppy drive on windows 8
Hi, Sounds like driver related problem to me. Try use this tool to update the drivers: Driver Update Software for XP Vista 7 8. Wish you best of luck.
Nov 30, 2012 | Iomega Floppy USB-Powered External Floppy...
Connect another laptop to my wireless kodak printer but it won't recognise the printer
check the website of your printer such as if its a Lexmark go to lexmark.com and see if the model number is compatable with the Vista programming. A lot of printers do not operate with Vista. I have three printers that only operate with XP and Windows 7
Sep 01, 2012 | Kodak ESP 9 All-In-One InkJet Printer
Iomage macmini 1TB not recognised in disk utilities
Check cable. Try different cable. Try different ports you connect the Iomega with the computer with en on the Iomega itself.
Dec 17, 2011 | Iomega MiniMax Desktop - Hard drive - 500...
Win 7 can't recognise my iomega hard drive LPHD-UP with s/n 54bk506524
Install the driver of the external hard drive first before connecting it to your computer, or when an icon appears on the lower right side of your desktop, right click on it and try to repair it by using troubleshoot compatibility. Maybe, your hard drive doesn't work with windows 7. You can run it in older versions of Operating Systems even if you have windows 7 in it.
Nov 19, 2010 | Computers & Internet
Aug 01, 2009 | Iomega 1TB Desktop USB 2.0 Hard Drive
Computers & Internet Logo
165 people viewed this question
David Payne
David Payne
