Dell laptop vostro 1500 won't start - Computers & Internet
    Novelist:
    Champion:
  • 233 Answers
There are three possible reasons why it's acting like that.
1. Defective AC Adapter or Power cord
2. Defective Motherboard
3. Defective Battery
First off, you need to isolate the part which causing the issue. Please follow the following steps:
1. Remove the battery and use the power cord alone in powering up your computer. If it goes well, then you need to replace the battery. If no go, then try using a different known good outlet.
2. Check the AC Adapter (the box) if there's a light lit. If it's green, then it's should be working fine. If it's amber or nothing at all, then there's a problem with it. You might need to replace that.
3. If the AC ADapter looks good, then try to wiggle the cord so that you can check if the cord is properly connected to the computer. Usually, cords get loose and it causes problems. If it has this
kind of problem, then you need to get a technician to check that for you because you might need to buy a new motherboard for that.
Please do the above simple steps, and let me know if anything happens. I hope this can solve the issue.
Posted on Nov 28, 2012
PaulRepair
  • 66 Answers
SOURCE: Dell Vostro 1500
There is a solution on these Dell Models.
Go to Start>RUN and type in MS Config
Go to the startup tab and uncheck the PCMServices.exe
Restart the computer, and it should fix it.
Paul
Posted on Mar 06, 2009
  • 100 Answers
SOURCE: Dell vostro 1500 has BIOS PASSWORD
It sounds like you are prompted to enter bios password. Call dell tech support and they will generate unlosk code for you.
Posted on May 27, 2009
SOURCE: Dell Vostro 1500 not switching on...
Motherboard is bad that's why the ac adapter light will turn off ,possible short ciruit on the board. you need to have a replacement for it. Call dell tech support for repair.
Posted on Jul 21, 2010
  • 2567 Answers
SOURCE: Using Dell laptop Vostro 1500,
There might be a possibility that the battery is not making good contact with the laptop's charging circuitry. To eliminate this possibility as a root cause of the battery not charging, turn off and unplug the laptop, take the battery off the laptop, and using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self. When done, put the battery back into the laptop, plug it, and turn it on.
Posted on Oct 24, 2010
jb_b
  • 88 Answers
SOURCE: i have dell vostro 1500
Follow the steps below to reset/remove the bios password.
  1. Turn off your computer.
  2. Remove the battery and disconnect the power cord.
  3. Turn over the laptop and unscrew the small cover which is retained by only one screw.jbertrand_ba_1.jpg
  4. Once the cover is removed, you will find the memory module.
Now under the memory module, you will find a blue plastic sleeve connected to the mainboard with a single wire. Disconnect the wire and wait about 30 seconds - 1 minute before reconnecting it. Replace memory module and put back the cover and screw it.
Replace the battery and reconnect the power cord.
Turn on the laptop and you will not be prompted for a password.
If you would like to put another BIOS password, restart the computer and enter the BIOS setup and there you will be able to define a new password.
Posted on May 10, 2011
Vostro 1500 screen blank except for flashing cursor
The good news is that your laptop powers on and you have a display. The bad news is that you laptop is trying to boot up from an OS (operating system software) like XP, Vista, or Win 7. Ether your software is corrupted or you have a problem with the hard drive or hard drive controller.
Press and hold the <Fn> key while powering the system on. This will run the Dell Diagnostics. Another more intense diagnostic program is located on a Dell CD that you should have received with your laptop. Look for one that has "Diagnostics and utilities" listed under the "Contents". You will have to boot from that CD disk. To do this, power on your laptop and tap the <F12> key to bring you to the "One time boot menu". Insert the CD and then select CD/DVD drive and hit <Enter> key. Select the "Run the 32 Bit Dell Diagnostics".
If diagnostics pass then your software is corrupted and needs to be reinstalled.
Mar 03, 2013 | Dell Vostro 1500 Notebook
Dell vostro 200 F8 menu won't respond to repair
to access the recovery partition you need to press Ctrl and F11 when you boot up which should start the factory recovery process.
Nov 11, 2012 | Computers & Internet
Dell vostro 1710 won't start after bios update
Assuming you did the correct bios update, you may need to remove the CMOS battery for about 30 seconds and then replace it.
Jul 05, 2012 | Dell Vostro 1710 Laptop
How to reset a Dell computer to factory settings
Resetting a Dell Vostro to the factory settings allows the user to restore the Dell Vostro to the original operating condition as if it was just taken out of the box. Dell system includes a restore utility called 'Dell Symantec System Restore' to reset or restore your Dell system to factory setting.
Step 1: Before reset any Dell Vostro laptop, backup your all important data and programs, otherwise you may lose it. It is recommended to use an external storage device for your entire data backup, so that you couldn't lose it in any sudden occurring issue...
Step 2: Remove any other unnecessary external drive and restart your Dell Inspiron laptop.
Step 3: Press 'F8' key continue until 'Advanced Boot Options' wouldn't be appear.
Step 4: Use your keyboard arrow key to select 'Repair Your Computer' from the list and hit 'Enter'.
Step 5: Now click 'Next' and login as the administrator account.
Step 6: Click 'Dell Factory Image Recovery and Data Safe options', select your language option and click 'Next'.
Step 7: Click the check box 'Yes, reformat hard drive and restore system software to factory condition' and click 'Next' to start Dell Vostro reset process...
This process will erase all your previous changes that have been made to the Dell Vostro laptop and reset the configuration settings to factory setting.
Feel free to get technical assistance for all type of Dell laptops(Vostro, Latitude,Inspiron...etc..) at
http://www.vtechsquad.com/dell-support/
Dec 01, 2011 | Dell Vostro 1500 Notebook
Vostro 1500, won't start, I press the power button, the drive light comes on and goes off and nothing else happens. Screen never comes on, external monitor same results.
Hello.
The most common reasons for power issues are the battery, power jack and power adapter/cord.
Power off and remove the battery. If the laptop powers on with just the adapter connected, your battery is faulty.
If you move/wiggle the power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.
The power jack is inside the laptop and either needs soldering or replacement. If a power jack problem, it should be addressed by someone knowledgeable.
If no change, the power adapter is probably faulty and needs replacement.
Hope this helps.
Oct 30, 2011 | Dell Vostro 1500 Notebook
Hello, the battery on my dell vostro 1500 is fully charged, at 65% of its life and passes the dell diagnostic tool, but.. when i take out the plug the battery fails in less than 5 seconds. any help is...
Ifthe laptop battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Jun 05, 2011 | Dell Vostro 1500 Notebook
Hi i have a vostro 1520 dell laptop there is a problem that some strange 1.my laptop when just full battery is connected to it won't turn on but when i press 20 to 30 sec the turn on key and...
First 2 of your problems are due to the fact that your laptop enters hibernation (or hybrid sleep in windows 7) and windows cannot restore your last saved state. The 3rd problem indicates you have windows problems (bad/not updated drivers, filesystem corruption, application issues). I would suggest you to reinstall windows.
May 14, 2011 | Dell Vostro 1500 Notebook
Vostro 1400 shorted
Dell Dell™ Vostro™ 1500 XP Windows Driver Recovery CD Restore DiskThis is an automated Dell™ Vostro™ 1500 XP drivers recovery cd. The Dell™ Vostro™ 1500 drivers are supplied in a special windows friendly format. This means that your Dell Dell™ Vostro™ 1500 XP Laptop will automatically find and install all the drivers for your system, with hardly any user intera ..... dell vostro 1500 eeprom short ...
Sep 04, 2009 | Dell Vostro 1500 Notebook
pls i need the password of dell vostro 1500 laptop
Dec 31, 2008 | Dell Vostro 1500 Notebook
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
