Question about Speed Queen Dryers
Speed queen sde107wf dryer
The dryer runs and heats up. t runs for part of a cycle then shuts down. When more coins are added will not restart. Allowed to run the tmer out until the light goes out still will not restart. Power is avalable at the red wire on the thermo high limit switch but none at the black wire. That legs is dead.
jgwhomeequip
  • 1902 Answers
SOURCE: Kenmore gas dryer #110.7732792 is making buzz/hum
Check for blockage in your lint trap and the hose running to the outside of the house
Posted on Apr 14, 2009
erpaalai
  • 999 Answers
SOURCE: coin operated speed queen gas dryer works some
Check the coils on the gas valve. Sounds like an intermittent one. Eric
Posted on Jun 20, 2009
localwonder
  • 6784 Answers
SOURCE: Whirlpool Dryer Does not dry
Its the thermal fuse. when you jump or, by-pass the cycle thermostat, you are basically by-passing the fuse as well. replacing the thermal fuse will fix thsi issue.
The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Posted on Jun 22, 2009
SOURCE: Maytag Performa PYE2200AYW Dryer Heats intermittently
i had the same problem with my dryer and i installed the wrong thermal fuse for gas dryer which calls for a pink thermal fuse in which i installed and it works fine also check the lint in the front of your dryer. also my dryer which is the same make as yours seems will run on the fluff cycle until i replaced the right thermal fuse. my dryer run exceptionally hot and eventally shut down and it only run on the fluff cycle for any length of time.
Posted on Sep 22, 2009
  • 77 Answers
SOURCE: dryer will not heat up Does run
It's probably the thermostats that are normally attatched to the element or it could be the element itself. They are nprmally placed in the rear of the appliance.
The thermostats will only cost a few pounds.
Posted on Mar 12, 2010
Kleensmaid heavy duty washer by speed queen, washes but shuts down on what seems to be overspeed on the spin cycle
Amazon.com: Customer Reviews: Speed Queen 3.3 Cu. Ft ...
www.amazon.com/Speed-Queen...Washer/.../B004ZO...
Amazon.com, Inc.Find helpful customer reviews and review ratings for Speed Queen 3.3 Cu. ... If you need more water in the tub you can hold down the reset switch until the machine ... I tried the delicate wash and spin cycle, but the clothes retain too much water and ..... It takes time to correlate the number of turns and the direction to turn it.Missing: overspeed
Commercial Washer and Dryer Problems
www.affordablelaundry.com/commercial-washer-and-dryer-problems
The water should shut off once it reaches wash level, if it doesn't, and water level hasn't... (these are the glass type fuses) be sure to turn power off before checking them. ... If you have the voltage in, but not out, it's the contactor. .... We repair: Speed Queenwasher, IPSO washer, Milnor washer, UniMac washing machines.Missing: overspeed
[PDF]View document in PDF
Dec 19, 2015 | Speed Queen Washing Machines
Why does my gas dryer heat for 30 sec then i hear a click and the gas shuts off?
It's not supposed to run continually, there is a thermostat inside that regulates the temperature to about 130-150F, if it's not in that range you might need to change the cycle thermostat.
Aug 06, 2014 | Speed Queen AGS28AWF Gas Dryer
Speed Queen Heavy duty Dryer appears to shut down because of over heating. We have had this dryer for quite awhile and the kids are all gone now so we actually don't use it as much. It doesn't...
The cycling or operating thermostatis often the problem when a dryer runstoo hot, but there are also other things that can make it run hot also.
Here is a tip that I wrote that gives more details about why a clothes dryer will get too hot.
Clothes Dryergetting too hot
heatman101
Aug 14, 2011 | Speed Queen AES28AWF Electric Dryer
When coin put into machine dryer started spark
Make sure someone hasnt shut off you gas supply. Check inlet gas pressure to valve. Check to see if you have voltage to the gas valve . If you have all that then the valve has bound up or burned out the opening coil . It will need to be replaced. Has this been happening to this dryer often. Do you have problems with other dryers? It sounds as though you are in a laundro-mat as the use of coins to operate.
Jul 16, 2011 | Speed Queen KGS18AWF Gas Dryer
Coin-operated Speed Queen washer: Model swtt21wn
speed queen double front load washer spinning without stop,please give some idea,thanks alot
Feb 21, 2011 | Speed Queen SWT921 Top Load Washer
Dryer will not heat up Does run
Mar 12, 2010 | Speed Queen Dryers
I have an old speed Queen coin operated dryer and I would like to remove the coin function. Can this be doneMachine detail on request.
you can get it to run by installing coin plugs in the slide are assembly or leave the top lock panel open and push the spring arm before each load for personal use.
May 22, 2009 | Dryers
Speed queen commerical dryer
try replacing the gas valve coils. they are cheap
Jul 25, 2008 | Speed Queen CGS68AWF Gas Dryer
Dryers Logo
48 people viewed this question
Top Speed Queen Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Kristy Heard Duke
Kristy Heard Duke
Level 1 Expert
Are you a Speed Queen Dryer Expert? Answer questions, earn points and help others
