Whirlpool whitemagic 650h esc error - Washing Machines
3 Suggested Answers
mohankumar63
  • 223 Answers
SOURCE: I get a "PE" error
As you said in the question you are washing machine is showing error "PE" it's not a big problem you are washing machine is just fine.PE means error signal due to low voltage .Machine resumes functioning after the voltage comes back to normal.Thanks for your question.
Posted on Jun 19, 2011
FitzOriginal
  • 842 Answers
SOURCE: Hi, Mine is a
I'm going to presume that when the machine is powered off there is no water coming in, thereby demonstrating that the inlet valve is not jammed open. If water IS still entering the machine even when it's powered off, please add a comment to this thread and we can discuss the matter further.
If the inlet valve is not the issue then this is almost certainly the result of the fill sensor failing.
Essentially, the sensor is a bellows device that activates a microswitch. A pipe is connected to the device at one end and to the water level in the drum at the other end. As the machine fills and water reaches the end of the pipe and advances up it, the air pressure in the pipe increases, inflating the bellows. As the bellows inflate, they press on and trip a microswitch inside the sensor and cut the power to the water inlet valve, stopping the water flowing into the machine when it reaches the correct, measured level according to the pressure in the pipe. If the device fails, it may not be cutting power to the inlet valve.
Take the top off the machine, if you look down the side you will see a (typically clear plastic) tube about the thickness of a pencil, connected to a circular device about the circumference of a coffee cup and about two inches thick.
This is the sensor. Problems with it may be:
It has come unclipped from where it should be mounted. The device is VERY sensitive and if it has slipped out of place, over or underfilling is common. (Reposition the sensor, hopefully you can see where it came from!)
The pipe that is connected to it has come off, so the air pressure that the sensor measures is not increasing as the machine fills (push the pile back on and all is well)
The machine has been subject to some trauma (Such as a very uneven load that has made it shake violently. The starting level of the water that is in the bottom of the pipe is now wrong and the pressure sensor is being affected. (Remove the pipe from the sensor, blow down the pipe to get any water that should not be there out and then replace the pipe).
A wire is off the sensor (Take a look around and re-fit any loose wire).
The sensor has actually failed and requires replacement. (A dealer in these goods will be able to find you a replacement, if you are visiting a dealer, take the unit, along with the make and model with you so they can match it easily. Failing this, search for a part on the internet and match it to your make and model).
Posted on Jul 28, 2011
Whirlpool top load 1-2-3 whitemagic it is showing 1E error why does this error come
your not getting proper water fill hot or cold water is not flowing into machine fast as it should check make sure water is turned on all the way or replace water valve
Dec 23, 2016 | Whirlpool Washing Machines
Whirlpool Washing Machine Whitemagic h70 Wiring Diagram
Can't seem to find one.
Is there a model# other than whitemagic h70?
I have had luck on parts places showing schematics when you start looking for parts in the machine.
Maybe that can work for you.
Nov 25, 2015 | Whirlpool Washing Machines
I am having whirlpool washing machine model-whitemagic FSAN652 during washing machine suddenly stopped working and an error PE is displayed pl give me suggestion to rectify
whirlpool have a good fault code list on the net
go google and type in whirlpool top loader model------ and look for pdf version of manual or fault codes.
Jun 28, 2015 | Whirlpool Washing Machines
Pe ERROR WITH WHIRLPOOL MAKE WHITEMAGIC 123 650 h WASHING MACHINE, MACHINE WORKS BUT OUTER BOWL DOESNOT SPIN AND MAKING BEEP SOUND DURING PROGRAMMED
does tube move by hand? does it have the correct amount of resistance when turning, or is it hard or too easy?
Dec 09, 2014 | Whirlpool Washing Machines
I get ESC error problum how to solve them
No water is detected having entered the machine. Check your water lines, make sure they're turned on and feeding water to the machine. If they are then you may have bad sensors in the washing machine. The ESC error occurs when no water is detected as having entered the machine. The Washing Machine upon not detecting water turns off the internal valves and kicks the error.
Jul 31, 2014 | Whirlpool Washing Machines
I get a PE error code
I get PE error code in whirlpool white magic F65
Aug 12, 2012 | Washing Machines
PE error where E is blinking in whirlpool whitemagic
pe error on the machine is normally the pause in action. try pressing the start /pause button again to activate the wash program
Jun 23, 2012 | Whirlpool Washing Machines
Washing Machines Logo
170 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
