Question about Juki Sewing Machines
How to set the timing on a juki lu-562
The walkin foot guide dosent move
5 Suggested Answers
  • 3741 Answers
SOURCE: I have a Juki Lu-562. The safety clutch counter
click this link directly .http://www.raichert.com/adobe/LU562%20LU563.pdf ------ its mentioned on page number 12 of the link.ablout the clutch spring adjustment. --------- check out.keep updated.thanks.
Posted on Nov 10, 2009
SOURCE: I have a Juki LU-562 sewing machine I was sewing
Like most of the older sewing machines, the lu-562 is usually an easy fix when it comes to issues of timing and even broken parts. First determine where the spring came from and that should point you to the parts that need replacing and/or readjusting. But, by all means DO NOT continue operating the machine until its fixed. Without actually seeing the machine, it sounds as if the needle bar spring failed.
Posted on Feb 28, 2011
SOURCE: How to put Lu-562 back in timing
try youtube or ehow
sewusa.com
Posted on Apr 15, 2012
Can the presser foot be raised slightly on pfaff tiptronic 2030 to facilitate free motion quilting? There is not enough clearance with feed dogs down to freely move material to quilt. Thank you.
You need a special foot for free motion quilting--it is slightly shorter in height than a regular presser foot, which essentially provides space between the presser foot and the needle plate to manually move the fabric. Sometimes machines came with a standard darning foot accessory. Your Pfaff dealer probably has at least one style in stock. But there are other specialty feet you can probably use, ie Big Foot, clear free motion foot, C-shaped, oval, etc. You can also purchase a shank adapter (verify it is the correct shank for your machine) and use it with a kit of snap-on presser feet so you can have a variety of presser feet for different functions.
Pfaff Presser Feet
Pfaff Big Foot Free Motion Quilting Foot
Pfaff Free Motion Guide Presser Foot
Pfaff Free Motion Open Toe Quilting Foot
http://www.sewingpartsonline.com/snap-on-sewing-machine-presser-feet.aspx
May 07, 2016 | PfaFF Sewing Machines
Can the lZ 1286 used walkin foot.Can it sew piping. What type of machine is it.
all machines can sew piping, but you need a special foot for the job
the foot looks like it is only 1/2 there and replaces the full foot
it allows the needle to sew right up against the piping
it replaces the standard foot
it is available from any sewing machine repair shop, or any shop that sells sewing machine accessories
Nov 05, 2015 | Sewing Machines
Free motion quilting with the Singer 3343
I don't use a foot - I just gently guide the fabric and create designs.Hope this helps.Jimmy
Mar 28, 2012 | Singer 3343 Mechanical Sewing Machine
Hello, I have a kenmore sewing machine model #385.19233 . It is not broken, what i need is someone who can tell me how to get this machine to do free motion sewing. I hope you can help me.
If your machine has an embroidery foot, this will allow you to free motion embroidery. The embroidery foot will be positioned close to the fabric but will not hold the fabric in place.The presser foot must be down so that you will have the correct tension. Once the foot is on, the presser foot lifter is in the down position, then it's up to you to guide the fabric under the machine in the pattern you want. I advise a regular straight stitch with about 6-8 stitches to the inch. Move the fabric at a medium speed under the foot. If you move too slowly the stitches will be too close. If you move too quickly you'll have HUGE skips in your stitches. The main thing to know is that you can't use a regular foot because it will hold the fabric in place, even if you lower the feed dogs. When I free motion, I use the embroidery foot and keep the feed dogs up just to give a little resistance but NOT to hold the fabric in place. I love doing the free motion and I hope this helps you get started. If it helps you, please come back and rate my advice. Thanks!
Aug 01, 2011 | Kenmore Sewing Machines
Singer inspiration. When using zipper foot. Excess amount of thread on bottom of material, very loose and loopy. Wasting alot of thread for such a some task.
Your top threading is not right, check to make sure that your thread hasn't jumped out of a guide. Totally rethead with the presser foot up, now pull thread, it should move smoothly, next put the presser foot down, the thread should barely move. This will seat your thread in the tension discs. If, that does not work, insert a new needle.
Apr 23, 2011 | Singer Inspiration 4210 Mechanical Sewing...
Why does the backing gather up even though it is penned and sprayed with quilting spray
Presser foot tension is to low for the weight/finish of the fabric, or bottom dogs are worn.
  • The feed dog feeds the fabric under the presser foot while you guide the fabric.
  • The feed dog regulates the stitch length by how much fabric passes under the presser foot as the machine stitches.
  • It is important for you to not push and pull the fabric under the presser foot. Allow the feed dog to move the fabric, so that you do not bend and break sewing machine needles.
Hope this helps.
Feb 09, 2011 | Sewing Machines
My janome machine model 2001.doesnot work properly it thread is loose from down side during sewing ,sometimes work properly but some time while sewing it shows same problem i was cleaning with tooth brush...
I think you may have to careful clean everything and check you havn't dropped feed dogs or changed a setting. I don't really know what you mean by the foot getting stuck, but if the feed dogs ( moving part under the cloth) are down than the cloth can't move. Also, the pressure of the foot may be too high; this can also happen accidently while cleaning.
Get a manual ( sewingmanuals.com) and double check everything. Also, check there is no thread in the thread guides as this may have been your original problem. pull a thread towards to needle
Sep 02, 2010 | Janome 4612 Sewing Machine
How to fit an even feed foot with quilting guide to a Janone J3-24 with a front loading bobbin?
Their is going to be two spots to make sure are attached right. #1- the shank of the foot should be secure and flat. #2 the arm that extends from the walking foot should be straddling the needle screw ( this allows the top feet to move up and down with the needle/bottom feet)
Let me know if you need more help, Chris
Jun 12, 2010 | Janome 1600P-DB Mechanical Sewing Machine
Keeps on running as soon as it is pluged in foot pedal dosent seem to do anything
The suppressor has blown usually in the foot control, if you can undo the foot control and take out what looks like a fuse the machine will run perfectly, if the suppressor is on the motor then you will need to take it in to a repair shop because in that case it would have to be replaced, the foot cointrol suppressor does not have to be replaced.
Sep 13, 2009 | Bernina Sewing Machines
Pfaff Creative 1371
I suggest you to order the following product:
Sewing Machine Repair Guide
It's a professional repair guide written by an expert. Besides PfaFF sewing machine, you can learn how to repair other brands of sewing machine as well. The author claims that you can earn money after you had learn the repair skills!
Good luck.
Feb 21, 2008 | PfaFF Creative 7570
Sewing Machines Logo
Top Juki Sewing Machines Experts
Tally Girl
Tally Girl
Pete Alaniz
Level 1 Expert
SewTechWayne
SewTechWayne
Are you a Juki Sewing Machine Expert? Answer questions, earn points and help others
