Question about HP Color LaserJet 2550n printer + HP Color Training and extended warranty ;U4929E, Next-Day exhange...
Change ip address on color laserjet 2550n - HP Color LaserJet 2550n printer + HP Color Training and extended warranty ;U4929E, Next-Day exhange...
SOURCE: HP JetDirect IP Address
how to assign the IP address to Hp color laserjet 2550Ln printer?
Posted on Sep 17, 2008
  • 10406 Answers
SOURCE: how do i change the ip address on an hp laserjet
Use the buttons and the LCD on the printer, to navigate through the main-menu and the sub-menus, to change the IP-address.
Also, via the manufacturer's web-site: http://support.hp.com
select & download the "Quick Setup Guide" for your specific model of printer, and follow its instructions.
Posted on Nov 18, 2009
HP Xpert
  • 112 Answers
SOURCE: HP Color LaserJet 2550N. Slow printing takes 16
http://www.hp.com/#Support
Follow the link and get the correct driver and get installed
Posted on Jan 19, 2010
BarrettDenCo
  • 1772 Answers
SOURCE: Need to change the ip address on an hp laserjet
Sorry to read about your problem, I hope this helps you out.
Use the Networking screens to configure and manage your product on your network. The appearance and features of the Networking screens differ depending on the model and version of your HP Jetdirect print server. The following screen is similar to what you might see when you click Networking. From the left navigational bar, click the Networking menu for the screen that you want to view
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Posted on Dec 21, 2010
SOURCE: how do I change IP address settings for my HP
Changing the printer's IP address
If the TCP/IP address needs to be changed, the HP Jetdirect can be reset to factory defaults so that it can receive a DHCP configuration from a server (see below). Another method is to use the printer's control panel:
1.Press the green check mark (Select) button.
2.Press the Up or Down arrow to scroll to CONFIGURE DEVICE menu and press the check mark button.
3.Press the Up or Down arrow to scroll to I/O , then press the check mark button.
4.Press the Up or Down arrow to scroll to EIO 1, 2, or 3 (depending on which EIO slot is in), then press the check mark button.
5.Press the Up or Down arrow to scroll to TCP/IP , press the check mark button.
6.Choose Config Method , then press the check mark button.
7.Choose Manual , then press the check mark button. Wait for the display to return to the Config Method screen. A Manual Settings option should now be available.
8.Press the Up or Down arrow to select Manual Settings , then press the check mark button.
9.Press the Up or Down arrow to scroll to IP address , then press the check mark button.
10.Use the Up or Down arrows to choose first byte of IP address. Press the check mark button to save the IP byte.
Repeat for the second, third, and fourth octets.
11.Continue using the Up or Down arrows and the check mark button to enter the Subnet address and the Gateway address.
Posted on May 05, 2011
Ip setup
Check the following link,
http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&dlc=en&docname=c00262557&lc=en
Search for the TCP/IP settings from the Menu button in the settings and then you can manually change it.
Hope it helps.
Jun 12, 2013 | HP LaserJet 2550n Printer
How do I manually setup the ip address on the hp2550n
go to printer settings & set printer IP address.
Hp laserjet 2550n stopped prining in color, why?
Check your print driver settings. And if you are printing from any of the microsoft office applications look at the page setup to see if something was changed. Click file, then right near print is the page setup.
Nov 21, 2011 | HP LaserJet 2550n Printer
How can I setup static IP address on this printer
Press both the green 'Go' Button and the orange 'cancel' button,
This should produce 3 test prints from the machine, the last one being your network configurations....
Go toyour PC, and browse to the ip shown. Open the settings page and change it there.
Dec 23, 2009 | HP LaserJet 2550n Printer
I need to print off the configuration page nicludng the DHCP given IP address
When the printer is in the ready state, press the go and cancel buttons at the same time and a config page will print.
Dec 23, 2009 | HP Color LaserJet 2550n printer + HP Color...
Won't print!
Hi there, well I found a manual and online drivers for this unit. If you have never printed on this machine, and it is currently on the nwtwork? You have to either log into the printer or make sure the printer knows it is on the network. In the display it should state the IP address for the device. Also when you installed the drivers for the machine, I assume you did a successful "Test Page Print"? Let me know if you have more problems. Here are your links:
Manual & Drivers: Click Me
Turk
Oct 20, 2009 | HP Color LaserJet 2550n printer + HP Color...
Jun 30, 2009 | HP LaserJet 2550n Printer
Computer and printer not talking through router
Ensure that the computers and printer are set to "obtain ip address automatically" If they are, try shutting down the router and all four devices, the restart each one starting with the router, and make sure the router is completely up before starting the computers. If that doesnt work, the network connection to the printer could have blown when the router did.
Jun 11, 2009 | HP Color LaserJet 2550n printer + HP Color...
Drum Light On
You will need to replace the drum soon. It can be purchased directly from HP here: http://www.shopping.hp.com/supmodel/product/Q3704A%2523ABA?jumpid=in_r329_search//laserjet+2550n_Q3704A
Or, you may be able to find it cheaper in Google. Type in "Laserjet 2550n drum" and see what results you get.
Mar 25, 2009 | HP Color LaserJet 2550n printer + HP Color...
May 10, 2008 | HP LaserJet 2550Ln Printer
169 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
