Question about Exercise & Fitness
How do i fold up and lock the proform 835 QT treadmill? The latch is higher than the bolt.
Nothing in way of closing.
    Top Expert:
  • 12,223 Answers
See the video attached. God bless you
Posted on Nov 28, 2012
5 Suggested Answers
ButtFuzz
  • 463 Answers
SOURCE: Proform 860 QT doesnt have power
There's a little breaker near the main on/off switch that has tripped. Re-set the breaker. (also check the main on/off switch, typically near where the power cord enters the treadmill...
Posted on Mar 13, 2009
  • 10 Answers
SOURCE: my proform 830 qt circuit keeps flipping
I've been having this problem too and it seems the best solutions i've came up with have been to buy a lube kit for the treadmill from the proform website or replace the circuit breaker.
Posted on Sep 24, 2009
taran_2005
  • 10515 Answers
SOURCE: Proform 765 treadmill slows down when step on. Do
More likely time to replace the belt. Let me provide you with all the information you need. This information is already there on many websites.
BELT LOSES POWER
(Bogs Down or is Sluggish) This condition is when the treadmill operates normally without a person on the belt and then slows down when someone steps on the belt or when the treadmill operates normally for a given period of time with someone on the belt then abruptly begins to slow down.
There are four typical causes for this problem (listed in order of our experience:
1) The walking belt and/or deck are worn. (85% of the time)
2) The walking belt and/or motor belt are too tight- if you have adjusted either recently. (8% of the time)
3) The motor has lost torque and needs brushes or has demagnetized. (5% of the time)
4) The controller is dropping output. (2% of the time)
Walking Belt is Worn:
The only certain way to test for a worn walking belt is to take a DC amp draw (if you have a DC treadmill) or an AC draw (for AC). Trying to look at the belt or a feel test is highly unreliable. Better tests, if you lack a DC ammeter (they are expensive for a good one), are a coast test or an incline test. To test the deck, go back to the Troubleshooting section and download the belt and deck inspections instructions. The coast test is to get on the treadmill as the lowest incline setting and walk on the treadmill at 3 MPH. Pull the safety key and it should take you 2-3 full steps to stop (this is a general rule…some like a few Tunturi models stop on a dime even with a healthy belt but most this tests works well upon). Fewer steps indicate high friction.
The incline test is to put the treadmill at max incline and walk on it at 3 MPH. If the treadmill operates normally at max incline but bogs down at minimum incline, replace the walking belt. Gravity takes over for the drive system eliminating the friction problem. On some heavily worn walking belts, this test will not eliminate the problem.
Walking Belt/Motor Belt too Tight:
If you have adjusted the walking belt or motor belt recently, check for this problem. When the belts start slipping, some people just crank down the belts and on treadmills, tighter is not necessarily better. The
tighter the belts, the more the drive system has to work to keep everything moving. You should be able to lift the walking belt (with the treadmill unplugged) in the center of the treadmill about 3” without straining. Tighter belts should be loosen but make sure you don’t create a dangerous slipping situation by loosening.
The motor belt (with the treadmill unplugged) should be able to be turned by hand to almost a 90 degree angle from its normal operating position. Loosen the belt if too tight. Make sure to test for slipping and if it does with the proper tension, replace the motor belt.
Needs Brushes / Demagnetized Motor:
Typically when we find a motor that has lost torque; it needs a new set of motor brushes. Typically we can make brushes for almost any motor if we don’t already stock them. Motor demagnetization is not that common but it does happen and it is normally easy to diagnose. If you have confirmed the belt and/or deck is not worn and the belts aren’t too tight, you can test for a motor torque problem. DO NOT USE YOUR HAND OR ANY OTHER BODY PART TO IMPEDE THE MOTOR…YOU WILL LIKELY LOSE YOUR BODY PART IN THE PROCESS IF THE MOTOR IS GOOD. The step to test for the motor is to use a foreign object preferably on a long shaft. First determine the direction of the motor spin (most have directional movement printed on the motor tag), then apply pressure with an object with downward pressure on the flywheel in the direction the flywheel is turning (do not attempt to put force against the rotating direction of the flywheel as you can easily injure yourself). If you can slow the motor, typically you need brush replacement.
To test for demagnetization, the motor must be disassembled. Once you have the motor retaining bolts removed, remove the motor core by sliding it out of the end of the housing. If the magnets pull the core against the housing and it is difficult to remove, the magnets are good. If the magnets do not attract the core, the motor has to be replaced.
Controller:
This is the most uncommon of the causes. Typically replacing a controller in this situation will not solve the underlying problem and then you will end up replacing a belt as well as a control. Normally if a control is dropping output, it will do it with a person on the belt or not. Tests of DC output dropping is normal in many controls since they have a current limiter which will automatically drop output to prevent burning up the board. This is best diagnosed by eliminating the other possible problems first. If you are left with the control as the cause, replace the control.
The site :-
http://www.treadmilldoctor.com/Treadmill-Belt-Bogs-Down
Any further assistance, let me know.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Oct 10, 2009
  • 218 Answers
SOURCE: converting kph to mph
press and hold the stop button while placing the key on, then release and hit speed + or - I don't remember which right now. One turns the store demo on/off and the other is for mph/kph
Posted on Aug 14, 2010
We folded the Proform 500 LE Elliptical and moved it. Now we are unable to unfold the elliptical with the latch button. Suggestions?
HOW TO FOLD AND UNFOLD THE ELLIPTICAL
When the elliptical is not in use, the frame can be folded out of the way. First, lift the latch under each pedal arm, and lift the pedal arms off the adjustment sleeves on the crank arms.
Next, raise the pedal arms until they touch the magnets on the upper body legs; the magnets will hold the pedal arms in place.
Then, hold the handle and lift the frame until it locks in a vertical position. To use the elliptical, first hold the handle, press the latch button, and lower the frame.
Next, pull the pedal arms off the magnets on the upper body legs.
Then, lift the latches under the pedal arms, and set the pedal arms on the adjustment sleeves on the crank arms.
Release the latches, and make sure that the pedal arms are securely connected to the adjustment sleeves.
Will be attaching a link to your manual also
http://www.sportsmith.net/images/product_support/ProForm/PFEVEL959101%20-%20PROFORM%20500%20ZLE%20ELLIPTICAL/PFEVEL95910.1-307585.pdf
May 25, 2015 | Proform Exercise & Fitness
How do i fold my treadmill
sounds like the latch could be broken
Aug 30, 2014 | Proform 600 LT Treadmill
I lost the latch knob bolt
please go to www.fitnessrepairparts.com and get the parts
Happy new year. God bless you
Jan 01, 2013 | Proform Performance 400 Treadmill Exercise...
How to fold my afg 5.0 treadmill for storagae
Dear Sir: Hello , i hope everythign is o.k
Please do the following:
FOLDING Firmly grasp the back end of the treadmill. Carefully lift the end of the treadmill deck to the upright position until the foot lock latch engages and securely locks the deck into position. Make sure the deck is securely latched before letting go. To unfold, firmly grasp the back end of the treadmill. Gently press down on the foot lock latch with your foot until the lock latch disengages. Carefully lower the deck to the ground. NOTE: on some models the foot lock latch might be on the right hand side. NOTE: when folding the Horizon Fitness Treadmill the console assembly will tilt away from you, but will return when fully folded in the upright position. Please allow two additional feet from wall when folding.
Thank you in advance, sincerely. Blessing.
If you need additional help, please contact me.
e.cuadra Managua, Nicaragua C.A.
Sep 25, 2011 | Horizon AFG 5.0 AT Treadmill
My Proform 785 will not unfold even after I have pulled the latch. Is there something else I need to do to unfold it?
You may have damaged the treadmill when folding it up. If the incline was not lowered to its minimum position, the frame can be damaged.
To lower the treadmill, all you do is release the latch and lower the deck of the treadmill to the floor.
There are many Proform machines known as "785" including a number of elliptical trainers. An actual model number would make diagnosis much easier...
Feb 26, 2011 | Proform 785 Treadmill
How do i fold up then unfold the proform xp 620?
Before folding the treadmill, adjust the incline to the lowest position. If you do not do this, you may damage the treadmill when you fold it. Remove the key and unplug the power cord. CAUTION: You must be able to safely lift 45 lbs. (20 kg) to raise, lower, or move the treadmill.
Hold the metal frame firmly in the location shown by the arrow at the right. CAUTION: To decrease the possibility of injury, do not lift the frame by the plastic foot rails. Make sure to bend your legs and keep your back straight as you raise the frame. Raise the frame about halfway to the vertical position.
Raise the frame until the latch knob locks into the storage position. Make sure that the latch knob is locked in the storage position. To protect the floor or carpet from damage, place a mat under the treadmill. Keep the treadmill out of direct sunlight. Do not leave the treadmill in the storage position in temperatures above 85° F (30° C).
To lower follow this procedure:
Hold the upper end of the treadmill with your right hand. Pull the latch knob to the left and hold it. It may be necessary to push the frame forward as you pull the knob to the left. Pivot the frame downward and release the latch knob.
Hold the metal frame firmly with both hands and lower it to the floor. CAUTION: Do not grip only the plastic foot rails or drop the frame to the floor. Bend your legs and keep your back straight.
Jun 02, 2010 | Proform XP Weight Loss 620 Treadmill
The band is not moving
Proform 830 QT built sped up to fast and then stopped working. Will not move any more. Is there a reset button?
Sep 16, 2009 | Proform Sport 1000 Folding Treadmill...
Unfolding the deck on treadmill
From the owners manual:
HOW TO LOWER THE TREADMILL FOR USE
1. Hold the upper end of the treadmill with your right hand.
knob.
2. Hold the metal frame firmly with both hands and lower
Jan 08, 2009 | Proform XP Weight Loss 620 Treadmill
My proform 830 qt circuit keeps flipping
Dec 12, 2008 | Exercise & Fitness
Exercise & Fitness Logo
64 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
