SOURCE: hob not working
replace the hob. the f1 error is not sensing a temp change and if the burner is broke it wont sense it.
SOURCE: TOUCH CONTROL HOB (SCHOTT CERAM) GLASS CRACKED
Hi. Yes you can buy a new glass. Most of the come with frame top now. If you get me the model # I can look this up for you and get you an idea on cost.
Vic
SOURCE: Stoves 700CTH hob
I have a Stoves 900 CTH with the same problem. Its been like it for about 6 months and we're still able to get it going eventually.
If you turn the power on at the mains and leave it beeping for about 2 hrs then press the power on touch button. You should see all the "0."s flashing. When the flashing and beeping goes slow try pressing one of the hob buttons alot until the little dot illuminates next to the 0 then quickly lit the + button.
It sometimes works after 5 mins but other times it takes 20-30mins and is a real pain in the ****.
I did ring Stoves a while back and they quoted me £190 for the pcb but I hardly use it so just lived with it as it is but I finally had enough tonight and done a web search which turned up this thread.
I've just pulled it to bits to see if I could locate this "C17" but not 100% sure what I'm looking for.
Is it the big silver thing in the center with 5B RVJ on it?
SOURCE: I can't unset the child safety lock on my diplomat ceramic hob
get the model number if a cooktop will be underneatth on sticker.... go to kitchaid.com and locate thier manuals and literature section where u can download a copy or print one out.... hope this helps
