Question about Navigon 5100 GPS Navigator Handheld GPS Receiver
Navigon 5100 does not connect with GPS
Message on screen "GPS reception is currently not sufficient..."
  • Anonymous May 19, 2009
    I hold my navigon outside for like 1/2 hour and it still doesn't pick up the satellites.
NAVIGATION IS NOT WORKING. THE SCREEN IS " NAVIGON AND THE WORLD IS YOURS"
WHAT IS THE SOLUTION.
Posted on Feb 06, 2009
Reception currently not sufficient navigon iphone problem
This indicates that the Navigon app is unable to get a GPS fix to determine your exact location. This can happen in areas with lot's of buildings or thick tree line. You may have to use a module with an external antenna option if it continues on a regular basis. Also make sure under settings - Location Services - Navigon that the option is turned on. If it is off it will not be able to use your GPS radio in the phone.
Mar 02, 2011 | Cell Phones
3 DAYS GPS gps reception is currently not sufficient.Why?
I had to reset the whole thing back to factory standards
go to
options
settings
options again
factory settings
then click yes.
Aug 01, 2009 | Navigon 2100 Portable GPS Receiver
Navigon 5100 When connected to charger, computer icon comes up
you are not using a charger with the right voltage- you need 5 volts 1.2 amps radio shack has a gps charger that will work
Jul 15, 2009 | Panasonic Navigon 5100
My Navigon 5100 GPS will not turn on. At times, when it does turn on, it will not turn off.
I'm not sure if you realize this, but you must hold the power button for about 10 seconds to turn the 5100 on and off.
Jul 12, 2009 | Navigon 5100 GPS Navigator Handheld GPS...
GPS signal not sufficient on iPhone 3G
Had the same problem with Navigon for the iPhone. I found a simple quick fix:
1. Go to your iPhone Settings
2. Press the General tab
3. Scroll to the bottom and press the Reset tab
4. Press the Reset Network Settings tab
This may take a short time, then after it's done, reboot your device (if it doesn't on its own).
You should now have a good GPS signal!
Jul 05, 2009 | Navigon 5100 GPS Navigator Handheld GPS...
Navigon 5100 gps
Try turning it off and turning it back on while it is still plugged in and see if that works.
Oct 23, 2008 | Panasonic Navigon 5100
Navagon 5100
Hello 1234567i,
Most GPS receivers are not designed to be used for tracking. The GPS receives signals from Global Positioning Satellites and then uses those signals to calculate its current location, which it displays on the screen. However that data is not normally sent anywhere externally so there is no way for a remote user to determine where the GPS is.. Thus you cannot use a computer or any other device to track the GPS.
The Navigon 5100 appears to be no exception.
Without pairing the GPS with an external communications device (cell phone, two-way radio, laptop with a WiFi connection, etc.) the GPS lacks the ability to transmit its location reports to any external source. There certainly are ways that a GPS can be used with an external communications device as a tracker, but most GPS receivers do not have this capability out of the box.
Best Regards,
Ken
"Go Ahead. Use Us."
Jul 07, 2008 | Panasonic Navigon 5100
Navigon 5100 GPS Navigator Handheld GPS Receiver Logo
601 people viewed this question
Top Navigon GPS Experts
Will Halftowaite
Are you a Navigon GPS Expert? Answer questions, earn points and help others
